Spacers are for the prop if the adapter is smaller than the reamed diameter. This is not the case here because you can ream it to the size of your adapter. You won't need them.
If the prop hits the base plate when turned around (pusher configuration) then just put an ordinary metal washer in between until cleared. Alternatively you could trim/groove the base plate where the prop hits until cleared. Chris |
United Kingdom, Swansea
Joined Mar 2011
It HAS to be a washer otherwise the nut won't tigten down far enough for the adaptor to clamp onto the motor shaft So I need a spacer/washer about 5mm thick (min) and of similar outside diamter to the circular part of the prop This this is supposed to be ARF, it's claimed that all you need is TX/RX ESC and battery Turns out it has crap glue, the prop won't fit along with the supplied adaptor and motor, there are no servo extensions (only elevator which is pre-fitted), not to mention missing servos ![]() It's not so much the cost as the hassle in sourcing these items and having to wait for them to arrive from wherever |
| Thread Tools | |
| Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) | kylevn | Foamies (Scratchbuilt) | 106 | Jul 01, 2012 10:28 AM |
| New Product Seaplane ICON A5 by Guanli | kitaro | Scale Electric Planes | 4 | Sep 04, 2011 05:22 PM |
| Discussion GuanLi Icon A5 for FPV | popoti | Video Piloting (FPV/RPV) | 22 | Nov 11, 2010 10:40 AM |
| Discussion Interesting new LSA amphibian in the works: The Icon A5 | Thomas B | Waterplanes | 30 | May 14, 2010 02:00 AM |
| Discussion micro icon a5 | afitz87 | Foamies (Scratchbuilt) | 4 | Apr 24, 2010 11:47 AM |
