Old May 03, 2011, 12:11 AM
motronic is offline
Find More Posts by motronic
Athens, Greece
Joined Apr 2006
Originally Posted by highfly! View Post
thomas, you are correct i used the 602 after carving some of the foam to accomodate the new retract. I had several flights with this setup and no issues so it seems to work.
many thx bit windy to fly some pictures though
motronic is offline Find More Posts by motronic
Old May 03, 2011, 07:38 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Maiden flight:
HK 1.8m Icon A5 - First Flight (1 min 58 sec)
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old May 03, 2011, 08:16 PM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Finally I had a chance to fly my 1800mm ICON A5 in reasonable weather. Repaired broken fuse with some reinforcement (applied carbon tow) and now it is rigid, replaced gear servo with larger one. I have not increased volume of sponsons yet.
It flew good on water in moderate wind. Can take off well with small flap down. It can land very slow, or can land and continue to plane ok. I flipped it once to take off too slow.
ICON is sensitive to CG position, also sensitive CG height and center. It will not stand straight if I mount battery side of cockpit. It was noticeably unstable if I mount battery high on top of nose gear linkage. I ended up to add some ballast (temporary small battery pack) to get correct CG for me.
It is very prone to wind on water. Due to lack of sponson volume, it was difficult to turn in moderate wind when other float planes (even high winged planes) do not have difficulty.
It can fly in very small area slow, close to pilot. It is ok as far as it points windward, it can take off and land beautifully. I will plan to increase sponson volume somehow.
Satoru
ssatoru is offline Find More Posts by ssatoru
Old May 03, 2011, 11:45 PM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
Congrats on your Maidens. !!!
DaveBC is offline Find More Posts by DaveBC
Old May 04, 2011, 02:11 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
............................ I will plan to increase sponson volume somehow.
Satoru
I was worried about the off center Cg as a result of battery location issue, as well....luckily, I had a spare pair pair of 4S 2200mAh Turnigy nanotech 25c packs (did not quite measure up as competitive packs for electric Formula One racing) and was able to do a balanced installation, with one pack on each side of the nose gear pushrods. (as motronic did above, in post 331)
As nice as the fuse servo tray is, might be worth cutting it away and getting the batteries even lower.
I am planning for the first water flights in two weeks at a seaplane event and I am definitely going to increase sponson volume before I try it out on water....have high hopes it will help.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old May 07, 2011, 02:54 AM
ssatoru is offline
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Good luck for the first flight. Yes, 2 packs in parallel will be the best to get balanced. I am not sure I want to place the pack lower to avoid water. Mine does have water leaked in from somewhere after each flight.
I also plan to attend water plane event early June. That place is large river where wave is not calm. I need to think about neat way to increase volume.
Satoru
[QUOTE=Thomas B;18146521]I was worried about the off center Cg as a result of battery location issue, as well....luckily, I had a spare.../QUOTE]
Old May 08, 2011, 01:27 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
the SMALLER A5
Originally Posted by Lancer31 View Post
Judy did a great job of hand launching the Guan'Li version of the Icon A5,
and it hardly needed any trim. It was a beautiful test-flight. We are ready to take it to the float-fly.
Hi Lancer:
You are referring to the smaller A5 here, correct?
Do you (or anyone else out there) mind sharing their motor/prop/esc/battery setup for the smaller A5?
I picked up a kit version yesterday...
Rob
Bombay is offline Find More Posts by Bombay
Old May 09, 2011, 08:25 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
bye
Lancer31 is offline Find More Posts by Lancer31
Old May 09, 2011, 09:52 AM
Vasy is offline
Find More Posts by Vasy
Vancouver, Canada
Joined May 2007
Originally Posted by Bombay View Post
Hi Lancer:
Rob
KD A22-15M Brushless Outrunner, 2200 3s battery as I found this is the only one I can use with out adding any extra ballast. 35Amp ESC and a GWS 9x5x3 prop.
I had to cut the step deeper for it to take off water. With out the mod it would dive when I added power to take off turning into submarine
A-5 by HobbyKing (4 min 45 sec)
Vasy is offline Find More Posts by Vasy
Vasy is offline
Vancouver, Canada
Joined May 2007
My unsuccessful maiden flight.
Broke the tail off. Managed to fix it and flew after. Will post a short video that got to shoot before the camera battery died.
Old May 09, 2011, 10:36 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Vasy:
Thanks for the motor info. Can you clarify what you mean by diving under power? Are you stating that without the deeper step...and before it takes off from the water...throttling up causes the plane to submerge?
Would you say that the motor/prop/battery combo you are using provides more than enough power? Lastly, did you have to raise the motor or cut a notch into the tail boom to fit the 9" prop?
Rob
Old May 09, 2011, 04:19 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
We might want to keep this thread for the two NfD Icon models and post info about the Guanli Icon over in the thread about the Guanli Icon.
This would help prevent any confusion in this thread by readers.
Old May 09, 2011, 06:47 PM
NY, Rochester
Joined Oct 2003
Sorry to see that, glad you got her going again!
Chris
PS: Treeplane
Old May 10, 2011, 02:29 AM
Vasy is offline
Vancouver, Canada
Joined May 2007
Chris
PS: Treeplane
Battery was about to die in the camera, so just did a quick take off / land
I find the plane flies not bad at all, I like it better compare to the mini A-5.
Icon A5 into the tree (1 min 40 sec)
Short Icon A-5 flight (0 min 49 sec)
Old May 10, 2011, 10:32 AM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
She seemed a bit underpowered and tail heavy from the video. Did you use the stock setup?
Highfly! is offline Find More Posts by Highfly!
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 04:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 06:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 11:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 03:00 AM
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 4 Apr 24, 2010 12:47 PM
