Old Oct 14, 2010, 03:56 PM
Firehawk989 is offline
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
Originally Posted by Jürgen Be View Post
thats it
Firehawk989
I did the payment via banktransfer, the called it payment by T/T. First I was`nt shure, if I will do this to a forein country, but everything went fine. No problems with order, payment and shipping. But the shipping was nearly the same price, as the model
Also nice contact via email with the support. I checked everything by email, also ordered the model by email, not on the website.
Jürgen
Thanks! I will contact them via email when I have the extra cash lying around to pick this plane up. Roughly what was the total cost for the kit and shipping in USD if you don't mind me asking?
Firehawk989 is offline Find More Posts by Firehawk989
Old Oct 14, 2010, 05:00 PM
Jürgen Be is offline
Find More Posts by Jürgen Be
Jürgen Be's Avatar
near Stuttgart, Germany
Joined Oct 2008
Firehawk989
sorry, I can`t tell you the price for one kit inkl. shipping, because I´ve ordered a set of 2 of the small ones, and 2 of the 70" version, for me and friends. But if you ask for the price at NFD Hobby, they shurely will tell you.
baddb1
nice, I also have one of the 70", but still in the box. I will try to get it flown with only 3 cells and a motor at 700 - 800KV and maybe a 12" 3 bladed prop.
I missed the manual too.
Could you please post some photos of your linkage for the landinggear / servomounts??
On the small A5, I set the CG between 1/3 (a bit more in front of) of the wing, measured from the leadingedge. I think this will work at the 70" version too.
Jürgen
Jürgen Be is offline Find More Posts by Jürgen Be
Old Oct 14, 2010, 07:59 PM
Vancouver, BC
Joined Aug 2009
Firehawk989
baddb1
Jürgen
No problem! Thanks for the info anyway.
Old Oct 15, 2010, 02:05 PM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
So how did it do for water getting in the cabin? Did you have to tape it shut? How where the flight characteristics with the flaps, did they help at all?
Dakrat is offline Find More Posts by Dakrat
Old Oct 15, 2010, 02:46 PM
Jürgen Be's Avatar
Joined Oct 2008
There`s no need, to tape the cabin and after all flights, the woodparts in the fus were dry. If some water gets into the fus, there`s a kind of valve / outlet behind the step, as you can see in a photo few threads before. The water gets out when flying the model.........Same is in the 70" version.
With the flaps, the A5 flies very stable and they help for flying at lower speeds. Starting from water was easier.
But I can only speak for the small version with the flaps. With the flaps, I do a little aileron up ( see in a photo) and there`s no need to mix elevator up, or down.
Jürgen
Old Oct 16, 2010, 10:15 AM
ssatoru is offline
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Hi all, I finally got 1800mm ICON A5. I asked local distributor who carries EPO 50 Rainbow from the same company to get one for me.
The box is lage but neatly packed. Wing front edge red is already painted. 6 page color manual with step by step photo, instruction in Chinese and English comes with it. If anybody wants, I will try to scan and mail tomorrow or Monday.
Manual says CG is '75mm away from the front edge of the wing, which is located in the servo extension groove.'
Manual photo shows low cost TowerPro SG91R 10g servos are used for moving surfaces. (I am not sure they are enough.) It specifically advises to use reliable metal servo HITEC 85MG for rudder/stairing and rectract.
Satoru
Originally Posted by baddb1 View Post
1 - The manual was not sent with it. They informed me they would send it when it is complete. Not a biggie, BUT, I am unsure of where the COG should be. Does anyone have an idea?
[/URL]
ssatoru is offline Find More Posts by ssatoru
Old Oct 16, 2010, 11:09 AM
lupy is offline
Find More Posts by lupy
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
I sure wouldn't trust it to a 10g servo.
http://www.hobbycity.com/hobbycity/s...idProduct=8760
It's 17g but has as much torque as a normal sized servo, and is $15.60 for members. Best of all, it's suppost to have seals, helping to protect it from water. It is rated very well by lots of people, the top couple of reviews are negative, but lots of people on the glider forums rave about them. I would run it on 5V, some of the neg reviews have run 6V and had problems.
Does the manual list a wing area?? Also a wing width near the flaps?
Ken
update, Got a few of these, no seals, so must be waterproofed with grease and corrosion x, which worked fine. They are really strong servos, and currently working on my Neptune II .40 class seaplane. They are not quite as smooth as a full sized servo, but I can't feel it in the air.
lupy is offline Find More Posts by lupy
Old Oct 18, 2010, 12:08 AM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
subscribed
i have a cessna 185 but havent got so far as to fly off water with it yet... has anyone here flown both a 1500mm cessna and 1800mm Icon and comment as to which is the better bird to fly off water?
AussieHoppy is offline Find More Posts by AussieHoppy
Old Oct 18, 2010, 02:08 AM
ssatoru is offline
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
I measured the main wing area as 35.6dm2. (Root chord 22cm, taper starts at 50cm from root to 12cm chord at wing tip.). WCL will be 11.8 which is in the range of sport plane.
For me it is heavier than 1.63m span Multiplex Magister's 45dm2 I fly as float plane at 2.7kg with 600W or so power. I will need to give ICON more power.
The main wing is thick and under cambered. (Good!) The main retract does not have lock, it will rely on nose retract's which will be linked together. Unlike manual stated, rudder and water rudder is already linkaged. Elevator servo extension is already wired. Canopy is already built. (it seems a tight fit to open from aft side only.) It is good to see center part of belly is protected by plastic already. I was expecting to cover it with glass but seems not needed. I think I can build it in shorter time than I thought.
Thank you for info on 17g servo. Yes, I will stick to servo I am familiar with (Hyperion's or GWS in my case) and will not take risk here.
Thanks.
Satoru
Old Oct 18, 2010, 07:03 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Satoru
YES, that would be nice if you could scan manual! PM me.
Thank you for the CG info. That is where I have it set now. I'm just waiting for calm weather for my second flight.
BTW - Did you get a motor mount with yours? What motor do you plan to use?
baddb1 is online now Find More Posts by baddb1
Old Oct 18, 2010, 07:22 AM
Jürgen Be's Avatar
Joined Oct 2008
baddb1
maybe youu did`nt read
baddb1
Jürgen
would be nice, if you can do.
Satoru
If it`s possible,you can send me the manual too.
Jürgen
Old Oct 18, 2010, 10:25 AM
ssatoru is offline
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Hi Bill, Jürgen,
I mailed scaned manual from my gmail address. Please let me know if you did not get it.
Yes, ply wood motor mount came with the kit. I have not decided on motor yet. I have Hyperion ZS3025-10 775-Kv motor and will calculate if it works with my available batteries.
Thanks.
Satoru
Old Oct 18, 2010, 12:23 PM
baddb1's Avatar
Joined Jan 2009
Thanks ssatoru, got it!!
Jurgen - Sorry, forgot about the pic, I'll grab one tonight. (You can kind of see it in my youtube video if you pause it.)
Old Oct 18, 2010, 12:58 PM
Jürgen Be's Avatar
Joined Oct 2008
Thanks Satoru,
got your mail, thanks a lot.
baddb1
I take a look at your video one more time
Jürgen
Old Oct 18, 2010, 02:52 PM
lupy is offline
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
Ssatoru: Thanks for the wing area numbers, esp since you actually measured the wings. I don't trust much else these days. Multiplex is a case in point, they list the twinstar at 650sq inches. I measured mine, the wing is only 26" on a side with a 9" width or 468sq inches. Even adding in the tail area and the wing buried in the fuse, they are still about 50 sq inches short, maybe they are counting the vertical tail???
An online conversion states 1sq dcm is 15.5 sq in , so 551sq in for the icon. I don't count the tail as it really dosn't add to lift.
If the icon can be built for the avertised weight of 88oz, it should fly just fine on 600watts. My lanier mariner flew great with an eflight 32 a 4cell pack & 12X6 APC prop. 560 watts for a 100oz RTF plane. It would loop from level, climb nice, and do resonably short take offs. I spent most of the time at 2/3 throttle or less. Unless you want to prop hang or climb straight up, more power just adds weight and hurts real world flying performance.
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 04:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 06:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 11:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 03:00 AM
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 4 Apr 24, 2010 12:47 PM
