Old Feb 14, 2011, 02:29 AM
shigetyann is offline
Find More Posts by shigetyann
shigetyann's Avatar
centrea Japan
Joined Nov 2006
I agree with AussieHoppy, from a second moment of area of view.
Of course it's also my opinion only.
shigetyann is offline Find More Posts by shigetyann
Latest blog entry: Slope Soaling
Old Feb 14, 2011, 02:40 AM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
Well mines finished , just waiting for the silicone water proofing around the cockpit to cure...mite have to fit spray rails...will see
Ian
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Feb 14, 2011, 04:11 AM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
i'm assuming the spray rails are to reduce the amount of water creeping up beside the cockpit? or to push the water downwards to increase planing earlier?
let us know how you go please Ian...
AussieHoppy is online now Find More Posts by AussieHoppy
Old Feb 14, 2011, 04:38 AM
Joined Nov 2002
both of those as well as pehaps helping to keep spray out of the prop........
Old Feb 15, 2011, 02:21 AM
Joined May 2010
i would like to know what success you have there, i'll be looking at putting the vid tx part way out on a wing, but i'd prefer to put it on the tail, which makes me just a tad nervous regarding water spray...
Old Feb 17, 2011, 05:01 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Has anyone flown theirs? Was the COG at 75mm adequate?
Chris
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Feb 17, 2011, 05:50 AM
kitaro is offline
Find More Posts by kitaro
kitaro's Avatar
Italy, Tuscany
Joined Apr 2006
kv motor adeguate for 4 or 5 lipo?
Motor 750kv 45A is ok?
Prop 10x7 tri blade
thanks for help
kitaro is offline Find More Posts by kitaro
Old Feb 18, 2011, 06:42 PM
Joined May 2010
hi guys... well I now have a reason to fibreglass the tail lol
failed attempted to maiden this morning
took my cessna up for 3 batteries worth of flying, wanted to get my thumbs working again coz it's been a while since the last time i flew, cessna flew faultlessly, as always... she's my keeper
eFlite 25
11 x 8 x 2 blade
2 x 3000mah 4S
FrSky 2.4
A bit weighty AUW, but thought i'd go the bigger packs so once 3 mistakes high i could stay up for a while and sort trimming etc
nil wind
Icon... ground checks... range check... all good... did a retracted undercarriage belly slide taxi (grass looked just a tad too high for the flimsy nose gear so i didnt even try), slid along supurbly gaining speed easily. doesnt like to turn while belly on grass obviously, but really scooted along and tracked well.
Lowered the flaps 1st stage, gradually opened the throttle, she lifted sooner than i thought with almost no elev input! kept her approx 3' off the ground gaining air speed... then she started porpoising.... more and more... the went into corkscrewing... reduced power, no improvement... wingtip touched ground, cut the throttle as she nosed in enough to flip on her back.
Only apparent damage is the main wing root is dislodged which doesnt worry me to glue back in place anyway.... and the all too thin tail section snapped clean through... easy glue fix but i'll take the time to fibreglass this time.
I think a combination of pilot error and/or poor judgement on my behalf... i should not have loaded her up on 6000mah of batteries for the maiden.
And next time i wont use flaps on my maiden- i never use flaps on maiden flights until all is trimmed, but thought with the weight i'd use first stage...
The only other questionable thing is that this is the first time I have used FrSky for RC... but I sincerely dont believe it was the radio at fault, no telemetry beeps, seemed solid.
I'm going to remove the FrSky RC Rx from the Icon & fly my trusty olde FMS P51 with it, just to make sure all is good.
One other doubt.... the manual states COG is at the servo wire groove... now to balance at this point I have my 2 x 3000mah batts probably 1/3rd into the cavity BEHIND the ply cockpit... how is everyone else finding their COG?
she's such a different plane to all else i fly, i have no idea why she initially flew straight 2-3 feet off the ground then went funky on me... perhaps ground effect masked being tail heavy at first? I dunno.... but i definately will be repairing to have another shot, unfortunately i dont have the time right now though.... it's taken this long just to get to maiden lol
cheers guys!
Old Feb 19, 2011, 04:43 PM
NY, Rochester
Joined Oct 2003
Tail
Reinforced the tail with CF rods sunk in the foam. Just Dremeled out a groove and glued them in, spackled with foam putty and will cover with white tape strips. Makes a real difference.
Chris
Old Feb 22, 2011, 04:43 PM
Gundy is offline
Find More Posts by Gundy
Blu-Core is my friend
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
Just got done reading the entire thread... lots of great info.
I got my 1800mm Icon last week and came here to find out all the goodies first, before starting the build.
Does anyone have a video of the "tail wiggle" in flight?
This will be an FPV plane. I hardly fly any LOS anymore...
I have a skywalker that has a very flimsy tail. It moves all over when testing on the bench, but flies great. I have lots of hours FPVing it "stock"
I think I will build the Icon stock for the first flight, then work on the mods.
This plane will never see water... and never see a paved runway either. I am wondering how much weight could be saved dumping the landing gear.
We will see how it flies stock first then start changing things...LOL
Later,
Gundy
Gundy is offline Find More Posts by Gundy
Old Feb 22, 2011, 05:20 PM
NY, Rochester
Joined Oct 2003
Hey Gundy, mine won't be seeing any hard surface (I hope) only water/snow, dumped the front wheel, the rear LG rod can't be removed w/o cutting open the foam.
Chris
Old Feb 24, 2011, 05:58 PM
Gundy is offline
Gundy's Avatar
La Crosse, WI
Joined Apr 2006
Chris
landing gear comes out easy... well sorta.
loosen all the set screws (3 of them)
take off the sponsins (not sure how to spell that) thanks to the poor job of gluing done in china they pop right off.
next, slide out the rod.
The front gear was easy. DRILL out the 3 screws... they only put 3 in and they stripped all three slid it all out.
Total weight 160gr
Why not take off the water rudder and put a new rod all the way to air rudder?? Done.
Much less in the hull now one servo for the rudder.
It is going to be sooooo easy to set up the wiring for the FPV, everything will be so easy to get to.
Motor test:
using supplied motor and prop
Plush 60a ESC
2 - 3s packs 4000mah to make 6s
19amps 485watts (thats with a fresh pack over 25v) ohms law works!
Need to mount the radio tonight. No on-board video until after the the test flight.
Later,
Gundy
Old Feb 24, 2011, 09:00 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
What is the total weight of your setup including batteries? With only 485 Watts I wonder how easy it will be to take off from water. I like the low current draw. What prop did you use?
Total weight 160gr
Motor test:
Plush 60a ESC
Later,
Gundy
Highfly! is offline Find More Posts by Highfly!
Old Mar 02, 2011, 01:32 PM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
Small ICON-A5(NFD s288)
Hi all.
A main topic is big ICON(A488) though, I got a good result in small ICON(s288).
Please check a video.
Thank you.
ICON A5 very best of touch and go (3 min 40 sec)
Old Mar 02, 2011, 01:52 PM
mmmdowning is offline
Find More Posts by mmmdowning
Spotsylvania, VA
Joined Nov 2005
Nice!!
mmmdowning is offline Find More Posts by mmmdowning
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 04:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 06:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 11:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 03:00 AM
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 4 Apr 24, 2010 12:47 PM
