Old Feb 08, 2011, 03:41 PM
lupy is offline
Find More Posts by lupy
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
This is basically a light 40 class plane. I fly several seaplanes , that range from 90-110 oz using a e-flight .32 on 4 cells using around 500watts max and a apc 12/6 prop. This produces about 70oz static, While not vertical monsters, they fly just fine at this power level. Unless the plane is really poorly designed, it should fly resonably with this combo. 1000 watts just seems like overkill unless the motor is a real stinker, then it would make more sense to ditch the motor; the more expensive batteries will cost more in the long run, add weight, and kill the run time.
lupy is offline Find More Posts by lupy
Old Feb 08, 2011, 03:55 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
So your flying at around 120 watts per lb.........
I will post the facts and figures next week when I get mine running
Ian
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Feb 08, 2011, 06:10 PM
Joined Nov 2002
Curiosity got the better of me , so I managed to mount the motor and speedy.......here's what my E-meter said
APC 12 x 6
Tunigy 6s x 4 AH
Tunigy 80A speedy
after 2min stabilized at
25volts
454watts
19A
this is only 82watts per Lb.......... @ 5.5Lbs
So you will be able to fly for a long time or/and wont need big lipo's like these........unless I need the nose weight
Ian
Old Feb 08, 2011, 08:49 PM
Highfly! is offline
Find More Posts by Highfly!
Highfly!'s Avatar
United States, CA, Cameron Park
Joined May 2007
Ian, are those numbers with the stock motor provided by HK?
Highfly! is offline Find More Posts by Highfly!
Old Feb 08, 2011, 08:50 PM
baddb1 is offline
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
APC 12 x 6
Tunigy 6s x 4 AH
Tunigy 80A speedy
25volts
454watts
19A
Ian
From what I saw on mine,, you'll definitely need the nose weight to get the correct CG.
baddb1 is offline Find More Posts by baddb1
Old Feb 08, 2011, 11:15 PM
Joined Nov 2002
Absotivetly , thats wot we wuz talking about..
I like going this way , high voltage , low current....at the end of the day it costs roughly the same to get the same watts....more batts but a cheaper speedy , but much less pain than with the higher Amp draw which usually means more heat in the speedy / motor...
BTW....plenty of thrust , should fly at around half throttle...
Old Feb 09, 2011, 03:30 PM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Looking at mine I wonder where you are putting the 6S battery? Got all the rods in the center. Using 2 3S lipos would work though.
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Feb 09, 2011, 04:52 PM
Joined Nov 2002
You answered your own question............
Old Feb 09, 2011, 06:13 PM
NY, Rochester
Joined Oct 2003
Figured that What about the tail, seems to be the weak spot when it comes to stability. I'm thinking of ways to reinforce the narrow tail section - any thoughts?
Chris
Old Feb 09, 2011, 10:42 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
i'll be maidening mine when weather and work are both favourable
yes the tail is weak in the area the fuselage transitions into the tail, visibly moving around when just bench testing the motor.
if the maiden flight (coming soon) is successful, i'll be fibreglassing from behind the prop to the underside of the horizontal stabilizer.
the other issue is some reports of limited tail wag in the 1800mm version. Flying LOS this shouldnt be an issue, but i'm looking at flying fpv so wag is not welcomed. if mine has wag i'll be trying to at least reduce the wag by fitting a couple of "fins" on the horiz stab tips.
i'll be maidening mine with 2 x 4S 3000mah batts, eflite 25 (on the small side i know, but i seek flight duration rather than speed) and 11 x 8 x 2 bladed prop.
mongrel, if i understand your earlier question correctly, 2 batts can be wired up in parallel or series, resulting in either double the voltage or double the mah. in my case i'll be doubling the mah (to 6000mah). I was going to make my own cable but the LHS had them on the shelf... i relate to laziness
i may have misunderstood your question, if so, please disregard
my 2 batts are positioned either side of the cockpit, part way into the compartment behind the cockpit, with the servos in the centre, giving me the cog where the "manual" states at the servo wire groove.
AussieHoppy is online now Find More Posts by AussieHoppy
Old Feb 10, 2011, 04:14 AM
NY, Rochester
Joined Oct 2003
Good ideas. I might cut a groove along the fuselage/tail transition on the left side (possibly both sides) and run a CF rod there. Good luck with your maiden!
Chris
Old Feb 10, 2011, 05:11 AM
mmmdowning is offline
Find More Posts by mmmdowning
Spotsylvania, VA
Joined Nov 2005
Well, I've got mine in and am going to start glassing on Friday. I'm thinking I should go with a motor next size up for the added wieght of the FG. I'll start showing photos soon.
mmmdowning is offline Find More Posts by mmmdowning
Old Feb 10, 2011, 01:38 PM
lupy is offline
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
I wouldn't think that the glass will add more than an ounce, maybe two at the most. I would be curious if you could fly it pre-glass to see the tail wag, then glass it and see if the tail wag is gone. The other Idea I had was to use a piece of brass tube with a sharpened edge and a drill to cut a hole from the rear that a .325" carbon tube will slip into. I did this on my second easystar, and the tail is much stiffer than stock.
Old Feb 10, 2011, 01:46 PM
Spotsylvania, VA
Joined Nov 2005
I like the idea of the rod or tube through the tail. There's a lot of good ideas for this bird.
Old Feb 10, 2011, 10:12 PM
Joined May 2010
I agree, the weight of fibreglass is almost insignificant compared to the weight of batteries for example, I doubt that'll be an issue... unless you are looking at an inch thick f'glass lay-up
I'll be maidening mine pretty much standard (no f'glass etc) to see what her characteristics are.
IMHO I really dont think fibreglassing the tail will make any change to the wag issue, but it should dramatically reduce the amount of vibration/ slop in the tail section. My reasoning is, the more i thinks about it, i reckon it's a combination of such a wide cockpit/ fuse, exacerbated with sponsons, combined with a short fuselage between motor to the tail... the wind goes around the width of the fuse then gets sucked back in to the prop... who knows what turbulance there is getting thrown back at the tail, and i reckon there'd be certains air speeds where that turbulance is getting messy- and with a short fuse, there's not enough length to allow the air to stabilize before the tail cops it...
I'm willing to try tail "fins", failing that i'll decide to either leave her as a LOS plane, or persevere and perhaps lengthen the fuse at the tail... but i'd prefer not to...
a mate of mine had suggested much the same sort of thing adding more cf inside the tail, but for me, seeing as there is already steel box in the tail (albeit in seperate pieces) i'm opting for f'glassing. Also i think even with additional cf rods, given how thin the tail is, this wont be enough to properly make the tail rigid... f'glassing is the only way to strengthen/ stiffen the tail sufficiently... my opinion only, of course
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 5 Jun 25, 2016 04:14 PM
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 03:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 05:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 10:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 02:00 AM
