Old Feb 03, 2011, 06:44 AM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
I'm telling u Mongrel, the cockpit is HUGE for an 1800 wingspan! Not only is the cockpit huge, but immediately behind the cockpit (under the wing) there's another large cavity! I'm in the midst of moving house at the moment, so I've been without internet & yet another couple of weeks before I'm online again.
Still hoping to maiden Sunday, but if not, then early next week, I'll let y'all know.
Cheers
Hoppy
AussieHoppy is online now Find More Posts by AussieHoppy
Old Feb 03, 2011, 07:17 AM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
OK thanks!! Am keen on your report!
Cheers
Mongrel
The_Mongrel is offline Find More Posts by The_Mongrel
Old Feb 03, 2011, 08:01 PM
lupy is offline
Find More Posts by lupy
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
Just checked, and these are in the HK USA warehouse, in stock. Under $200 for members with motor and servos, and it seems to qualify for $.01 shipping! I know I bad mouthed HK a few pages back for forcing us to take an unknown motor and servos with their kit, but it's pretty tempting now with no import problems, and at that price, even if the extras are junk, it's hard to resist. If I wasn't so busy these days, I would jump on one.
lupy is offline Find More Posts by lupy
Old Feb 03, 2011, 08:08 PM
Joined Dec 2007
So here is a question....
If it needs a 6S battery, can you safely make a harness to join 2 X 3S packs? Or am I asking for my packs to be deaded!!!
Old Feb 04, 2011, 01:09 AM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
It is very common to put two 3S packs in series to get a 6S pack for a model. I use 2S, 3S, 4S and 5S packs to get 6S, 7S, 8S, 9S and 10S packes.
If you are using the common Deans T connector, you can even get a series adapter ready made at the hobby shop. Or you can wire up one yourself using one female connector and two male connectors.
Obviously they have to be the same capacity and brand and it is best to use packs of the same age and levels of use.
Thomas B is offline Find More Posts by Thomas B
Old Feb 04, 2011, 01:44 AM
Joined Dec 2007
Cool! I did use the deans, but have buggered them off for the XT60 connectors
Old Feb 04, 2011, 12:28 PM
lupy is offline
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
If you use a turnigy inflight voltage monitor, you can wire a jumper to connect both 3 cell pack voltage taps into one big 6 cell tap, and watch all the cells in real time while flying. I did this with a 4 cell pack, and started to notice one cell was sagging badly way before the others. When running a 6 cell pack, I would not trust a normal LVC to protect your battery, as one low cell will be masked by the other strong cells. Otherwise, you are left flying blind and must land well before you think the battery is empty.
Old Feb 04, 2011, 02:01 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
You will need these.....then
http://www.hobbycity.com/hobbycity/s...dProduct=10264
Ian
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Feb 04, 2011, 05:11 PM
Joined Dec 2007
That happened to me yesterday! Was flying my tricopter and had a bad cell on a new battery - result = Crash!!
Old Feb 05, 2011, 08:58 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
I wonder?
As near as I can tell, the motor supplied is very close to Hobby King's KDA36-08XL, 1000 KV, which appears to be able to spin a 12X6 prop at 10,000 RPM, on 11.1 Volts. Why would you want to double that voltage to 22.2 Volts?
Of course, there may be things about the motors that come with the kit that
I do not know. Be that as it may, I will probably use 3 cells, until I learn more.
Lancer31 is offline Find More Posts by Lancer31
Old Feb 05, 2011, 02:10 PM
Joined Nov 2002
It says the motor is 500Kv.......
So 11volts X 500 = 5500 RPM.........
I dont think that will fly the plane
I will be giving mine a run up next week , but I think your gunna need 5-6s
Ian
Old Feb 08, 2011, 09:16 AM
Lancer31 is offline
Joined Jun 2005
You are quite right!
I had not looked at the literature that came with the model, but it is a 500KV motor. I may swap out the motor for the 1000KV version.
Old Feb 08, 2011, 10:34 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Whats the part number on the Turnigy monitor you have? I think I should get one, I'm getting a large collection of batteries and some seem like they are going bad.
baddb1 is online now Find More Posts by baddb1
Old Feb 08, 2011, 12:04 PM
lupy is offline
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
woops, my mistake, it's a "Quanum" http://www.hobbyking.com/hobbyking/s...dProduct=10343
it came from Hobby king, so I just assumed it was a turnigy. Mine is the earlier version that won't do amperage so I may upgrade it at some point. It seems to have resonable range. If you unplug the battery, the monitor tells you it has lost the signal, I have never lost the signal while flying. I haven't checked the voltage measuring for accuracy. but it seems resonable. It makes a beeping noise if any cell runs low, so you can just ignore it in flight most of the time. At least for bigger packs it seems like good insurance.
Old Feb 08, 2011, 03:21 PM
Joined Nov 2002
Err....why would you do that ???
The motor supplied will pull around a max of 50amps
50A X 21volts (6s)= 1050 watts
1050 watts :- 11volts (3s) = 95amps...
I think you might want to learn about Ohms law..
Ian
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 03:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 05:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 10:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 02:00 AM
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 4 Apr 24, 2010 11:47 AM
