Old Jan 17, 2011, 07:58 PM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
I always now run a tap thru any blind nuts....to clear out the glue
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Jan 17, 2011, 08:58 PM
shigetyann is offline
Find More Posts by shigetyann
shigetyann's Avatar
centrea Japan
Joined Nov 2006
I found Ebihuryaa's bulletin boad. Bellow URL is it.
Sorry Japansese only.
http://ebifrya.board.coocan.jp/?m=li...608&summary=on
Originally Posted by ssatoru View Post
Yes, plate. I was not sure its shape.
Satoru
shigetyann is offline Find More Posts by shigetyann
Latest blog entry: Slope Soaling
Old Jan 18, 2011, 02:27 PM
Joined Nov 2002
What are these "plates" used for...????
Old Jan 18, 2011, 05:54 PM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
If i'd felt resistance of any degree, i would've run a tap through
the nut let go pretty much without any sign... if i'd put a threading tap into it, the nut still would've let go, then i would have had to make a scale antenna out of the tap sticking up out of the tail
just a word of caution on the blind nuts in the tail
are the "plates" something along the lines of additional planing strakes, to help get up on top of the water?
I am kinda tempted to perhaps add to the sides of the sponsons just to see if that'll aid in the "wing tip in the water lean", but i think to stop the leaning over, the size of the foam would end up with the plane looking like a strange bi-plane lol
i'll wait until after i've flown it a few times, to see what adverse effects sponson extensions has on flight performance
AussieHoppy is offline Find More Posts by AussieHoppy
Old Jan 18, 2011, 07:02 PM
Joined Nov 2002
Wadda ya give a bloke with water on the brain....?????
A tap on the head
Old Jan 18, 2011, 09:01 PM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
I suppose that Ebifuryaa fitted plates on front edges of the sidesfloats (sidesponson, side sponsons?) not to suffer from water.
This way is another one.
As mentioned Junger Be #10 in this thread, water goes up along fuselage surface (as represented “overflowing” in #10) before planing. This causes hard to move planing. To prevent this situation Junger Be attached sidestabs or plasticstrips; show #10 pictures.
I wonder plasticstrips are needed every float.
Old Jan 19, 2011, 07:00 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
cia
Lancer31 is offline Find More Posts by Lancer31
Old Jan 19, 2011, 09:48 AM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
To Lancer31
Thanks a lot for your information and your opinions.
Using a wing-leveler, I agree with you that rate-gyro is the best, too. Nowadays rate-gyro’s weight is 30 gram or so. This means we can put smaller plane on. But none of our member wants to mount it, because of our principle; more simple and less cost. I think this judgment limits under 700 gram plane, as like smaller ICON-A5. Of course for bigger one is no problem. I’d like to mount rate-gyro for large ICON-A5. Thank you for your advice.
Also I’ve been enjoying R/C heli around two decades, electric and gas, from 450 class to .90 class (for F3C competition). So I think I know well which item is better for use. (Sorry a little bit proud )
BTW a handle name “seeker-shige or seeker” is also me, sorry too.
Those footages were edited by me. Please vote those footages good!.
Thank you.
shigetyann
Old Jan 19, 2011, 01:31 PM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Originally Posted by Lancer31 View Post
Another possibility, for maintaining stable condition, during takeoff & landing, would be a wing-leveler. Such a system could consist of a single rate-gyro, which can be switched on or off, to control the aileron servos, during takeoff & landing phases. The "magic" trick of a wing-leveler is that its gyro-axis is canted exactly 55 degrees up, with respect to the horizontal centerline of the fuselage. What that does is to respond to any gust-caused upset of the model, whether in the yaw or roll mode, and give aileron to correct it.
While it may well be necessary to add spray-rails to the bow edges, to help control how the water reacts with the hull, and maybe greater span/volume to the sponsons, a wing-leveler system has the advantage of being able to respond instantly to the problem! (Even faster than Shigetyann, and his good-flying racer friends, especially when it is 0 degrees C, at the pond)!
Nice! It will be interesting to see your results!
The problem I am seeing though is during low speed taxi, I can't seem to turn the Icon into the wind for take-off. And by wind, I mean even a 5mph wind! The wing will also dig into the water causing more of a problem in trying to turn or even accelerate to take-off speed. I assume this system will only work once the plane has started to move a bit? Or will the prop wash cause the wings to stabilize at very slow speed?
baddb1 is online now Find More Posts by baddb1
Old Jan 19, 2011, 02:12 PM
Joined Nov 2002
That rate gyro sounds like a cunning stunt (dont swap that around) will give it a go
Ian
Old Jan 19, 2011, 02:14 PM
Joined Nov 2002
Try going a bit faster , so youve got more airflow and water rudder response
Ian
Old Jan 19, 2011, 02:24 PM
baddb1's Avatar
Joined Jan 2009
Ian
Once the little bit of wind catches the wing and gets up under it, the opposing wing tip digs into the water and keeps me from going anywhere. If I try to speed up the Icon just spins around the wingtip thats in the water. I think wing sponsons would help?!
Old Jan 19, 2011, 02:32 PM
Joined Nov 2002
Try going faster when the wings are level , then you should have better control
Old Jan 19, 2011, 02:58 PM
baddb1's Avatar
Joined Jan 2009
Thanks, understood, it just takes awhile to get the wings level so speed can be increased. See ssatoru post also as he had similar problems. http://www.rcgroups.com/forums/showp...&postcount=145
Old Jan 19, 2011, 03:01 PM
Joined Nov 2002
if you watch the vids you will see how a bit of speed works
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 5 Jun 25, 2016 04:14 PM
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 03:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 05:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 10:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 02:00 AM
