ReadyMadeRC GoPro Pan & Tilt Mount Review
GoPro- pan and tilt edition? Sure! Author Kevin Martin puts the ReadyMadeRC GoPro pan and tilt mount on a ParkZone Radian to see just how well these mounts work!
Servos:Hitec HS-65HBAvailable from ReadyMadeRC
Servo Cost:$21.99 each (included with GoPro Pan/Tilt)
Rotation capability:360
Manufacturer:ReadyMadeRC
Available From:ReadyMadeRC
Price for Radian Pod:$43.99
Price for GoPro Pan/Tilt mount (with servos):$83.99
ReadyMadeRC has easily become one of the leading vendors when it comes to FPV. The man behind it all, Tim, has quickly garnished a reputation for his top of the line customer service, as well as his products- besides the "standard" FPV merchandise he sells, there are also an assortment of custom laser cut "FPV Pods" designed to fit many different airframes. From Telemasters to Radians to Easystars, Tim has a pod to fit it all.
Alongside his pod designs, Tim also cuts a variety of pan and tilt mounts for everything from ground based antenna tracker mounts to the GoPro HD camera. I went to ReadyMadeRC looking for a way to turn my trusty Parkzone Radian into a capable HD Video platform. Luckily, I went to the right place.
Radian Pod Assembly
The Radian pod and GoPro mount both arrived as small bags of laser cut ply, ready to be assembled. Also included are 4 strong neodymium magnets to ensure you're new FPV pod stays securely in place. Assembly is a breeze, and only requires some CA glue, and about an hour of your time (if you're a very meticulous builder like I am).
GoPro Pan/Tilt Assembly
The GoPro assembly is slightly more complex, and will take a little more patience in the build. Be sure to re-read the full color directions a few times before you begin if you're prone to "I can do it from here" syndrome like me.
GoPro Wiring
Using a GoPro pan and tilt mechanism is no use unless you can actually see what you are looking at. Up next- prepping the GoPro to view the Live Video-Out! For detailed instructions and help, go here. I built my wiring harness to also charge the GoPro off the receiver, so I never have to worry about running out of battery mid-flight.
Wiring you will need:
For some people, soldering a cable like this on their own can be very daunting. Luckily, ReadyMadeRC sells a similar, "ReadyMade" wiring harness. Note, this requires a separate plug if you wish to simultaneously charge the GoPro camera.
Mounting
The ReadyMadeRC pod fits snugly into the Radian canopy area, and also offers easy access beneath it for all your electronics. I later chose to fit a rubber band around the fuselage and mount, just to be sure my new pod and GoPro didn't try any sneaky escapes.
<font face='arial,helvetica' size=-2></font>
Video
Be sure to play in HD!
(Vimeo version)
The first flight with the RMRC mount
Want more videos? Click on my name above to go to my vimeo channel!
After flying with this mount well near 100 times, I absolutely love it. The pan and tilt capabilities are great, and really bring HD FPV to a different level with the ability to "look around". The servos are very fast, and are not anything near "sluggish", so quick and choppy movements on your pan control WILL translate to quick and choppy servo movement. I found that smooth movement required a steady hand and a fair amount of expo, but resulted in great, smooth FPV filming. The ReadyMadeRC pod and mount were perfect fits for my Radian, and I highly recommend them to anyone looking to add a unique capability to their GoPro-toting airplane.
Definitely! The Pod designs are extremely easy to install, and work fantastic. Besides that, they look extremely professional, and are modular- allowing you to easily modify your pod to fit a new camera.
In the end, the pan and tilt pod from ReadyMadeRC was anything but a disappointment. It is extremely functional, looks great, and is a very easy way to turn your favorite plane into a capable FPV machine. With the wide variety of different pods and camera mounts available, chances are, ReadyMadeRC has a setup to fit your needs.
Hits
  • Easy to assemble
  • Lightweight
  • Modular
  • Durable
  • Allows for 360 rotation
  • Backed by the ReadyMadeRC reputation
  • Made in the USA
Misses
  • If the main gear comes off of the pan servo due to an inadequate glue job (guilty), it can be hard to fix.
  • Does not come with the extra batteries you will need to feed your rekindled FPV addiction!
Old Sep 07, 2011, 04:12 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
Reserved for future use!
Kmart is offline Find More Posts by Kmart
Old Sep 07, 2011, 04:14 PM
banzi28 is offline
Find More Posts by banzi28
United States, WI, Eau Claire
Joined May 2011
I just got my SkySurfer and Pod from ReadyMadeRC. Plan on doing a review just like this one. Great writeup
banzi28 is offline Find More Posts by banzi28
Old Sep 07, 2011, 04:21 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
Awesome! The ReadyMadeRC pods work perfectly- I'm sure you will enjoy it!
-Kevin
Old Sep 07, 2011, 05:22 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
With what you did for the wiring... can you use video out and record it? -Tyler
flyboy321 is offline Find More Posts by flyboy321
Old Sep 07, 2011, 05:31 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
Yep! Record HD onboard, and use the video out.
-Kevin
Old Sep 07, 2011, 05:52 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Kevin Martin=kmart. All makes sense now....LOL.
Can the hero 960 do video out and HD record aswell?
gundamnitpete is offline Find More Posts by gundamnitpete
Old Sep 07, 2011, 06:06 PM
rcplanes1234 is offline
Find More Posts by rcplanes1234
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
Very good review
rcplanes1234 is offline Find More Posts by rcplanes1234
Kmart is offline
Kmart's Avatar
Joined Sep 2008
Thank you!
Pete-
I do believe it can. However, I don't recommend the 960 if you're shopping for a camera. I only ever use my gopro in R3 (720p, and 60fps) and R5 (1080P), and the 960 has neither of those functions. If you want to get a GoPro camera, just get the full one, and don't waste your money with the smaller- you will want the 60FPS or 1080 feature very soon.
-Kevin
Old Sep 07, 2011, 06:12 PM
Team White Llama!
I already bought the 960 for making motorcycle videos (helmet cam!), so I was just thinking of double duty.
However I've had so much fun with the first, that I plan on getting a 1080p aswell
Old Sep 07, 2011, 06:19 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
Oh yeah- I use my GoPro for just about everything. If only Tim could make a pod for everything I do...
-Kevin
Old Sep 07, 2011, 11:05 PM
dee-grose is offline
Find More Posts by dee-grose
Wishing I was at Torrey Pines
dee-grose's Avatar
Tanner, Alabama
Joined Oct 2003
Kevin,
How much does the mount and camera weigh? Did you have any balance issues since all of that gear sits ahead of the CG?
Andy
dee-grose is offline Find More Posts by dee-grose
Old Sep 07, 2011, 11:43 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
Andy, good question! In my FPV conversion, my Radian lost almost all of its original identity outside of the airframe (out of personal preference, not necessity). Because FPV is almost always a custom addition, there isn't really a definite answer. However, I always flew with a 3s 2600mAh battery, and later a bigger motor up front (just for crazier verticals, the stock still works fine), and my Radian flew great. I suggest mounting the video transmitter right behind to aid in balance, though.
Kevin
Old Sep 07, 2011, 11:47 PM
Kmart is offline
Kmart's Avatar
Joined Sep 2008
A quick trip on the scale says 205g for GoPro and mount.
Kevin
Old Sep 08, 2011, 07:21 AM
dee-grose's Avatar
Tanner, Alabama
Joined Oct 2003
OK, I was just curious what had to be moved around to make it balance. I've got a Radian and one day hope to be able to go FPV with it. That mount looks so clean and well-done.
Oh yeah, those videos rock...absolutely amazing scenery.
Andy
Discussion Pan&Tilt for GoPro HD reqeust... zaguruinzasky FPV Talk 676 Feb 13, 2011 11:15 PM
New Product Hobby King has a new Fiberglass Pan-Tilt Camera Mount for FPV CrashingDutchman FPV Talk 79 Nov 04, 2010 10:03 AM
Alert *SOLD* ReadyMadeRC Pan & Tilt For Sale *SOLD* pedantik FPV Talk 9 May 21, 2010 07:00 AM
Question cheap 180 pan/tilt mount kyle7119 FPV Talk 29 Apr 20, 2010 06:15 AM
New Product ReadyMadeRC Pan/Tilt System for Antenna Trackers FPV Bill FPV Talk 73 Nov 25, 2009 03:36 PM
