Old May 18, 2010, 05:21 PM
rocketmagnet is offline
Find More Posts by rocketmagnet
AAaaaaaahhhh!
rocketmagnet's Avatar
London
Joined May 2010
Airfoil for maximum lift
Hi all
I'm looking for an airfoil which will provide as much lift as possible, especially at low speeds. I don't care about efficiency, drag, or L/D. I just want lift.
As I understand it, this would be a heavily cambered, thick wing flying at an AoA of 45º. Am I right?
If so, where might I find such an airfoil?
Many thanks
Hugo
rocketmagnet is offline Find More Posts by rocketmagnet
Old May 18, 2010, 06:18 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Well first off if you have enough power to pull a wing through the air at 45 degrees you don't really NEED a wing since the engine will have enough power to hold the plane up on it's own.
If you're looking for a wing to carry a payload in a larger model then the Selig 1233 designed for the SAE payload competitions would be the way to go. If it's for a smaller and slower model then some of the higher camber airfoils used in free flight would be better.
To point you in the right direction we'd need more information about what the model size and weight would be.
Also you may THINK you don't need to worry about all those other things but you do. If you create too much drag your motor or engine won't produce the airspeed required to remain aloft. And while lots of camber is good if you go much past 6 to 7% camber then the airfoil tends to suffer from separation bubble issues and again you suddenly need a lot more power to hold it up in the air. And the best solution to getting lots of lift to allow for slow flight is to give the model more wing area and lighten the wing loading. Airfoil ability can help but when the chips are down the biggest wing flys the slowest.
Oh, one more factor. The Selig 1233 is a good heavy lift airfoil, or a good slow speed airfoil, but it has to be fabricated to a high degree of accuracy. It's not an airfoil you can use with open structure and cover it. The section is critical as to shape far more than many other airfoils. So this means you need to make the wing using more complex methods that will ensure the high degree of accuracy that the airfoil requires. And it's not just THAT airfoil. Lots of the better performers require the same level of accuracy to achieve the promised performance. So again without knowing what you're trying to do and given the odd focus of the request it's hard to say what you should be using and why.
BMatthews is online now Find More Posts by BMatthews
Old May 19, 2010, 03:18 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Also maximum lift occurs nearer 15 Deg than 45 Deg.. As noted previously planes that fly at very high alpha are using thrust from their props to supplement lift from the wings.. You dont see gliders flying with 45 Deg AoA
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old May 19, 2010, 04:04 AM
AAaaaaaahhhh!
London
Joined May 2010
But surely that's because normal wings, designed for normal flight will stall at about 15º-25º. Wouldn't an airfoil specifically designed to work at 45º give the most lift?
Old May 19, 2010, 04:19 AM
AAaaaaaahhhh!
London
Joined May 2010
Also you may THINK you don't need to worry about all those other things but you do. If you create too much drag your motor or engine won't produce the airspeed required to remain aloft. ... Airfoil ability can help but when the chips are down the biggest wing flys the slowest.
OK, I guess I should be more specific. I'm just curious about making a plane to investigate the slowest possible landing. I don't care about flying, or acrobatics or anything, just launching it from my hand, and seeing it land slowly a few seconds later.
I'm thinking about 1m span, 500g weight (including payload).
I think that a large problem will be maintaining control at this slow speed.
Hugo
Old May 19, 2010, 04:22 AM
realtimerecon is online now
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
This floats like a feather
realtimerecon is online now Find More Posts by realtimerecon
Old May 19, 2010, 04:31 AM
AAaaaaaahhhh!
London
Joined May 2010
Haha. A helicopter wasn't quite what I had in mind.
Old May 19, 2010, 06:03 AM
Aberdeen
Joined Mar 2006
At model airplane Re numbers maximum lift usually occurs at 12-15 Deg AoA.. 25 Deg would be stalled unless some very fancy tricks were used such as slats, boundary layer control etc.
As for designing a model airfoil to stall in excess of 45 Deg... First you would need to design new air
Steve
Old May 19, 2010, 06:10 AM
Aberdeen
Joined Mar 2006
Hugo
In that case you should reduce your weight? If all you are interested in is gliding slowly from a hand launch then why so heavy?.. What do you need a payload for if all you want is to hand launch and glide for a few seconds?
It would be very easy to build a 1m span model down to 50g or so.. You would then have a plane that would fly at walking pace, no fancy tricks required. As mentioned in the first reply; by far the most significant variable in minimum flying speed is wing loading, especially when you get down to very low Re numbers.
Providing the wing is not stalled control should be easy enough... But why if you just want to glide for a few seconds would you want 'control' just make the glider freeflight and save the added cost/weight of RC gear..
Steve
Old May 19, 2010, 07:09 AM
AAaaaaaahhhh!
London
Joined May 2010
OK, I know that reducing weight is more important. However, getting back to the original question ....
If one had to design an airfoil just to produce maximum lift, forgetting about everything else, what would it look like ?
I assume it would be quite thick with a lot of camber (After all, aren't slats and flaps there to basically increase the effective camber?). But what's the maximum camber? Cambering the wing into a tube is probably too much.
e
My guess would be about 45º of camber from the LE to the TE.
Hugo
Hugo
Old May 19, 2010, 07:15 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
e
Hugo
Hugo
Easiest way to get more lift out of a wing is to make it go faster
At lower speeds, you can trade lift for drag. fully flapped wings with slats are probably as good as it gets.
Don't fly at any higher speed worth a damn though.
You have to work out what you are really trying to achieve.
Old May 19, 2010, 07:33 AM
AAaaaaaahhhh!
London
Joined May 2010
I realise what I'm asking is unusual, and you're all trying to help me by suggesting things that are good advice for building normal practical aircraft. However, what I'd really like is some insight to the orignal question.
What I'm trying to achieve is this:
Lift: I want the maximum
Drag: Don't care
L/D: Don't care
Max flying speed: Don't care
Suitability for practical aircraft: Don't care
Efficiency: Don't care
Weight: Irrelevant to the question
Wing area: Irrelevant to the question
Hugo
Old May 19, 2010, 07:50 AM
Aberdeen
Joined Mar 2006
Then the Selig 1233 as suggested in the first reply is possibly a good choice. But it very much depends on how slow you are going and the size of the model. At very low Re (e.g .walking speed flight on small/medium size models) then a simple curved plate airfoil of minimal thickness will work as good as anything. The thick airfoils you see used on large scale models and full size planes dont work at all well on very slow flying models.
You say weight and wing area are irrelevant but nothing could be further from the truth. Weight and wing area determine wing loading and wing loading largely dictates flying speed. Flying speed and size dictate Re number and Re number is critical in deciding what type of airfoil will work best.
Regarding camber (i.e. the degree of 'curve' of the airfoil centre line)....You cant just add more camber to give more lift because there very soon comes a point when the air wont follow the curve of the airfoil and stall occurs. This comes much sooner at model Re numbers than at full size... Also forget 45 Deg angle of attack, the wing will stall long before that regardless of airfoil.
Steve
Old May 19, 2010, 08:23 AM
HerkS is online now
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Excessive camber works against your objectives - requiring increased downforce on the tail to offset the pitching moment of the airfoil. Your concept about high angle of attack misses the fact that your model would develop a very high rate of sink - would not land softly
The most reasonable approach to high lift at high angle of attack is a full span leading edge slat added to a good airfoil such as have been suggested.
HerkS is online now Find More Posts by HerkS
Old May 19, 2010, 09:46 AM
kcaldwel is offline
Find More Posts by kcaldwel
“emancipatory catastrophism”
kcaldwel's Avatar
Joined Jan 2007
kcaldwel is offline Find More Posts by kcaldwel
Question Airfoil Design and Lift kevin matthews Free Flight 11 May 04, 2010 04:29 AM
Discussion high lift airfoil j j b Chit Chat 4 Feb 18, 2010 03:13 PM
Discussion how to calculate lift on airfoil b-29er Modeling Science 4 Oct 08, 2009 06:28 PM
Question High lift airfoil b-29er Fuel Plane Talk 8 Oct 05, 2009 03:03 PM
Discussion Possible to calculate maximum lift? oilman2 Electric Plane Talk 3 Sep 12, 2009 11:22 AM
