Old Jul 19, 2010, 09:57 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Originally Posted by ty_horn View Post
I did not clip my wings. I did not add anything to my rudder... I just cut it at what seemed like a normal rudder size :-)
I took no dihedral out.
I actually did nothing but cut the elevator and rudder out (maybe 1 3/4 inches wide) but that is a guess. I am confident enough to fly along at half throttle and roll her over to inverted and fly 10 ft off of the deck like that. When I tell her to turn, she flips right around if I want.
Pretty convincing. I just converted mine to RE controls, so I will try her in the morning if the weather is good. I gave her big throws and big expo, so I am hoping it isnt too much. I will dial her in once I am sure I have enough control to keep her over the park and out of the trees.
I checked mine, and the AUW is 19.2 oz. Going RE did nto seem to add any weight since I just reconfigured the existing servo and added a fiberglass rod to link the elevator.
Tom, what is yours?
Edit, found it, 15.5 oz. Good guessing, Tom 3.7 oz heavier.
Derek_S is offline Find More Posts by Derek_S
Old Jul 20, 2010, 04:46 AM
ty_horn is offline
Find More Posts by ty_horn
Philippians 4:13
Seward, NE
Joined Nov 2006
I don't feel that this thing cares if you add weight to it or not.
ty_horn is offline Find More Posts by ty_horn
Old Jul 20, 2010, 07:39 AM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
The plot thickens..
She flies great at slow speeds now but not as well at higher speed. Quid pro quo?
Anyways, she is ready now some more casual flying! My next one might have big tailerons for some higher speed action...
Old Jul 20, 2010, 10:41 AM
AirmanAirhead is offline
Find More Posts by AirmanAirhead
AirmanAirhead's Avatar
Novato, CA
Joined Dec 2008
Titan Conversion Sea Plane
Somebody posted a question a while back who will try to make one of these a Sea Plane? Well even when that question was asked I was working on this. After a lot of testing and failure with the bottom. It turned out pretty good.
Jeff
Titan Sea Plane.mp4 (1 min 35 sec)
AirmanAirhead is offline Find More Posts by AirmanAirhead
Old Jul 20, 2010, 10:51 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
It looks like it flies great... and the motor position seems to eliminate any problems with water hitting the prop. Would love to see some close-up shots of the plane.
warhead_71 is offline Find More Posts by warhead_71
Old Jul 20, 2010, 10:52 AM
Novato, CA
Joined Dec 2008
Thanks, I just had the first successful flight this AM so I ran out of time to provide close ups which I will. It's now time to get used to it!!
AA
Old Jul 20, 2010, 11:02 AM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
AA
Awesome job I would love to see some pics too
rcrich is offline Find More Posts by rcrich
Old Jul 20, 2010, 11:10 AM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
AA - I saw u guys at 37 flying this morning!!
I think I have a pic of the plane if you want me to post it.
captaingeek is offline Find More Posts by captaingeek
Old Jul 20, 2010, 12:33 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
After watching the video, it seems like you don't even need the wingtip floats -- they never touched the water except for when you were doing it on purpose. It looks like the fuselage has sponsons as well... the side-extensions on the fuselage above the step. That ought to be sufficient considering the amount of dihedral the wings have.
Now I know how I'll do mine
Old Jul 20, 2010, 02:52 PM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
LiPo charged & motor mounted and ESC programmed . I have to check the current draw at WOT vs n such but going well ..
except now it is raining . LOL
Prime_8 is offline Find More Posts by Prime_8
Old Jul 20, 2010, 08:07 PM
Novato, CA
Joined Dec 2008
I'm not sure about not having the wing tip floats, with out them, on a quick turn and or taxi, the plane will dip one way or the other and the elevator will catch a bit on the very end. I think the floats make it handle better in sliding turns. You could try it without, and I might. Still a bit more testing is needed.
Old Jul 20, 2010, 10:09 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
cool AA . looks great to me .
only thing i wonder is could the wing tip floats be thinner and still work ?
- i was to excited about finaly getting my motor N stuff i for got to say coolness for a sea plane . LOL
:: mostly installed , still have to test motor draw in amps at wot . as my power setup(lipo&esc) provides 30 a , and motor is 24 a peak , for 60 sec .
so far the few test blasts never went over 12a , but blew everything off my desk and table across the room . I think it is about as good as my last .25 slimer. LOL
I'll put the TP props on once i get propsaver on . that gray prop locks to the nut , so i tested it first .
i can't belive how small the esc is . LOL my old boat ESC from a few years back ins a big Alu chunk. LOL
ps video of my bronco test flights & my micro Jetset that i use between charges .
http://www.rcgroups.com/forums/showp...0&postcount=13
Old Jul 20, 2010, 11:46 PM
Novato, CA
Joined Dec 2008
I want to reconfigure the wing tip floats. When I first started I was not sure what the problem was because it would not release from the water. The problem was not the wing tip floats, but the bottom has to have considerable foam added to create the right step, buoyancy and clearance for the wings. My current wing tip floats are way to funky. But I'll tell you, the first moment it finally lifted off was quite a thrill!
AA
Old Jul 21, 2010, 01:42 AM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
to aid in release , you can put a tunnel down center of main hull .
show me pic of hull area .
I used to make racing hydros , after i gave up flying slimers .
also micro steps can help if they reach high enough to alow air to get down in them. ( see realy fast boat greenpeace had that sunk ) .
should not need much surface area on tips. i can see bouancy / stabillity help , but small tip floats , or mid wing floats shoudl be all that is needed .
. i do really like how it is now , looks like a jet in the air.
Old Jul 21, 2010, 08:53 AM
Novato, CA
Joined Dec 2008
Prime 8,
Thanks for the tips. This little project is like so many proto-types, once you get it figured out, you would like to start over again and not have so much trial and error on the first one. I'm sure I could lighten this quite a bit by changing the bottom a bit which is like a big ski of sorts. I did hollow out the inner core to help save some weight and your tunnel idea is a helpful idea to consider. One issue I had to deal with was that originally the low wings would catch water before I could get up on the step. Only after I layered the bottom with thick foam to raise everything up did I have success. It does handle pretty nice on the water and like I said, I'm going to go with much smaller streamlined wing floats.
Thanks again,
Jeff
Build Log Air Hogs Titan (chuck glider) conversion Dash 9 Foamies (Scratchbuilt) 139 Jan 18, 2016 03:52 AM
Discussion AIR HOGS TITAN GLIDER to RC 'FUNJET' CONVERSION SNice Foamies (Kits) 65 Aug 04, 2012 11:57 AM
Discussion AIR HOGS TITAN wildhawk conversion Archer S Electric Plane Talk 10 May 17, 2010 08:28 PM
Air Hogs RC Titan Frequency 2 abdulf Electric Plane Talk 6 Jan 01, 2008 11:25 PM
4 fan air hogs rc TITAN igo Foamies (Kits) 1 Oct 19, 2004 07:38 PM
