LOL
open space is not so big , and with some scrap lenghts of spruce spar used to strenghthen it. i'm waitting on mail , i need the servos alone , to finalize control linkage for the rudders & ellivator . and the motor for the motor pod . - problem is now i'm killing time with side tracked things , like funky landing gear i test glued in place (love hot glue ) . i figure a rolling take-off would be best . but i want foam wheels . and my package to arrive ( was shipped on 3rd , so now it's in customs i bet . ) yeah i got the deal , motor and ESC combo. ( out of stock now LOL ) . it's the same motor Vyas got , and flys his new foamy with , but i have 7 and 8 inch props , nothing smaller . but should be ok . ? prop save for a pusher , possible ? - put it on backward , only saves from ground strike . I'm only concerned with it a large prop that will come near ground . |
![]() somthing stinks like ![]() ![]()
Prime I have the grayson v3 for my scratchbuilt su 37 and it goes BOY does it go and i have a AUW of 450 gm and that motor just makes it move!!! on this plane that motor is OVER FREEAAKING KILL the wings would just pop out and float down any 24 g motor would do it and teh combos from hobby king are great
such as this one http://www.hobbyking.com/hobbyking/s...047_Prop_Combo more than enough power Quote:
Check out my maiden flight video linked at the bottom of post 159. |
i was thinking of the G V3 . but i decide to get same motor you see Vyas flying his f22 with, a 2409 12t.
so i know it's size ( dimensions ), i finished roughing in the mount / pod . it has aft air vents & a vent / wire path for motor wires. jus messing round. ![]() ( pod is/was part of chopped tail section ) i will have a watt meter & 3 props to test , 2 8x4 versions , and a 7x6e but i wish / hope my LHS has some cheap foam landing gear. i think i want to avoid hand launch.. but that new motor pod may make hand launch easier ? . - i do want gear as an option. - now just need package to arrive . :: oh and i scrapped hiding the inkage and wil hot glue servos into wing near boom . |
Hey Guys, I'm new to this thread. I'm working with a Titan with an 1100 KV motor mounted on a pylon, and it flies pretty decent. I'm toying with the idea of trimming the wings at the transition point as mention in the the earliest posts. What's the current verdict on trimming the wings back?
Also, I've experimented making this a SeaPlane, but I'm having problems getting the step right but I've not given up yet. Any feedback? |
I think I'd slim down that pod if it were me... keeping as little blockage of the air flow into the prop as possible. You can always do that after a trial flight, of course. When you say you gave it right thrust. When looking from the rear, is the motor thrust line pointed to the right of the plane centerline? If so, the plane will probably turn LEFT, since it's a pusher. It will try to rotate about the CG, which is in front of the motor (just the opposite from a tractor motor up front). I just put my pusher motor aligned straight ahead, and it flies fine that way with no offset at all. Good luck with the maiden flight! |
Thanks Tom .
I'll flatten it out , I can use washers to change the thrust line . you answerd my other question , i should have break on . if prop is vertical when break is on , wil teh esc try to hold it vert when it hits ground . also the front part of motor pod is near COG top , so i let it saty a bit chubby for now for grip . I will prolly make wire skids for belly to protect prop if it is an issue but the prop saver should help. the 7 inch prop shoudl be even with belly . but the big 8's will be lower of course. i liked the look of my quick rigged test gear . i just mocked up for placement ideas. but i may jut do one belly wheel & skids. i had a gas plane with one big dubro on/ in belly and skids , it could touch n go just fiine . as i don't plan on in board servos now , i can build much the same rig . all that in time , i just what it flying first . LOL this setup cries for a trike gear. |
FWIW, I haven't had much luck with prop savers on higher revving motors... prop isn't held centered and balanced good enough. I grass land many planes with collet prop adaptors and ESC brake set to OFF... never once broke a prop during a normal landing (knock on grass )
ah well thats , even better to know , because i was figuring the torq and power of this wee motor seems over what a few elastics ( o rings ) would provide . (actualy i use cut medical tube segments )
the wing is strong enough for dicus like toss ... but that is not a good way to maiden & trim . LOL ~ unexpected flat spin anyone. now i wait for the motor and power systems . I just hope i can program, the meg 8 . i have a few sets of walk threws , so should be ok . "knock on grass " lol . i will have to make do for a bit after that, car is due for a timing belt change in a few months and that can be big $$$ . |
| Thread Tools | |
| Build Log Air Hogs Titan (chuck glider) conversion | Dash 9 | Foamies (Scratchbuilt) | 128 | Oct 14, 2012 12:38 AM |
| Discussion AIR HOGS TITAN GLIDER to RC 'FUNJET' CONVERSION | SNice | Foamies (Kits) | 65 | Aug 04, 2012 11:57 AM |
| Discussion AIR HOGS TITAN wildhawk conversion | Archer S | Electric Plane Talk | 10 | May 17, 2010 08:28 PM |
| Air Hogs RC Titan Frequency 2 | abdulf | Electric Plane Talk | 6 | Jan 01, 2008 11:25 PM |
| 4 fan air hogs rc TITAN | igo | Foamies (Kits) | 1 | Oct 19, 2004 07:38 PM |
