F-15 or/and F-18 (both will be pusher jet), some Israeli fighter jets like Kfir, or even Rafale... I do have extra pair of wing from one of the Titan glider, maybe a Northrop flying wing: http://www.richard-seaman.com/Aircra...FlyingWing.jpg Already got some Depron and Blucor in the garage, looking forward to more warbirds, or even some 3D plane conversion. |
Don't get a dedicated air brush compressor. As you said, they are way over-priced for what they cost. I picked up a 2 gal. "generic" compressor with regulated supply pressure for less money, and it is not only more than adequate for airbrush use, it's big enough to use for other things like pumping up a car tire, etc.
SNice,
Harbor freight had a compressor for airbrush, around $69.00 for 1/8 HP. They have another 1/5 HP airbrush compressor for $89.00. This one has an airbrush with it. Still a bit of money, but mine was priced $135.00 10 years ago! I so get the airplanes smell nice thing, got to love Talc Baby Powder. I got some foot powder once, P.U. to that. The plastic bottle thing is cool in it's own right and will still be used when possible around here, vacuum table or not!
Had to abort the Maiden this weekend. Had it out at the field yesterday. Did receive some oohs and aahs and a few laughs from the gassers. Was ready to taxi her out to the runway and the Master Warning Light came on. Back to the hangar. The retracts were loose and getting wobbly, probably because I hot glued them in the pockets and it was 100 degrees outside degrading the glue.
Spent some time today making a balsa crib and then applied 30 min.epoxy. Pretty darn stiff now. Note to self: Don't get epoxy inside the gear. Had to exercise the retracts up and down several times so they would move freely. El stupido ! Then ,I noticed that after placing a 11v 2200mah battery in the cabin, it was going to be tail heavy from the get-go. Was sitting there on the table doing a wheelie. So, I added ballast, yes, weight, in the nose by making holes with my soldering gun and inserting a couple of aa batteries. I think she has ample thrust. Ran up the e-flight 66's. Good power. At this point, I'm not 100% certain where the CG should actually be. Lifted her with my fingers about 1.5 inches from the leading edge. Seems okay. Drove her around on the driveway again and she taxi's nicely. Turns on a dime too So, I'll have to wait till next weekend as I'm traveling until then although I have short window Tuesday night at our club meeting. We'll see. "Triple 7 Sierra Lima Heavy" is as ready as she's going to get. Keep you posted on the progress and fate. Cheer's Hawk |
The CG is discussed elsewhere in this thread... a search on "CG" should locate the posts. Good luck on the maiden! |
Thanks Tom,
I'll take another look at it. I placed the mains at a point where I thought the wing would handle them. Much more toward the trailing adge and I'm not sure I could have mounted them at all. They are in the center of the wing. Good thing is I can remove some of the fore ballast. |
+1 to what Tom Frank said about the CG location -- it should be about the same as the stock glider as long as you have not modified the wing sweep.
Hawk - Sorry to hear about your maiden troubles -- but better safe than sorry! You will get her up! Don't pay any attention to the "haters"! Thanks to all for the air-compressor suggestions -- I will definitely look up all the leads you guys gave me! As for the Baby Powder reference -- it is part of Freddie B's paint technique. Here is a link to the post where I first learned of it: http://www.rcgroups.com/forums/showp...&postcount=211 The thunderbird 70mm EDF titan is ready for maiden. Hopefully I will be able to get her up soon!
SNice,
Love your fleet and video. The first EDF flew good with no wings or tail? (LOL ), But really your crew chief and his helper sure bring back some good memories of my two boys at that age (25+ years ago ) Enjoy themi it goes by so fast I can tell you are a great Daddy by the way they interact with you and the fleet in the video!Fred
Thanks Freddie B!
Yeah -- I thought I added an annotation about that V1 EDF -- that is what is left of it! lol -- It was dismantled due to lack of performance!lol ...So I did the maiden this morning and it was a complete success!!! Super stable, highly maneuverable, and a very wide speed envelope. The stall is pretty tame-- she just drops a wingtip and then the nose - no nasty spins or spirals. Recovery is pretty quick given enough altitude. In flight behavior was stable but extremely responsive -- After the first toss, I had to dial down the throws because she was a bit too twitchy. I still need to lock in the correct throws - perhaps I will reference similarly sized foamy EDF's. The "twitchyness" was amplified by the fact that my thumbs were shaking the entire flight! Other than that - she behaved like an arrow -- went exactly where the nose was pointed - possibly due to the anhedral in the tail (???). Launch: Uneventful -- didn't have to throw her nearly as hard as I thought I would. Gave her a firm toss at about 20deg and 60% throttle -- off she went -- no dip-- she was immediately on step. Landing: This was a bit of a challenge! With flaps down, it took me 3 landing attempts to get her back to earth! The glide slope was so shallow that It took forever to get her down. I had to fly her down to the ground. Normally on my approach (with other planes), I hold the elavator, and use the throttle to control my descent....this plane would not land! So I'm very happy with maiden performance. Trim was perfect -- all surfaces at 0 deflection - just need to lock in the control throws. Got video of the maiden and will post once I have a chance to edit... Here are a few stats from the completed model: AUW: 34.4oz (w/ 2650mah 3S lipo) ESC: 60A LIPO: 2650mah 3S 30C MOTOR/FAN: 3900KV/70mm WS: 32.5" (approx) Hawk - you should be fine with regard to weight!!! Those twins should supply more than enough power! I rarely went above 60% throttle on my maiden and performance was still excellent. Definitely move your CG back -- mine was about 4.75" behind the leading edge root (stock glider location). |
| Thread Tools | |
| Build Log Air Hogs Titan (chuck glider) conversion | Dash 9 | Foamies (Scratchbuilt) | 128 | Oct 14, 2012 12:38 AM |
| Discussion AIR HOGS TITAN GLIDER to RC 'FUNJET' CONVERSION | SNice | Foamies (Kits) | 65 | Aug 04, 2012 11:57 AM |
| Discussion AIR HOGS TITAN wildhawk conversion | Archer S | Electric Plane Talk | 10 | May 17, 2010 08:28 PM |
| Air Hogs RC Titan Frequency 2 | abdulf | Electric Plane Talk | 6 | Jan 01, 2008 11:25 PM |
| 4 fan air hogs rc TITAN | igo | Foamies (Kits) | 1 | Oct 19, 2004 07:38 PM |
