Old Jun 04, 2010, 08:08 AM
(Jo)Hannes is offline
Find More Posts by (Jo)Hannes
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
;-) thought i would have more effect on the elevator... just pulled to less...
...and there was a mixer throttle->depth programmed from a former model
But, no problem, i could just start again after i had found the prop....
(Jo)Hannes is offline Find More Posts by (Jo)Hannes
Old Jun 04, 2010, 08:50 AM
Ikarus2000 is offline
Find More Posts by Ikarus2000
South Africa
Impressive crash tolerance!
Ikarus2000 is offline Find More Posts by Ikarus2000
Old Jun 04, 2010, 08:58 AM
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
Jepp, thats what i like about small, light EPP-planes
some images from yesterday (still with old prop)
Old Jun 04, 2010, 09:03 AM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
Ailerons definitely need work on mine. I don't like the set up at all, and not sure if changing the side that control horns are on will help all that much. Hinges are really stiff as well, so that should help somewhat. Tempted to put balsa control surfaces on and tape hinges. I would like to change how the servo is set up as well, but just using a bit stiffer wire might help a bit
discostu956 is offline Find More Posts by discostu956
Old Jun 04, 2010, 10:44 AM
DrZiplok is offline
Find More Posts by DrZiplok
USA, CA, San Francisco
Joined Feb 2004
FWIW, it made a world of difference for mine. The wire is kinda OK in that the slop is all applied to the down-going aileron, which I don't care so much about. Stiffer wire wouldn't help the stock setup, and it might be challenging to get it to bend so sharply.
What would have helped the original setup would have been tubing with a finer ID and control surface horns with holes the right size.
= Mike
DrZiplok is offline Find More Posts by DrZiplok
Old Jun 04, 2010, 09:48 PM
Is my CG correct?
Wollongong, Aus
Joined Sep 2009
Cheers for that Dr. Will have a play with it. Still tempted to make balsa control surfaces, but will see how freeing them up helps
Old Jun 05, 2010, 03:24 AM
junglegym is offline
Find More Posts by junglegym
3 Strykers,your out !
junglegym's Avatar
Lurking Melbourne Australia
Joined Apr 2008
Hk Minswift , New MPX Merlin size comparison .
Someone asked me whether the HK Miniswift was the same size or a copy of the MPX Merlin.
No, M/Swift is smaller .
junglegym is offline Find More Posts by junglegym
Old Jun 05, 2010, 03:15 PM
aeromaniac is offline
Find More Posts by aeromaniac
Glow 😡 no no no
Australia, SA, Evanston Park
Joined Mar 2010
Thanks gym nice to see the size difference.
aeromaniac is offline Find More Posts by aeromaniac
Old Jun 05, 2010, 06:27 PM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
anyone else noticed that the swift tailplane seems oversize for the mains? I think I might copy the V-Tail version that was done with my spare set. Or even maybe convert the original.
BulletMaster is offline Find More Posts by BulletMaster
Old Jun 06, 2010, 08:36 AM
Chillaxin dude!
Joined Apr 2003
flew mine today for the first time is quite a bit of wind... absolute pearler! With rudder mixed into aileron, turns great! Very happy and a couple of observers were quite impressed with the performance from such a cheap model.
Old Jun 06, 2010, 08:51 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Caught up with JJ today and noticed his was doing the motor wire twisting just caught it in time ,lucky he had some medium cyno and a long thin applicator and drizled some around the motor mount plate from inside the cockpit, cant believe they use such a crap adhesive, be warned guys this looks like being a common fault.
I find I dont have to use the rudder and a 450Mah 2sp works well for ballance.
olmod is offline Find More Posts by olmod
Old Jun 06, 2010, 04:08 PM
shorty707 is offline
Find More Posts by shorty707
Joined May 2010
which cam did u use for these pics?? a little off topic sorry
shorty707 is offline Find More Posts by shorty707
Old Jun 06, 2010, 04:21 PM
DrZiplok is offline
Joined Feb 2004
EXIF data says Canon EOS 300D.
= Mike
Old Jun 07, 2010, 02:28 AM
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
= Mike
Then this should be it. Was the cam of a frind, don't know exactly, but definitely a Canon EOS
BTW. we did some even better pics with a NIKON D70 on the weekend...
Old Jun 07, 2010, 08:31 AM
jaskel is offline
Find More Posts by jaskel
WHAT U LOOKIN AT!
jaskel's Avatar
Penrith, NSW, Australia
Joined Dec 2005
this little model looks cool! might be a good little street flyer! Im hanging to see some more pics and videos guys!
jaskel is offline Find More Posts by jaskel
New Product Hobbyking Mini Swift R/C EPP Glider Plug-n-Fly with crash-kit CrashingDutchman Foamies (Kits) 273 Aug 07, 2013 02:30 PM
New Product New Hobby King Mini Swift R/C EPP Glider Plug-n-Fly w/ crash-kit A-10_Flyer Scratchbuilt Indoor and Micro Models 3 May 09, 2010 08:56 PM
Build Log 20" Mini Swift Repair log zedz Flying Wings 0 Apr 25, 2010 06:09 PM
Discussion ms mini swift monster mini Flying Wings 3 Apr 11, 2010 03:46 AM
