Old Feb 03, 2013, 08:11 PM
Fred_L is offline
Find More Posts by Fred_L
If it flies - it's good
Fred_L's Avatar
Australia, NSW, Sydney
Joined Sep 2003
As an experiment, I put one of these low cost 3-axis stabilisers in my Mini Switft, hoping to make it more stable in windy conditions.
http://www.hobbyking.com/hobbyking/s...rch=9171000102
It sort of worked. On the first flight I had the yaw gain set too high and it had a permanent tail waggle as it it oscillated in yaw. I reduced the gain and it was better, but I found a few other things that weren't great. Firstly it adds weight (almost 10%) in a very light aircraft, plus mounting it under the canopy caused a large CG shift forward requiring full up elevator trim. For some reason the already slow roll rate seemed to have reduced too. So in summary it works and in a larger aircraft where the added weight might be less of an issue it would be OK. But I ended up removing it from the Mini-Swift.
I see that there is now a version 2 of this unit. The V2 supports delta wings and v-tails.
Fred_L is offline Find More Posts by Fred_L
Old Feb 03, 2013, 09:39 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
I've heard several reports that using the HK item reduced throws substantially with no easy fix. I have one of those in my parts bin, but just haven't had a plane I felt could make use of it lately, that made me want to take it out of the package, install it, and play around with it..
tracknoob is offline Find More Posts by tracknoob
Old Feb 03, 2013, 10:50 PM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Ive been eyeballing that stabilizer, seems cheap enough and light enough, but that doesnt make it work. Thanks 4 the info. I alwys flew in the wind because it always seems to be windy ad the mswift does pretty well in the wind, I always thought.
kenstogie is offline Find More Posts by kenstogie
Old Feb 03, 2013, 11:29 PM
ChinoDiablo is offline
Find More Posts by ChinoDiablo
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
United States, VA, Hamilton
Joined Jul 2012
Mini Swift, V2
Did my mods on my new MS.
Used a lot of good ideas here on the thread and then some of my own.
1) used hinge tape on canopy to lock it down. No more rubberbands.
2) cut slot under wing for 500mah 2s bat
3) carved relief out of nose to fit AX1806 2500kv motor
4) kept original firewall but bolstered it with gorilla glue from behind and then a wooden cross piece that spans the width of the firewall for which the screw from the motor mount can bite into. Seems pretty strong but angled down quite a bit and hardly at all to the right. Hoping I won't have any weird flight characteristic because of this.
5) CofG is smack dab on the aileron tubes.
6) 5.5x4.5 Masterairscrew prop with prop collet.
I have space under the canopy for the gyro thingy which weighs in at all of 5 grams.
The Orange Rx is fixed inside so I will try mounting it on that.
Some Pics:
I will let you know how it goes.
maybe on Tuesday.
ChinoDiablo is offline Find More Posts by ChinoDiablo
Old Feb 04, 2013, 02:36 PM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Nice work, that should make a great plane.
I'm hoping you fly it a bit first without the gyro and add it later.
Then we can hear your thoughts on the difference it makes.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Feb 04, 2013, 02:54 PM
Joined Jul 2012
Thanks!
That's the plan...
I flew the hell out of my first one with no gyro but I'm curious how this 2 axis thing will do.
It worked pretty well in the F86 but that was an EDF. I don't know if that should make any difference.
Latest blog entry: Pizza!
Old Feb 04, 2013, 05:44 PM
Fred_L is offline
Fred_L's Avatar
Joined Sep 2003
For canopy latches on my crash kit I used a small magnet I bought on ebay. 20 in a package for just over $3 shipped.
http://www.ebay.com/itm/20-x-Strong-...item19d53b410e
I only used a magnet on one side and the other side was a piece of metal (just mild steel I guess) I cut from an electronic chassis someone threw out out in the trash. I cut it up with a hacksaw. Glued the pieces to the canopy and aircraft with hot melt glue. I figured that a magnet on both sides would require too much force to break apart. The aircraft is only foam after all. No need for rubber bands or tape.
This might all be moot since the newer kits don't come with the crash kit.
Old Feb 05, 2013, 03:43 PM
Joined Jul 2012
Welcome back Mini Swift!
Maiden flights today. 3 perfect zippy flights.
Just like old times.
No need for gyros.
She's fast, snappy and responsive.
I may have to strengthen the firewall, but that will be checked later.
Cheers,
Patrick
Old Feb 06, 2013, 11:13 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
For me this thing takes the wind pretty well. I use a 3s system and certainly some speed helps cut through it. I can't say I have used a gyro on one or any plane for that matter but if I were i would start with another plane. JMHO and it's probably worth the paper it's printed on.
Old Feb 06, 2013, 06:38 PM
Jayman72 is offline
Find More Posts by Jayman72
Note to self, put on pants.
Jayman72's Avatar
Australia, VIC, Frankston
Joined Mar 2012
It was time for a refinish of my swifty
Sanded lightly, quick spray of plastic adhesion primer, painted with acrylic poster paint, 2 light coats of WBPU satin to seal.
Running 1806 2500kv with HK 12a esc on 3s 460mah or 2s 800mah. 4.75x4.75 prop.
AUW is 210grams with 3s and lipo alarm.
Battery sits right on cg so i can change to a 2s 460mah if i want.
Jamie
Description: Name: 20130203_182232.jpg
Description: Name: 20130203_182204.jpg
Description: Name: 20130207_112332.jpg
Description:
Jayman72 is offline Find More Posts by Jayman72
Old Feb 07, 2013, 10:53 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Nice Looking paint Job. Running this thing on 3s is the way to go imho!!
Old Feb 08, 2013, 09:06 AM
fpsazerbaijan is offline
Find More Posts by fpsazerbaijan
FPV Noob
fpsazerbaijan's Avatar
United Kingdom, Scotland, Aberdeen
Joined Jun 2011
Has anyone converted their's to a pusher setup? I'm looking at turning my crash kit into a micro FPV rig
fpsazerbaijan is offline Find More Posts by fpsazerbaijan
Old Feb 08, 2013, 10:32 AM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Never heard of anyone doing that but maybe it's been done. Wouldn't think the airframe is condusive to it but I am not that skilled with mods like that.
Old Feb 08, 2013, 11:37 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
I know the Multiplex fox has been powered by a pusher configuration both on a power pod and with a tail mounted motor
http://www.rcgroups.com/forums/showp...8&postcount=72
http://www.rcgroups.com/forums/showp...postcount=2254 and even an edf
Andy
headlessagain is offline Find More Posts by headlessagain
Old Feb 08, 2013, 12:42 PM
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
I think the fox is a lot like the kinetic 800
New Product Hobbyking Mini Swift R/C EPP Glider Plug-n-Fly with crash-kit CrashingDutchman Foamies (Kits) 273 Aug 07, 2013 02:30 PM
New Product New Hobby King Mini Swift R/C EPP Glider Plug-n-Fly w/ crash-kit A-10_Flyer Scratchbuilt Indoor and Micro Models 3 May 09, 2010 08:56 PM
Build Log 20" Mini Swift Repair log zedz Flying Wings 0 Apr 25, 2010 06:09 PM
Discussion ms mini swift monster mini Flying Wings 3 Apr 11, 2010 03:46 AM
