Old Oct 29, 2012, 02:16 PM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Here is where my 800 2s pack sits with the 4 ch RX on top of the wing. Also a few picts of how I tarted her up. The decals were unused ones from my HK Parkjet
headlessagain is offline Find More Posts by headlessagain
Old Oct 29, 2012, 03:14 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Very nice looking Swiftie!!!
tracknoob is offline Find More Posts by tracknoob
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Hey, that turned out really nice.
IFlyRCs is offline Find More Posts by IFlyRCs
Old Oct 29, 2012, 05:30 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Thanks guys
Old Oct 29, 2012, 09:44 PM
ChinoDiablo is online now
Find More Posts by ChinoDiablo
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
United States, VA, Hamilton
Joined Jul 2012
Unfortunately my Mini Swift is beyond repair.
Firewall busted, front end distorted by gobs of gorilla glue.
I've decided to wait for HK to get these little birds back in stock and try again.
I believe the root to my problems with the Mini Swift lay in the fact that I used a prop adapter instead of a prop saver. Some hard landings resulted in the front part of the fuse cracking repeatedly. Next Mini will be used with either a prop saver or a Graupner folding prop.
Any suggestions for sizes and where to get a Graupner?
I intend to use the 1806 motor.
Thanks.
I really love the MS and can't wait to get another. Too bad they don't do the crash kit anymore.
ChinoDiablo is online now Find More Posts by ChinoDiablo
Latest blog entry: Pizza!
Old Oct 31, 2012, 01:47 AM
matrixFLYER is offline
Find More Posts by matrixFLYER
matrixFLYER's Avatar
Italy
Joined Nov 2011
Thanks.
Is only the front part broken? If it's the case you can make that part with depron and carbon fiber rod with 1806 motor.
matrixFLYER is offline Find More Posts by matrixFLYER
Old Oct 31, 2012, 08:30 AM
Joined Jul 2012
What is Depron?
Old Oct 31, 2012, 08:55 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Have a look here
http://radiocontrol.wikia.com/wiki/Foam and here for US alternative to depron
http://www.rcgroups.com/forums/showthread.php?t=1533245
Andy
Old Nov 01, 2012, 04:02 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Stuffed my Mini Swift into terra firma (or should that be terror frima) Was flying again in winds that would have grounded most models and having a blast. The wind was blowing across the park in the direction a row of houses. I cut the power just above them with the plan to glide in for a nice touch down. Instead, the model just went into a vertical dive that no amount of elevator would pull out from. It disappeared behind a hedge and I heard a sickening crack. I walked round to see if I could find it, expecting to see bits of foam strewn everywhere. To my surprise I found it in a flower bed about 2" away from a brick wall. The canopy had popped off and the prop was broken but all in all she looked to have survived pretty well. Back to base and I noticed that there was a split in the fuse, the left hand side of the wing was torn & distorted and the live aileron hinge was damaged.
CA took care of the fuse and the old hot water trick took out all of the distortion as well as a couple of dings on the leading edge. A bit of CA on a minor wing tear and some blenderm tape for the aileron and we will be back in business.
Conclusion, these are tough little models. If it had been a total loss I would certainly have bought another without hesitation.
Andy
Old Nov 04, 2012, 03:59 AM
morgans is offline
Find More Posts by morgans
Australia, NSW, Annandale
Joined Oct 2010
My mini swift had a sad encounter with a Me 109, it resulted in the wires being pulled out of the motor..... so i resurrected the second body into a glider.
Put a HK glider release on the nose activated by the rudder servo and also fixed a tow hook for bungee launch.
Works Ok for bungee, not a glider for aerotow though.
For your amusement have a look at
Hobby King Mini Swift - Testing bungee launching (1 min 57 sec)
E-Flite Apprentice + HobbyKing Mini Swift - First Aerotow attempts (4 min 8 sec)
morgans is offline Find More Posts by morgans
Old Nov 06, 2012, 03:53 PM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Folding prop upgrade?
Hi All,
Can anyone advise a good prop upgrade from the original supplied one?
I'm happy with the model in it's stock form without mods it flies well.
But my prop seemed a bit off balance from day 1 (losing energy to a vibration) & rather than replace it with the same, if there is an alternative, I'd like to give it a go.
I've read up to page ~40 and and gave up - sorry just got lazy and thought I'd ask directly.
Cheers - Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Jan 24, 2013, 07:55 PM
Joined Jul 2012
This poor thread is so old.
Well, I see HK has this back in stock...
Now that I know the ins and outs of this little bird, I just might get another...
$60+ for a small plane that kicks a$$ when hopped up!
Ya see there! I just talked myself into it!
Old Jan 25, 2013, 05:31 AM
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
I just might get another...I just talked myself into it!
My buddy who I gave my old one to flies that darn thing nearly every day, and just loves it to death. I was at the field yesterday and he head it up there.
Once you get used to it's quirks, and set it up the way you like it, it's hard to beat this little critter for what it is!
Old Jan 25, 2013, 04:52 PM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
I love this bird and flew it all the time because it sits on my front seat...... Until I was flying inverted w/out the battery being secured. It didn't fly so well with a 450mah 3s battery dangling. LOL. I just have to put the crash kit I have together w the old power system a good winter project. The kinetic, bonsai, pz micro Trojan and this get the most stick time just because they CAN go every where.
kenstogie is offline Find More Posts by kenstogie
Old Feb 02, 2013, 12:11 AM
Joined Jul 2012
Got my MS, take 2, all set up stock. Hinges, control horns, motor etc. I managed to re-use the main wing from my first MS.
I won't even try to fly her just yet. I'm going to wait for my 1806 motor and 10amp esc to show up before I even maiden her. I have a small 2 channel (aileron/elevator) gyro from a scrunched up F86 Sabre that I'm going to try to put to good use.
She's so nice and clean and perfect right now that I'd almost hate to fly her.
As they say... A plane in a hanger is safe but that's not what planes were built for.
Hopefully in the next couple of weeks.
New Product Hobbyking Mini Swift R/C EPP Glider Plug-n-Fly with crash-kit CrashingDutchman Foamies (Kits) 274 Sep 03, 2016 09:14 AM
New Product New Hobby King Mini Swift R/C EPP Glider Plug-n-Fly w/ crash-kit A-10_Flyer Scratchbuilt Indoor and Micro Models 3 May 09, 2010 08:56 PM
Build Log 20" Mini Swift Repair log zedz Flying Wings 0 Apr 25, 2010 06:09 PM
Discussion ms mini swift monster mini Flying Wings 3 Apr 11, 2010 03:46 AM
