Old Aug 31, 2012, 09:25 AM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
A 30A esc in mini swift?? A 50a ESC in a mini swift? why?
kenstogie is offline Find More Posts by kenstogie
Old Aug 31, 2012, 04:14 PM
ChinoDiablo is online now
Find More Posts by ChinoDiablo
Chef Pilot: Planes vs Butter
ChinoDiablo's Avatar
United States, VA, Hamilton
Joined Jul 2012
I've made my mods on the MS as described by Fred L and she looks pretty good.
I don't know what the weight is but she seems hefty by comparison to my other planes.
She's going to need some speed to stay in the air!
Just curious?
has anyone ever mounted the battery underneath the wing?
I'm using Zippy 500mah's.
It gets real tight inside and I need another centimeter to get the CG just right.
Also, what is the best way to "carve out" the insides?
I'm a little weary about how this bird is going to fly.
I'm sure she will fly the way she is supposed to fly, assuming she's balanced, but it's the speed thing that I'm concerned with.
Perhaps I should try my 240mah 2s batteries instead. Smaller, lighter, less mega-zippy.
That'll be on the next flight.
ChinoDiablo is online now Find More Posts by ChinoDiablo
Old Aug 31, 2012, 08:12 PM
Fred_L is offline
Find More Posts by Fred_L
If it flies - it's good
Fred_L's Avatar
Australia, NSW, Sydney
Joined Sep 2003
Yes, I mount my battery under the wing.
I cut a slot that I can access from the side to get the battery in and out. This lets me use larger 800mah 2S batteries without changing the CG. However 800mah 2S batteries lead to excessively long flight times of around 20+ minutes and I just get tired flying for that long in one stint - so back to the 500mah 2S batteries.
My flying weight is around 160g.
Fred_L is offline Find More Posts by Fred_L
Old Aug 31, 2012, 08:37 PM
Joined Jul 2012
Let me re-phrase that:
Has anyone mounted the battery EXTERNALLY under the wing?
Its seems that would solve a lot of problems
Fred: you cut a slot outside and under the wing to access the battery?
Is that directly under the wing/fuselage or to the left or right side under the wing?
Is there any compromise on the chassis structure?
I sort of like the idea of directly under the wing, in the center line of the bottom fuse, a slot wide enough to snuggly fit a 500mah bat with some external velcro straps to secure from left to right...
Also the slot should be long enough to slide the battery forward or aft to get the CG right, because as we all know, CG is critical on the Micro Swift to enjoy any sort of successful flying.
I love it and will try it this evening.
Old Aug 31, 2012, 10:33 PM
Fred_L is offline
Fred_L's Avatar
Joined Sep 2003
Battery slot
Photos are attached. I just cut the slot directly under the CG to minise any CG changes with battery size variations. The battery is a press fit and I wrap the thinner 500mah ones in some foam to pack them up to size.
This keeps the battery weight, which is about 30g, on the centreline. On a 160g aircraft I think handling would be advesely affected if you had that much weight carried under one wing.
The only issues I have had have been when it has nosed in on landing (flying too slow) and the battery shoots forward into the under canopy region and the fuselage splits at the forward corner of the battery cutout. You can see where I have PU glued it back up.
Old Sep 02, 2012, 06:18 PM
jetvision1170 is offline
Find More Posts by jetvision1170
United States, FL, Orlando
Joined Sep 2011
Linkage stoppers - screw too short
Can anyone tell me what you call the small circular part that locks down the pushrod with the screw on rudder control horn? The screw I received was too short and I ended up losing it when I took it the hardware store to find a replacement.
If anyone knows where I can order them on HK's site or another place, I would greatly appreciate it.
Thanks!
jetvision1170 is offline Find More Posts by jetvision1170
Old Sep 02, 2012, 06:54 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Thanks!
Like this maybe?
http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
Linkage stopper -- they have 'em in three sizes, mostly backordered, of course:
D1.8MM (10PCS) $2.95 BK
D2.1MM (10SETS) $1.11 BK
M3X2XL11.2MM (10PCS/SET) +10
tracknoob is offline Find More Posts by tracknoob
Old Sep 02, 2012, 08:17 PM
Fred_L is offline
Fred_L's Avatar
Joined Sep 2003
I think the generic name for a screw that tightens down in a fitting to squeeze a rod or other part is a 'grub screw'.
Yep, they sure are small on the Mini Swift.
Old Sep 02, 2012, 09:04 PM
Joined Sep 2011
Thanks that's exactly what I'm looking for!
Old Sep 03, 2012, 11:24 AM
Joined Jul 2012
Well, I made the mods on Mini as described by Fred.
Balances out beautifully.
Cutting a slot in the side is brilliant.
I'd like to have some sort of "tape-over" to cover the slot once the battery is in.
I'll be using 500mahs 2S and 6X5 prop with collet.
I'm get a little shaking at full throttle on the bench test.
It's not so bad at 3/4 throttle.
I hope I don't break too many props.
I'll be flying it Thursday at the field.
Old Sep 03, 2012, 07:02 PM
Fred_L is offline
Fred_L's Avatar
Joined Sep 2003
I've never had any trouble with the battery coming out of the slot. As I said, I make the battery a light press fit in the slot.
Full up elevator, full rudder and full aileron in the direction of the rudder produces a very rapidly rotating spin. It spins like a top. Even then the battery doesn't dislodge. But the spn axis is probably somehwere around the CG and that's where the battery is, so I suspect that even while spinning there aren't very high forces trying to extract the battery from the slot.
I only occasionally use full throttle. 2/3 -3/4 throttle gets it scooting along quite well. You can cruise at 1/2 throttle. A sustained vertical climb is possible on full throttle. I get flight times just over 10 minutes on the 500mah 2S pack.
Old Sep 03, 2012, 07:45 PM
Joined Jul 2012
Fantastic...
I can't wait!
Latest blog entry: Refining the Hanger
Old Sep 04, 2012, 02:12 AM
redbaron1 is offline
Find More Posts by redbaron1
redbaron1's Avatar
Australia, NSW, Casula
Joined Jan 2012
Actually the 2 words mini swift got mangled up. The brand name of the esc 50amp that I am using is the Swift and its installed in the Sonic 185 glider and not the mini swift plane. Down the thread these 2 words got mixed up.
She still beeps and going to try a 40 amp esc instead and see if she still does it.The motor brake I applied with the 50 amp swift esc still doesn't stop the prop from turning completely, she still turn very slowly when the throttle stick is right down. Testing the motor I found she drags 32 amps WOT so I am guessing the 40 amp esc would be more than enough to handle the current draw.
redbaron1 is offline Find More Posts by redbaron1
Old Sep 04, 2012, 02:19 AM
redbaron1's Avatar
Joined Jan 2012
Just another general question....When dealing with gliders do you set it up so she glides level with no input from the sticks cause that would mean a slight mixing of the throttle and down elevator when the throttle is applied. When I apply the throttle she climbs immediately.My educated 2 cents guess would be to let her glide level and mix the throttle with elevator to compensate the climbing effect as gliders are mean to glide and the throttle is meant to get her there.
Old Sep 04, 2012, 02:28 AM
Fred_L is offline
Fred_L's Avatar
Joined Sep 2003
The brake function is not a mechanical brake but an electrical one. It will only be active at 0% throttle. If the prop is still slowly turning then the throttle is not at 0% (well the ESC thinks it isn't). Set the throttle range as per a sequence described somewhere above so that the ESC discovers what is 0% throttle and what is 100% throttle. Move the throttle trim even lower so that the throttle output is definitely lower than 0% with the throttle all the way down.
The strange beeps and startup sequence you are describing could be because when it starts up it doesn't think the throttle is at 0%. Most ESCs will enter programming mode when started with a non zero throttle input. The beeps you hear will then will be dependent on the brand/model of ESC.
For an electric glider, trim for gliding. If it pulls up with throttle (quite common) then program a throttle to down elevator mix to counter that characteristic. Experimentation will lead you to the correct % value to set in the mix. I like it so that it goes where it is pointed - no nose up or nose down on throttle application. If I want it to climb under power then I use the elevator to change the attitude.
New Product Hobbyking Mini Swift R/C EPP Glider Plug-n-Fly with crash-kit CrashingDutchman Foamies (Kits) 273 Aug 07, 2013 02:30 PM
New Product New Hobby King Mini Swift R/C EPP Glider Plug-n-Fly w/ crash-kit A-10_Flyer Scratchbuilt Indoor and Micro Models 3 May 09, 2010 08:56 PM
Build Log 20" Mini Swift Repair log zedz Flying Wings 0 Apr 25, 2010 06:09 PM
Discussion ms mini swift monster mini Flying Wings 3 Apr 11, 2010 03:46 AM
