just got mine in the post... and 2 free servos! http://www.hobbycity.com/hobbycity/s.../_.13sec_/_52g
what a bargain! |
Wow that was the quickest most PAINLESS customer service experience I may have ever had in my life.
You are now chatting with : Trever You: Hey Trever Trever: Hello, how may I help you? Trever: Hello, how may I help you? You: I have an order that has something that is still... Trever: your order No,please You: on backorder and was wondering what to do about it. Can I take the backordered stuff off to let the rest ship?? Trever: yes,you can Trever: could you please tell us your order No.? You: XXXXXXXXX is the order number You: typing as fast as I can You: the Turnigy 800mah 2s 20c longs Trever: So should we cancel the BK item and ship the rest? Trever: you are typing very fast. You: Thanks! You: Yes but how do they handle the credit part? Trever: So should we cancel the BK item and ship the rest? You: Yes but do I get credit for the amount the batteries cost? Trever: ok.i will do it for you. You: Hobbyking credit is fine Trever: done,please check. You: Wow Trevor you are super quick. checking now brb in 2 secs Trever: anything else i can help you with? Trever: haha.thank you. You: Nope that'll do it. how long until that ships now?? You: Credit is there. Nice work. Trever: it will be shipped within 2 days. You: fantastic! Have a great day Trevor! Trever: have a nice day,too. You: Sorry Trever. You: ByeDone in under 5 mins and problem solved. |
I tried mine yesterday with a 410mah (? hextronic) and 610mah (rhino) and they both were pretty floaty. I found it a little more stable with the 610 but may have had the cog too far back with the other battery... I was fairly easy on the throttle with ~10min on each and only put back a little over 100mah when I charged them.
Great plane though (especially for the price) Tried to take a video (proped my BB against my sons wagon ). Not the best video but I will try and post it later anyway.EDIT: Certainly aren't many options in stock is there... these seem like good options (read: in stock )ZIPPY Flightmax 800mAh 2S1P ZIPPY Flightmax 500mAh 2S1P 20C Rhino 360mAh 2S 7.4v 20C Lipoly Pack EDIT: Video As Promised (not the best but its something)
Pickering Ontario CANADA
Joined May 2010
Hello. First post, so please excuse any errors.
I have been out several days now with the Swift using a 610 mah pack. Flies very well on this set up although it tip stalls like my DG1000. Keep the speed up and it's no problem. I agree with a previous post, the roll is brutal slow. The ailerons need to be freed up and more travel would be good. I have noticed that the elevator distorts with hard application causing it to roll during a rapid loop. I am thinking cut the hinges and use hinge tape for both ail. and ele. and if necessary move the ail. horn closer to the hinge line. You can take this bird out of the box and have a great time as it comes, but I like to tinker. All of this is imHo. Also, I ordered a 750 mah Rhino and it is too wide. Have a good one. Kerry |
USA, CA, San Francisco
Joined Feb 2004
The aileron linkage is all wrong, just for starters.
- The wrong side of the aileron is driven, giving negative differential. - The servo arm binds against the fuse. - The arms on the control surface are too close to the surface, and the holes in them are too large for the wires being used. - The aileron servo is too thick, distorting the fuse when the wing is installed. On mine, I could get 3-4mm of down aileron travel before the upward aileron started going up. I'm in the process of reworking the entire setup with new horns on the top and a thinner servo. = Mike |
Got mine in the air today, after about 20 mins out of the box, most of that was cutting out and placing the decals had no issues at all , it flies very well, pretty zippy it surprised me
using a Turnigy 2s 20c 800 mah .One negative: Cam prop won't fully fold, fouls on fuse, didn't notice it effect the flying though it just may make the blades vulnerable when landing . http://www.hobbyking.com/hobbyking/s...E_Warehouse%20 This Lipo is now back in stock ![]()
| Thread Tools | |
| New Product Hobbyking Mini Swift R/C EPP Glider Plug-n-Fly with crash-kit | CrashingDutchman | Foamies (Kits) | 272 | Aug 11, 2012 10:57 PM |
| New Product New Hobby King Mini Swift R/C EPP Glider Plug-n-Fly w/ crash-kit | A-10_Flyer | Indoor and Micro Models | 3 | May 09, 2010 08:56 PM |
| Build Log 20" Mini Swift Repair log | zedz | Flying Wings | 0 | Apr 25, 2010 06:09 PM |
| Discussion ms mini swift | monster mini | Flying Wings | 3 | Apr 11, 2010 03:46 AM |
