Old May 17, 2010, 08:15 PM
Dadude is offline
Find More Posts by Dadude
Nothing but high quality
Dadude's Avatar
United States, CT, Glastonbury
Joined Jun 2008
Get some vids up when you can, I am really eager to see this thing fly!
Jon
Dadude is offline Find More Posts by Dadude
Old May 17, 2010, 08:18 PM
Kahnx is offline
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
Originally Posted by KeithK View Post
Can the wing be easily removed for transport?
Keith
Yes the wing can be removed. The aileron servo is glued into the centre of the wing, so you'l have to disconnect it from the RX, and feed it back through the wing saddle. It'd be a PITA to do the first few times until you either got good at it or designed a mod to make it easier.
The plane comes in a EPS box, which has slots for the main components, and a spre of EACH - yes, a spare wing, fuselage and horizontal! The spare items aren't fitted out, but that would not be diffiicult. The box would be a great transport box for the plane to leave in the car, and would fit two complete planes (perhaps a powered one and a slopie!).
Brought the plane to work today .... guess what I'm planning at lunchtime??!
Kahnx is offline Find More Posts by Kahnx
Old May 17, 2010, 10:10 PM
KeithK is offline
Find More Posts by KeithK
What Canary?
KeithK's Avatar
Huntsville, AL USA
Joined Jul 2000
Thank you Kahnx, just ordered mine
KeithK is offline Find More Posts by KeithK
Old May 17, 2010, 10:25 PM
Kahnx is offline
Registered DSer
Kahnx's Avatar
Joined Mar 2003
Flight Report
Just got back form the local park. Windless today. Took some videos - my camera sitting on the ground, so they're not very good. Nonetheless....
Flew pretty straight, right off the launch, and gained height easily.
Rolls are 'sloooow', so I want to loosen, stiffen and probably lengthen the ailerons.
Not enough power for unlimited vertical (800 mAHr Flightmax 2S), but should be possible with a lighter battery. I'll probably just go for a bigger motor.
Glides very well when wings level, but loses height quickly in a turn.
Straight and level flight at full throttle pretty good - will quickly cover the length of a football field.
Turns quite nicely - I did most of the flight at low level, and did not have any trouble keeping a low, fast line in figure-8's at head-height.
Flight time aqpprox 9 minutes, with 3/4-full throttle for most of the time, but these are from the first charge of teh Flighmax's, so it'll probably get better.
I launched the plane probably 10 times, and it flew out easily. I hand-caught the plane probably half-a-dozen times - easy to line up the approach, and the glide is quite good.
As for FPV, I think that there is not quite enough power to fly a FatShark/ImmersionRC 10mw Tx and 922 camera on anything less than full throttle. For a lighter setup, you could probably get away with the stock power system. I'll test these theories.
I got some video, which I'll edit and put up tonight.
Cheers
Roger.
Old May 17, 2010, 11:07 PM
ED3 is offline
ED3
Find More Posts by ED3
ED3
100% RC ADDICT
ED3's Avatar
USA, CA, Los Angeles
Joined Aug 2007
nice my should be here in a few weeks
ed
ED3 is offline Find More Posts by ED3
Old May 18, 2010, 01:47 AM
asd9000 is offline
Find More Posts by asd9000
United States, FL, Tampa
Joined Nov 2009
Can't wait to see the video
asd9000 is offline Find More Posts by asd9000
Old May 18, 2010, 05:05 AM
discostu956 is offline
Find More Posts by discostu956
Is my CG correct?
discostu956's Avatar
Wollongong, Aus
Joined Sep 2009
Looking at one of these as well. Keen to see vid. Thanks for the report
discostu956 is offline Find More Posts by discostu956
Old May 18, 2010, 05:23 AM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
Sweeeet!
Man I pre-ordered mine ages ago and I still aint got it
How was the CG with the 800mah? I only ordered 500's
And get them vids up!!!
chancesAU is offline Find More Posts by chancesAU
Old May 18, 2010, 06:21 AM
Harri Pihl is offline
Find More Posts by Harri Pihl
Suomi, Lšnsi-Suomi, Uurainen
Joined Jan 2004
How about the stalling characters? The MPX Fox tip stalls badly so I ordered this one hoping more gentle stall...
Harri Pihl is offline Find More Posts by Harri Pihl
Old May 18, 2010, 07:41 AM
Kahnx is offline
Registered DSer
Kahnx's Avatar
Joined Mar 2003
Chances, the CoG is between the pushrod tube and the spar. To fit the 800mAHr battery, I needed to dig a little bit of foam out under the saddle - no big deal. The 500s should be fine, though the Flighmax batts appear to be thicker than other brands, so you may need to go digging too.
As for tipstall (yeah, I've got a fox) its is very good. no 'tendencies' at all in my 20 minutes of flying today.
Videos being processed.
Cheers
Roger.
Old May 18, 2010, 10:17 PM
A-10_Flyer is offline
Find More Posts by A-10_Flyer
making the world a weird place
A-10_Flyer's Avatar
Southern California.
Joined Aug 2008
Is the video done processing? I am dieing to see it fly!!
A-10_Flyer is offline Find More Posts by A-10_Flyer
Old May 18, 2010, 10:55 PM
chancesAU's Avatar
Australia
Joined Apr 2008
Heres a cool review from HK - to keep us going until the video is ready :P
Old May 19, 2010, 12:55 AM
Kahnx is offline
Registered DSer
Kahnx's Avatar
Joined Mar 2003
Chances, you're going to love the extra room in the cockpit for the FPV gear - miles more space than in the MX Fox.
Video up tonight - I promise ..... but I dont promise that it'll be that entertaining
Old May 19, 2010, 05:03 AM
Kahnx is offline
Registered DSer
Kahnx's Avatar
Joined Mar 2003
It was impossible to drag enough good footage from my stationery camera to capture the performance of this little plane. Sorry guys.
Instead I've done a small extract of some launching and catching. Really cant see much of the plane, but it's easy enough to launch, lap and catch without much effort.
HK Mini-Swift Hand Catching (1 min 38 sec)
Cheers
Roger.
(who will try to get some 'hat cam' videos)
Old May 19, 2010, 05:07 AM
BulletMaster is offline
Find More Posts by BulletMaster
Chillaxin dude!
BulletMaster's Avatar
Newcastle, NSW, Australia
Joined Apr 2003
mine's in transit at the moment... looking good for a morning delivery
BulletMaster is offline Find More Posts by BulletMaster
New Product Hobbyking Mini Swift R/C EPP Glider Plug-n-Fly with crash-kit CrashingDutchman Foamies (Kits) 273 Aug 07, 2013 02:30 PM
New Product New Hobby King Mini Swift R/C EPP Glider Plug-n-Fly w/ crash-kit A-10_Flyer Scratchbuilt Indoor and Micro Models 3 May 09, 2010 08:56 PM
Build Log 20" Mini Swift Repair log zedz Flying Wings 0 Apr 25, 2010 06:09 PM
Discussion ms mini swift monster mini Flying Wings 3 Apr 11, 2010 03:46 AM
