Old May 16, 2010, 06:32 PM
killerwin is offline
Find More Posts by killerwin
Say watt?!
killerwin's Avatar
United States, FL, Miami Lakes
Joined May 2009
Mini-HowTo
Program Flaperons Using T6A Radio
Here's how I programmed flaperons with my HobbyKing.com T6A radio.
I started out with a servo on CH1 for the left aileron and a servo on CH6 for the right aileron. I programmed the first mix (MIX1) for standard ailerons as follows:
Code:
Mix Num: MIX 1
Source: CH1
Des: CH6
Up Rate: 100%
Down Rate: 100%
Switch: ON
If all you want is ailerons, this is where you can stop. Next, for flapperons, I used up the remaining mixes (MIX2 & MIX3). MIX2 for CH1 (Left Aileron) and MIX3 for CH6 (Right Aileron):
Code:
Mix Num: MIX 2
Source: VR B
Des: CH1
Up Rate: 75%
Down Rate: 75%
Switch: SW B
Code:
Mix Num: MIX 3
Source: VR B
Des: CH6
Up Rate: -75%
Down Rate: -75%%
Switch: SW B
This results in the ability to switch flaperons ON and OFF with Switch B (SW B) and adjust the angle of the flaperons by rotating Pot B (VR B).
There are many options and settings to play with here, including aileron differential; to read further, see the thread where I found the info I needed: http://www.rcgroups.com/forums/showp...postcount=1705
Here’s the video:
How to Program Flaperons Using T6A Radio (4 min 39 sec)
killerwin is offline Find More Posts by killerwin
Discussion New software for the HobbyKing HK-T6A, FlySky FS-CT6A and Turborix TBXT6 radio HappyMan2009 Radios 479 Feb 10, 2016 01:44 PM
Discussion Radio 2.4 Ghz HK-T6A (Hobby King) 6 canais nino_sdk Brazil 93 Jul 06, 2012 02:40 PM
Discussion Anyone using HK T6A??? spessx Mini Helis 0 Dec 28, 2009 06:21 PM
Sold Hobbyking T6A 2.4ghz 6ch Radio System with extras whitty7628 Aircraft - General - Radio Equipment (FS/W) 1 Sep 29, 2009 08:16 PM
Discussion flaperons+flaps program 9 zap videocruzer Radios 2 Sep 04, 2009 12:18 PM
