Old May 16, 2010, 02:27 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
Old EK Logictrol 4 ch Radio
I have an old 4 ch EK Logictrol radio (and a 2-servo/RX brick). I know its of no use nowadays (at least for flying RC as it sits), but I was thinking that just for some nostalgia that the TX case might be used to convert to 2.4. It would make a nice TX for oldtimers and simple parkflyers.
There was a thread on the 9303 that one person (who has not posted for several months) says some people have used some old ACE RC boxes to convert to 2.4. He also had a link to a Yahoo message board, but I thought it might be better to ask here.
I was thinking that it might be possible to use the guts from an inexpensive spektrum radio, like maybe the DX5e, and put in the case for the EK. Would the old gimbals be OK to use? The one thing I don't like about the old gimbals is that they are so long.
If I can get this started, I will post some photos. I want to keep the EK TX box as original as possible, hence the DX5e. I will have to add some things such as a toggle for the binding switch, and another for the 5th channel. The 5e has a set of LEDs for the voltmeter, but the old EK has a simple analog needle gauge. Would that still be able to be used?
I would put the switches for the servo reversing on the back of the case.
As the DX5e uses 4 AA batteries, I could obviously coy that, but as the case is held together with four small sheet metal screws, I'd rather have some other battery like a LiPo pack that I could just put a charger jack in. Is it possible to have some sort of LiPo pack to power the DX5e with some modifications?
thanks in advance for any help.
jonquinn is offline Find More Posts by jonquinn
Old May 16, 2010, 07:12 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
The gimbals from the old Logictrol are of better mechanical quality than what is sold these days even in relatively pricy radios. If you use all the gut from the DX5 you'll just need to re scale the analog meter to read from 6 volts. They are just a regular meter which read the current trough a resistor. I am hacking a Hitec CRX myself right now after a mechanical failure and find it quite an interesting project. As for the reverse switches since they are not used very often you could have them inside the box to maintain the original look of the Logictrol. I have several older radios that I will convert to 2.4G eventually but not planning on using Spektrum for that. There is lot of D.I.Y. modules around from China which are very easy to use and bind to much cheaper Rxs as long as the encoder board of the Tx provide a good PPM pulse. As for using Lipo in that Tx it would be difficult unless you are very carefull since the cut-off voltage for two cells would still run the Tx after the cells are bellow 3V each, which would make charging inside the Tx a very risky proposition. Better stick with regular AA cells, A Rx pack would be just fine.
coriolan is offline Find More Posts by coriolan
Old May 16, 2010, 08:58 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Some of the people, used the Hobby City 4 channel and or Hobby City 6 channel systems to convert their old systems over to 2,4ghz. The TX and RX are quite inexpensive. The 6 channel is a computer radio, that you program via a USB port from your computer. It doesn't have a on board display, so it is easier to convert a old TX over.
4 channel $26.95 for TX and RX and $15 for extra receivers too.
http://www.hobbycity.com/hobbycity/s...x_%28Mode_2%29
6 channel TX and RX for $32.95 with $15.00 for extra receivers.
earlwb is offline Find More Posts by earlwb
Old May 16, 2010, 09:19 PM
jonquinn is offline
Joined Aug 2008
thanks for the tips.
I'll see what I can get as far as a nicad or NiMH battery pack goes for the RX. I'm going to try to get a spektrum DX5e off ebay, so as not to spend too much (I'm sticking with Spektrum as that is what I have right now, as far as receivers, etc. goes).
Old May 16, 2010, 10:53 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Why not just stick with AA NiMH batteries and use the manufacturer's charger? Best are Sanyo Eneloops or Rayovac Hybrids, which have about 2000 mAh capacity and very low self-discharge rate.
They would be better and cheaper than a receiver pack.
Daedalus66 is offline Find More Posts by Daedalus66
Old May 17, 2010, 11:17 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
The general concept is good. I did this with a Kraft radio, stuffing a DX5e board into it. I had to trim the edges of the board off and manually jumpering some signals, but it works fine.
I would use a normally open pushbutton rather than a toggle for the bind/range/Ch 6 button.
There are pictures over on RCU of the conversion.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
EK Logictrol 6channel/4servo needs a home tmwatson Vintage & Old-Timer Designs 21 May 28, 2010 09:48 AM
Sold Vintage EK logictrol sailplane accessories $20 mailed USPS CONUS be69ar Aircraft - Sailplanes (FS/W) 2 Jan 24, 2010 10:37 AM
Discussion EK Logictrol Help Outlaw 10.5 Radios 1 Sep 28, 2008 11:49 PM
Sold EK Logictrol Super Pro System tlh101 Aircraft - General - Radio Equipment (FS/W) 1 Apr 13, 2007 12:54 PM
FS: Antique EK Logictrol 27MHZ 6ch 4servo Best Offer tmwatson Aircraft - General - Radio Equipment (FS/W) 7 Sep 07, 2004 07:58 PM
