This thread is privately moderated by Heli Hacker, who may elect to delete unwanted replies.
Old May 16, 2010, 02:08 PM
Hang on, turbulence ahead
Heli Hacker's Avatar
St. Louis
Joined Dec 2007
New Board!
Finished board design for PhuBar 3 using ITG3200 3-axis gyro. Managed to squeeze the board size down to 30x28mm. If I solder cables directly onto the board instead of headers, and use clear shrink wrap instead of an enclosure, the whole thing should be 30x28x7mm, except for where the 5-pin programming connector will stick out from one side.
I added the fifth pin to that connector to supply 3.3v so I can use the TextStar serial terminal for field setup.
I also added connector pads for 2 general-purpose I/O connections plus ground to allow for programming the Propeller to do other functions if desired.
The 3-axis gyro will let me add rudder gyro capability, as well as use cosine-matrix math for more accurate attitude estimation.
Update: I received the boards from BatchPCB on June 1. They look really good - photo below
Heli Hacker is offline Find More Posts by Heli Hacker
Discussion New to the board, could use some help. timmins02 Lagoon Valley Electric Flyers 6 Mar 06, 2010 01:31 PM
For Sale (2) Chargery 550B 5s 5A Like new with JST-XH balance board Zeta Phoenix Aircraft - Electric - Batteries & Chargers (FS/W) 8 Dec 12, 2009 01:11 AM
Discussion new aerobat on the drawing board Conwy-Soarer Foamies (Scratchbuilt) 0 Nov 03, 2009 06:39 AM
Sold K&B 3.5 out board new clif Boats (FS/W) 6 Nov 02, 2009 06:29 PM
