This thread is privately moderated by Rickyd863, who may elect to delete unwanted replies.
Old May 15, 2010, 11:00 PM
Rickyd863 is offline
Find More Posts by Rickyd863
Rickyd863's Avatar
USA, KY, Louisville/Jefferson County
Joined Feb 2010
1st air time after crash
May 15, 2010
well, i thought today was the day to get the heli back in the air. or try to. I checked everything onthe heli and programed my 9303 that i had just got. I have a stand that i strap my heli to, so i can check everything out on it..I strapped the trex to the stand and binded it to the 9303. it went as smooth as silk. I tested all the servos and they seemed to work properly. I gave it a little throttle and noticed something wrong. It looked like my blades were not tracking evenly. i mean they were off by around a 1/2". I thought this was strange, as i had balanced the blades. So i decided to switch places with them and see what happens. They still tracked out by about 1/2". I then noticed that my main shaft was bent. So i took the head apart and replaced the main shaft. When i fired it up, i noticed the main gear was making a strange sound. I had not inserted the spacer onto the shaft in the correct place. i had put it between the main gear and tail gear. Popped the servo rods off swashplate and raised shaft and corrected this. I put back together and slowly advanced throttle. I noticed main tail gear was wobbling. In my opinion, this was too much, so i went through the same procedure and replaced it. I fired it up and the blades were still were not tracking correct. As i was taking the blades off, I noticed one of the grips had some play in it. I pulled the shaft, but as i was removing the first grip, the bearing next to the head unit, fell into the palm of my hand..That would be ok except it was in pieces. I almost thought it was a thrust bearing for a brief moment. Now i have 2 sets of bearings ordered the the grips and also a complete set from boca. While i anm waiting for them to arrive, guess I will have to choose which of my in-door heli's to play with. I have mcx s300, msr, cx3, and working on a cx2.. well, i favor the mcx for some reason... I went through this in around 4 hours today.. seemed like only minutes since i came into the shop. I like working on them but I want to fly one of these days...
until next time.
Rickyd863 is offline Find More Posts by Rickyd863
Discussion Air to air crash diem FPV Talk 11 Oct 03, 2009 03:16 AM
Discussion Air Hogs Aero Jet goes straight up, down, crash every time chadmyers Beginner Training Area (Aircraft-Electric) 7 Jan 06, 2008 11:07 AM
Question Engine Fix After my 1st Crash NCPaul Fuel Plane Talk 5 Sep 03, 2002 04:42 PM
Zagi Tray broken after 1st crash! Josh C Foamies (Kits) 14 Jul 15, 2001 04:10 PM
