Old Jun 10, 2003, 12:45 PM
Eddy is offline
Find More Posts by Eddy
Malibu Ca
Joined Feb 2000
winding a 1 3/8" CDR motor?????
Does anyone know what winding and how many turns are good for a 1.375" diameter stator? It is exactly the same as the smaller CDR motors, I don't knw what it came out of but would be a great stator for a larger size motor. I would it with the green Radio shack wire, I think it was 14 turns or so and the motor was not very powerfull but did work then I redid it with the orange radio shack wire and it did not seem to work at all, it worked at very low voltage then as I increased voltage it only shifted back and forth and did not rev up, is this because the wire was to heavy or not enough turnes?
Eddy is offline Find More Posts by Eddy
Old Jun 10, 2003, 04:26 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Hi Eddy,
Can you post some pictures?
How many teeth are there in the stator?
How many magnets in the ring? If it's a circular magnet ring, use a screwdriver to count the number of attraction points.
What winding diagram did you use for the stator (link, site, drawing)?
Met vriendelijke groet Ron van Sommeren
diy outrunner brushless e-motor discussion.
Electric fly-in & lrk meet, June 22nd, 2003, Nijmegen, the Netherlands.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jun 10, 2003, 05:44 PM
Eddy is offline
Malibu Ca
Joined Feb 2000
windings
This is the site I used to wind the motor
http://mitglied.lycos.de/hestoeck/planes_cdrmaking.html
I used a magnet and there were 7 points of attraction.
Old Jun 10, 2003, 11:44 PM
jmbig is offline
Find More Posts by jmbig
North Highland,ca
Joined Dec 2002
Try 10 t to 12 to start change the outer magnet to good neo's
2 magnets for ever 3 teeth witch on 9 teeth would be 6 magnets
closer the magnets fit to the stator the better BUT. Take a look at the LRK brushless site above. CU
jmbig is offline Find More Posts by jmbig
Old Jun 11, 2003, 06:52 AM
Joined Feb 2001
I have never hear of 7 magnetpole motors, are you sure?
All teeth wound in the same direction?
Use a powerdrill to drive the shaft and measure the voltages, they should be the same.
As jmbig said, neodym magnets will give a huge improvement.
Groeten Ron
Old Jun 11, 2003, 09:18 AM
Eddy is offline
Malibu Ca
Joined Feb 2000
Sorry, it is a 6 pole I miscounted. where do I get neodym magnets
the right sise for this motor? Should I use the green radio shack wire or something heavier?
Old Jun 11, 2003, 09:54 AM
jmbig is offline
North Highland,ca
Joined Dec 2002
Anyway you wing ever third pole with one pice of wire all in the same direction rotation on the tooth then you do the other two
winds just after the first. It is almost better to unwind the orignal
to get the pattern. There are a lot of pictures at the LRK site. The six tooth stator is not as much torque as a 9 but it will work ok
CU
Old Jun 11, 2003, 11:07 AM
Joined Feb 2001
I don't know about Radio Shack gear, I we are not talking plastic insulation here but lacquer coated wire? You have enough space to use thicker wire, the thicker the better (lower resistance, higher efficiency), or you can wind several strands in parallel.
Magnets:
http://www.engconcepts.net/Magnets/P...x_Magnets.html
http://groups.yahoo.com/group/lrk-torquemax/
-> photos
-> !winding ...
Originally posted by jmbig
... The six tooth stator is not as much torque as a 9 but it will work ok ...
Jim, I assume you mean the six magnetpole stator?
Groeten Ron
edit: changed faulty link
Old Jun 11, 2003, 11:48 AM
Eddy is offline
Malibu Ca
Joined Feb 2000
The winding link does not work
Thanks for all the info so far.
Old Jun 11, 2003, 11:49 AM
Eddy is offline
Malibu Ca
Joined Feb 2000
Can the rotor be made out of titainum to make it lighter or does it need to be magnetic?
Old Jun 11, 2003, 01:19 PM
Eddy is offline
Malibu Ca
Joined Feb 2000
I emailed the guy about the magnets he had 5mm square by 1mm thick will this work do I need 2 side by side? So a total of 12 magnets or will six do? The magnet in the motor is 5 mm wide by 2 mm thick.
Old Jun 11, 2003, 05:13 PM
Joined Feb 2001
It does now.
Although I set the 'photos' and 'files' section to 'public', Yahoo insists on loggin in for the 'photos' section Don't worry, you will not get any spam from the list and you can set the 'nomail' option.
Titanium will not work. You need steel (not stainless steel).
You can cascade magnets.
Groeten Ron
New Brushless motor - 1/3 scale model? allan Electric Plane Talk 12 Jan 10, 2008 06:37 AM
Discussion Running a 1 - 3 Volt Pager Motor With a GWS ICS50 ESC ShokWaveRider Scratchbuilt Indoor and Micro Models 8 Aug 13, 2007 10:39 AM
Homemade gear 1:3.2 (Electric motor) jlagran Heli The Builders Workshop 1 Sep 14, 2004 03:24 AM
Gear Ratio Question.3.5:1 to 3.8:1? nw6601 Power Systems 3 Mar 11, 2003 05:15 PM
Prop for Endo at 3.8:1? Ben74 Electric Sailplanes 11 May 29, 2002 11:07 PM
