Make a hot wire foam cutter in 30 minutes.
See video and pics below. I was tired of reading and researching and pricing out hot wire cutters, so I thought about the bits and pieces of info I gathered and decided to take the plunge and do it my way with stuff I already had. No train transformers, dimmer switches etc… That is for a better setup in the future if I really need it If I had 4 small alligator clips I could have done it in 15 minutes!!! Thanks to all who put info out there. List of parts: 1x 450 Instant Starting Amps - Start It® Jump-Starter http:/www.blackanddecker.com/Product...roductID=15582I had bought mine at SAM'S 6 years ago for $39.95. Had it on the boat, the car, the truck and it saved my butt many times. Everyone should have one! Tell the wife. ![]() I plugged tires and inflated them on the side of the road without removing the wheels, jump started my boat many times while I was way out there… Also helped quite a few people with drained batteries. Now that is enough to justify getting one! ![]() 1x extension cord 1x fiberglass rod 1x guitar string 2x small alligator clips Soldering iron 30 minutes to spare! Note: If I had 4 small alligator clips I would have used them so as not to solder wires permanently to the battery jumper clips. I will have to go and get 2 more so I can do a quick connect/disconnect in order to still use the jump start for its main reason of being!!! See the video and pics. Self explanatory. I think I will call this the "K.I.S.S." hot wire cutter. Next is to build my vacuum forming box: I already have some leftover peg board, a wet dry vac, wood pieces and a portable rotisserie oven of good size to heat up the plastic. The other is setting up my vacuum bagging machine to bag wings. I will also use a simple hand pump used to check the vacuum on cars, 20-30 bucks. (ALSO PORTABLE and does not require a power source.) This is what I want for my hangar: http://www.samsclub.com/sams/shop/pr...oductId=129079 Would a really cool weather vane!!! Visit:http://www.rcgroups.com/forums/showthread.php?t=1243116 for more info on the $1 covering. Enjoy and please contribute your feedback to this thread. Thanks, Lafayette.
Try on a really flat surface like a glass table. See if your cut improves. Lafayette |
New pics of thin cuts of FFF using my setup, guitar string for wire.
I obtained nice cuts 1/16" and 1/64". That is paper thin. The 1/16th would be perfect for sheeting, or for wings for micro planes. With the 1/64" I can finally make some "Walkalong gliders" for my kids and schoolmates! One for me too, I can always use the exercise!!!
The video was to show what can be done with odds and ends on the cheap! I also built a router and a gravity table fot just a few bucks. I,d rather buy foam or balsa or batteries!
This is really cool stuff Lafayette. Any chance of a vid shwoing how you cut the 1/16 & 1/64 thick pieces?
I have a need for 3mm & thinner foam but can't spring for new foam atm but have a lot of blue FFF and also the 2" blue. Would love to see how you cut that stuff. Thx for posting this. ![]() jimmy |
Also look at the SEEBEE build on my blog, or go to the thread I have a wire router and a gravity table build in the vids made for close to nothing. http://www.rcgroups.com/forums/showt...1284518&page=2 |
| Thread Tools | |
| Alert For Sale CNC Hot Wire Foam Cutter | Depdog | Atlanta Area RC | 9 | Mar 24, 2010 10:35 AM |
| Wanted Hot Wire foam cutter | diasje | Aircraft - General - Miscellaneous (FS/W) | 7 | Nov 29, 2009 04:17 PM |
| Wanted CNC Hot Wire Foam Cutter or parts! | jfruge | Aircraft - General - Miscellaneous (FS/W) | 5 | Nov 22, 2009 09:14 PM |
| Help! Hot Wire Foam Cutter | rudes | Utah Flyers Organization | 4 | Oct 14, 2009 05:44 AM |
| For Sale Cnc Hot Wire Foam Cutter | Depdog | Aircraft - General - Miscellaneous (FS/W) | 0 | Oct 08, 2009 12:15 PM |
