Old May 14, 2010, 09:20 PM
fooyukvoon is offline
Find More Posts by fooyukvoon
The Need4Speed
fooyukvoon's Avatar
Malaysia, Perak, Ipoh
Joined Aug 2008
What's the Difference between an Aerobatic Version and 3D version of a kit?
Hello everyone,
I've got the HK Edge 540G2 36" Kit, and I am suspecting it may be designed for aerobatics and not really suited for 3D. How can we tell if a plane is suited for 3D or not?
Are there certain things to look for when buying a 3D capable plane besides what the seller claims it can do?
Or is there settings that will convert a normal Aerobatic plane into a 3D capable plane.
I hover/prop hang mostly (with my other foamie/EPP planes) and this being my 1st balsa/ply 3D plane, I find it to be very unstable getting it into the upright/vertical position.
Any suggestions will be greatly appreciated.
Nd4spd
fooyukvoon is offline Find More Posts by fooyukvoon
Old May 14, 2010, 10:46 PM
kc-foamie is offline
Find More Posts by kc-foamie
Joined Apr 2010
Originally Posted by fooyukvoon View Post
Hello everyone,
I think two requirements to make a "3D" plane is the ability to climb vertically (greater than 1:1 thrust ratio) and the ability to get the CG far enough back to allow reliable hovering. I'm sure exceptionally skilled pilots could hover a lot of planes, but it's far easier when the CG is back a bit from the most stable configuration.
The combination of those two things (power and weight distribution) could mean the difference between "aerobatic" and "3d".
kc-foamie is offline Find More Posts by kc-foamie
Old May 14, 2010, 11:35 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
err, close. 3d aerobatics are aerobatics and maneuvering post-stall. Because there's no lift (the plane is stalled), you typically need a boat load of power to compensate. The post above is right in that regard. Not unusual to have 2:1 thrust to weight, won't have much fun unless you get at least 1.5:1 or more.
The other key aspect of crontrolling beyond the stall is very large control surfaces and control throws... the air isn't moving much, so you need more control. extra throws and surfaces also means you can push the plane into 3d maneuvers which requires pushing through stalls, etc.
"getting the cofg far enough back to hover" isn't really correct... hovering is a skill that takes practice, and if you know the input you can hover a nose heavy plane if it's designed well. If you set up the plane to be tail too heavy you simply create a mess of a plane to fly in other maneuvers and you're simply making life hard for yourself. "neutral" is about as far back as you ever want the CofG (neutral is rolling inverted and needing no down elevator to maintain height).
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old May 15, 2010, 12:22 AM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
In the manual, the CoG was recommended at 7cm from LE, at that setting, the plane appeared tail heavy when the throttle is below 60% and drops/sink rate is quite fast but flat. It does not glide very well off throttle.
Does this indicate a CoG that is too far aft?
Have tried moving the CoG as far as 1.5cm forward. At this setting, the plane glides and it appears to fly just like a normal plane should. Would this be a good setting for 3D? Being a balsa/ply plane, I am being very careful as it is not as crash resistant as an EPP plane
Thanks.
Nd4spd
Old May 15, 2010, 10:55 AM
theKM is offline
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
Thanks.
Nd4spd
some planes do this with a neutral cofg, and some 3d planes aren't easy to land for this reason. will have to do the roll inverted test to find out... trim for level flight at half throttle, and then roll inverted and see what happens.
Old May 15, 2010, 12:45 PM
Dennis C is online now
Find More Posts by Dennis C
Dennis C's Avatar
Grass Valley California
Joined Jun 2004
Assumint that the airfoil is symetrical then you need to trim the airplane to fly straight and leval with nearly full throttle, roll inverted and you should need nearlyno down stick to fly leval.
UP/down thrust can effect climb and glide power on and power off.
trimed for leval flight at full power (CG located where you want it) cut the power, the plane should start a very gentle dive, power back up and it shoul leval back out.
If the model dives too much then you need to add down thrust. If it baloons then you need add up thrust.
another key to goood 3D performance is a light wing loading. Many good sport aerobatic models are too heavy for good 3D performance.
Dennis
Dennis C is online now Find More Posts by Dennis C
Old May 15, 2010, 06:45 PM
The Need4Speed
fooyukvoon's Avatar
Joined Aug 2008
This is the model I am talking about. It's by Top Model (China) Everyone at my field commented that it was quite heavy.
Off Site hi can you help plz, what's the difference between np12v and a pb 12v Batteries jock1961 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 28, 2010 11:18 PM
Question hi can you help plz, what's the difference between np12v and a pb 12v Batteries jock1961 GWS (Grand Wing Servo) 1 Mar 28, 2010 06:42 PM
Discussion is there much difference between an octura y 535 and an x 535 propeller ? mortonj69 Dock Talk 7 Nov 22, 2009 02:55 PM
Question What's the difference between trailing edge and aileron stock? flatland2d The Builders Workshop 5 Oct 05, 2009 08:52 PM
Discussion What's the difference between an esc with bec and one without? randall1959 Power Systems 4 Jul 25, 2009 01:20 PM
