Old Jul 04, 2010, 09:58 PM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
Originally Posted by mack5 View Post
Hi
Thanks for all of you, Kwok_Yu your .wmy plays but it has no sound
Also how do you turn a line into a polyline?
Can you combine a .dat file with a wing out line to make a top / bottom wing?
JimnAz thanks for the file. I had to put in the SKup plugin folder befor the plugin worked. But it worked.
There is no sound in the video. To turn a line into a polyline, I use the bezier splines plugin: right click context menu/convert to/polyline
I hope you make it a priority to figure out your problem with the skechucation forum, as I have no wish to be your personal supplier of public plugins. For now, I googled and found the bezier splines plugin also posted here: http://www.kien06vl.com/viewtopic.php?f=140&t=824
The dat file just imports as a bunch of edges. If you aren't able to make that into a top and bottom curve, you should be learning the basics before trying to do surface modeling. One tip , I can give you, is after you have the top and bottom edges, then convert them into a bezier spline instead of a polyline.
-Kwok
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Sep 17, 2010, 10:01 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I have a question about importing image files. It seems that no mater how good the image file looks outside of sketchup that once it's imported it looks blurry. Is there a particular image file type that works better when importing?
SteveC68 is offline Find More Posts by SteveC68
Old Sep 17, 2010, 10:06 AM
7up is offline
7up
Find More Posts by 7up
7up
,ɯǝ ʇoƃ ɐʎ ɟı ,ɯǝ ǝʞoɯs
7up's Avatar
USA, KY, West Liberty
Joined Jun 2001
Do you have "X-ray"face style turned on?
View > Face Style > X-ray
7up is offline Find More Posts by 7up
Old Sep 17, 2010, 10:26 AM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
No that's not it. I think Sketchup just doesn't handle image files well. I've imported very large drawings (70" wide x 30" tall) and they still look pretty blurry when zooming in to try and trace. These same image files look very sharp in Gimp when zoomed into the same level.
Old Sep 17, 2010, 10:32 AM
7up is offline
7up
7up
7up's Avatar
Joined Jun 2001
hmmm, I've never had any trouble with images being blurry.
Have you checked to make sure that "Hardware acceleration" is turned on?
Window > Preferences > OpenGL
Old Sep 17, 2010, 11:52 AM
Kwok_Yu is offline
Maryland, USA
Joined May 2004
I just checked and it is blurry. Never noticed that before. Maybe it's imported at a lower resolution to save space?
Old Sep 17, 2010, 12:21 PM
7up is offline
7up
7up
7up's Avatar
Joined Jun 2001
I honestly can't see any eifference on mine, however, I do see some on your's Kwok but it could just be me. I have very poor eyesight.
Old Jan 27, 2011, 06:43 AM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Hello,
Does anyone have information on how or where to get the "fredoscale" plugin? I cannot seem to download it from the page that it used to be on (the links are inactive). Is there an alternate program that will allow me to bend parts?
Thanks!
SNice is offline Find More Posts by SNice
Old Jan 27, 2011, 07:02 AM
7up is offline
7up
7up
7up's Avatar
Joined Jun 2001
Fredoscale --> http://forums.sketchucation.com/viewtopic.php?t=17948
Old Jan 27, 2011, 07:30 AM
SNice is offline
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Thanks, 7up!
I did not realize that you had to be logged on/in to gain access to downloads. I got it now! Thanks again!
Old Jan 27, 2011, 06:03 PM
Karl Bē is offline
Find More Posts by Karl Bē
29 rods from you in western WI
Karl Bē's Avatar
Joined Jan 2003
Regarding images imported into Sketchup:
If your image is larger than 1024 pixels, it will be downsized. To get a large image into SU at high resolution, you'll have to break it into 1024x1024 panels, then import one at a time. The original image for this German U-boat is 6238x2750. I've highlighted each 1024 panel in the first shot, then zoomed in to show the detail on the second.
I don't have good hull contour drawings for the Type VIIc, though I'll be able to rough something up from the limited cross sections and 3-views here.
Karl Bē is offline Find More Posts by Karl Bē
Old Jan 28, 2011, 04:34 PM
Kwok_Yu is offline
Maryland, USA
Joined May 2004
Karl Bē, how is you cut the picture into exact 1024x1024 panels? I also remember there was mention of a openGL setting. I forget in what context. I see there is one called "use max texture size".
-Kwok
Old Jan 28, 2011, 05:19 PM
Karl Bē is offline
Karl Bē's Avatar
Joined Jan 2003
I use Photoshop Elements and set the selection tool to 1024x1024, then create "new image from clipboard". Start the next square selection at the corner of the first, then select again and repeat. Just make sure the selection isn't feathered or anti-aliased, or the edges will be harder to join.
If the image editor of your choice makes it hard to select the exact regions, just overlap the selections slightly, then align in SU using transparency. It is important to select the exact size each time, to make rescaling accurate.
Old Feb 01, 2011, 08:45 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Dan5.0's Avatar
Joined Dec 2008
Just downloaded Google Sketch-UP. Is it fairly easy to use?
Dan5.0 is offline Find More Posts by Dan5.0
Old Feb 01, 2011, 09:21 AM
jcpatrick is online now
Find More Posts by jcpatrick
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
There is no other design software that is as easy or easier. Do spend time on their basic instruction videos, you can get farther in two hours with the free training than days on your own.
That goes even if you have CAD experience, since SketchUp has its own 'way' of doing things. For instance, there is no copy command, but copies are easy to make as modified Move or Rotate (hold Control key) commands, and multiple copies are modifications to that by either dividing the distance or angle, or by multiplying the instances. It may sound complicated, but the practice is far faster and easier than having separate copy and move keys.
jcpatrick is online now Find More Posts by jcpatrick
Idea How about a ''specific location/area'' video request thread? saucisse FPV Talk 7 Feb 03, 2010 05:23 PM
Wanted Will trade just about new Micro-T with extras for an 18t/b roller. sonicjet Cars - Cars and Parts (FS/W) 3 Jan 19, 2010 03:34 PM
Video Sketchup How to: Custom Firewall for an F4U tvcasualty Electric Plane Talk 8 Dec 14, 2009 02:59 PM
Mr. Lin: How about just a new gearbox housing? Highlander GWS (Grand Wing Servo) 14 Dec 24, 2004 07:59 PM
HOW do you delete a new thread i just made? how do you check your old ones? imaspaceguy90 Site Chat 3 Jul 03, 2004 01:32 PM
