Old Jun 23, 2010, 03:40 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Steve, I just had a play with a crude "boat" shape and after planking it using Kwok's triangles, I selected them all (one boat section at a time) and smoothed them using the Edit, nEntities, Smooth Edges commands. That's how I would get smooth airfoil shapes which are compound curves I think. Seems to work for boat hulls too!
The example is a bit rushed and rough and you would want to use more segments on the triangles but I think you can see the idea.
John
Originally Posted by SteveC68 View Post
SWEET! Thanks for that one.
jj604 is online now Find More Posts by jj604
Old Jun 23, 2010, 09:19 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
I tried the triangles thing, but it doesn't give a true hull shape. Just straight lines between the bulkheads. Although tedious what I ended up doing was dividing the bottom and sides of the bulkheads into equal numbers of segments. Then using the Arc tool to draw an arc between three bulkheads at each subdivision. Then the problem becomes making the result into a surface.
SteveC68 is offline Find More Posts by SteveC68
Old Jun 23, 2010, 04:19 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
I think that IS the problem because in my limited experience of Sketchup an arbitrary surface can only be constructed from edges that are in the same plane. All the curved surfaces I have seen are made from pushing arcs, follow-me etc. I've never found away to "fill in" an area that is not flat. That's why Kwok's solution works since a triangle, by definition, is coplanar.
Be interested in the technique if someone knows it.
John
Old Jun 23, 2010, 08:26 PM
JimnAz is offline
Find More Posts by JimnAz
Joined Mar 2007
John
This is really quite easy now if you want to use a plugin. Check out forums.Sketchucation.com site for the plugins by TIG and Fredo. They have extrude edges by rails, and curviloft respectively. I use both of these a lot in drawing fuselages and wings. The curviloft one is my favorite at this time.
Jim
JimnAz is offline Find More Posts by JimnAz
Old Jun 23, 2010, 08:54 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Thanks, Jim.
That's what I love about these forums. Someone always knows something useful you don't that solves a problem.
Regards, John
Jim
Old Jun 23, 2010, 09:02 PM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Yeah that one is going to need a tutorial.
Here is what I got with dividing edges and using the arc tool. Not nearly as good as a real loft, but better than straight lines drawn between points.
Old Jun 23, 2010, 09:28 PM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
I gave curviloft a try. Works pretty good. Just remember, the basics of subdivison is still there. And it depends on what your goal is. If for example, you want to unfold the skin, then you don't want it that complicated.
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Jun 23, 2010, 10:07 PM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Hot dang I figured it out! Works like a champ. Thanks Jim for posting that. I had been following some lofting plugins at the site you linked to but never could get them to work.
Old Jun 25, 2010, 05:10 AM
Kwok_Yu is offline
Maryland, USA
Joined May 2004
How do you draw a wing with a curve leading edge and a straight trailing edge, like the current European wing and stab have?
I was asked this question by someone. So I figure, I would answer it here as it could help others. And like I said before, I don't have that much experience with 3d surface modeling. So if you have a good method please post it. I gave it a shot with TIG's extrudeEdgesByRails plugin and I think it worked great. You can download all of TIG's extrude plugins in one zipped package here: http://forums.sketchucation.com/viewtopic.php?t=25362
Old Jun 25, 2010, 11:03 PM
Kwok_Yu is offline
Maryland, USA
Joined May 2004
Finished it up. Sorry, but I just notice the sketchup file is not the finished one. It seems I forgot to save at the end. So the one posted, is some intermediate file without the wing tips.
Old Jul 02, 2010, 08:48 PM
mack5 is offline
Find More Posts by mack5
Joined Jun 2004
hi everone
I been trying to draw curved wings for a f3b glider and some how I can not download the TIG's extrude plugins from the skup web page. I am getting a error message when I do. I regestred on the page but I can not down load any of the plugin.
Does anyone have this plugin that I can use?
Also how do you show the wing section, root and tip section for a curved wing?
Big thanks
Sorry for asking some of you off line such basic questions off line I do not wont to clog up this thred with basic questions
mack5 is offline Find More Posts by mack5
Old Jul 02, 2010, 09:29 PM
Kwok_Yu is offline
Maryland, USA
Joined May 2004
You should be asking the question here. That's what this thread is for. If you have the question, others will too. And it's easier to answer it once, instead of multiple times. You are not clogging up the thread, if it is on topic.
Download the plugin here: (deleted link, plugin is posted 2 posts below)
What do you mean "show"? You just draw the curves. I even provide the sketchup file above, to show how to draw the curves. Here is a quick video on how to use the plugin: http://www.mediafire.com/file/mzunj000qzm/TIG's extrude edges by rails plugin.wmv
Doing to tip is hard. I don't have a good method. You will have to figure it out later for yourself, after you learn the basics.
-Kwok
Old Jul 02, 2010, 09:48 PM
Kwok_Yu is offline
Maryland, USA
Joined May 2004
Actually this one get you real close to doing the whole tip in one shot. I just scaled down the tip airfoil really small.
Old Jul 02, 2010, 11:40 PM
JimnAz is offline
Joined Mar 2007
Originally Posted by mack5 View Post
hi everone
Big thanks
Here you go. Make sure you read the info on SKu Plugins forum and have the companion .rb's also.
Jim
Old Jul 04, 2010, 07:58 PM
mack5 is offline
Joined Jun 2004
curved wing
Hi
Thanks for all of you, Kwok_Yu your .wmy plays but it has no sound
Also how do you turn a line into a polyline?
Can you combine a .dat file with a wing out line to make a top / bottom wing?
JimnAz thanks for the file. I had to put in the SKup plugin folder befor the plugin worked. But it worked.
Idea How about a ''specific location/area'' video request thread? saucisse FPV Talk 7 Feb 03, 2010 05:23 PM
Wanted Will trade just about new Micro-T with extras for an 18t/b roller. sonicjet Cars - Cars and Parts (FS/W) 3 Jan 19, 2010 03:34 PM
Video Sketchup How to: Custom Firewall for an F4U tvcasualty Electric Plane Talk 8 Dec 14, 2009 02:59 PM
Mr. Lin: How about just a new gearbox housing? Highlander GWS (Grand Wing Servo) 14 Dec 24, 2004 07:59 PM
HOW do you delete a new thread i just made? how do you check your old ones? imaspaceguy90 Site Chat 3 Jul 03, 2004 01:32 PM
