Canary Islands
Joined Nov 2004
ArduIMU Quadcopter
Hi all, this is my new quadcopter project:
This time, this mini droid is able to flight alone. Take a look at the video, itīs funny... ![]()
Specs of this tiny quadcopter: Size: 28.5cm (rotor to rotor) Motors: 1811 2000Kv 10grams brushless motors Props: 5x3 (standard props, no counter rotating) ESCs: Turnigy 6A Batt: 2S610 Lipo Main board: ArduIMU+ v2 flat Sensors: 3 accels, 3 gyros, 3 magnetometers More sensors: Sonar (LV-EZ0), 4x Sharp IR sensors (GP2Y0A02) GPS: optional (Ublox or generic NMEA like MTKs) IMU algorithm : DCM (the one used in ArduIMU project) Telemetry: Xbee Pro Magnetometers, Sonar, IR sensors and GPS are optional sensors if you only like to fly like a normal quad... I am using standard props (no counter rotating) and mounted two of the motors tilted (see photos on the blog post part II) This time, the hardware (ArduIMU) really show itīs limits... itīs not a problem of CPU power, itīs a problem of the limited I/O (I had to use an external Arduino Pro mini to read the analog signals of the distance sensors), so I am starting to move this project to the big brother, the new ArduPilot Mega Hardware and the new sensor shield (not available yet). The original blog posts with more info and full codes are here: PartIII: http://diydrones.com/profiles/blogs/...opter-part-iii PartII: http://diydrones.com/profiles/blogs/...copter-part-ii (another video inside) Jose. |
South korea
Joined Dec 2003
you can easily make arduIMU quadcopter please read Diydrone jose blog part II.- http://diydrones.com/profiles/blogs/...copter-part-ii and I attached sensor diagram in part III.- http://diydrones.com/profiles/blogs/...opter-part-iii arduino is easy to program you can read ArduIMU manual.- http://docs.google.com/View?id=dp66935_12c9b5bd2c and uploading procedure is here - http://docs.google.com/View?id=ddjmq...07734034210443 and visit website http://arduino.cc |
Joined Mar 2010
does this quad part 3 requires arduimu alone or .. some other board to integrate with it ... any way how to code the board which code we have to use please advice in detail .. thanks |
Joined Apr 2011
Infrared sensors
Hi, I'd like to connect 4 Sharp IR sensors to my ardupilot mega ( http://code.google.com/p/ardupilot-m...ardwareDetails) for obstacle avoidance but i am not sure how to connect those sensors to my ardupilot mega physically. I have seen jose did it on diydrones website (http://diydrones.com/profiles/blogs/...opter-part-iii) but as far as i know he is using differnt IMU board. The IMU board i am actually using is this one (http://code.google.com/p/ardupilot-m...ki/IMUHardware). I know it is a stupid question but help me pls
.Just a summary of which pin to connect which. Thanks you in advance...
i like the ping-pong part
| Thread Tools | |
| Discussion ArduPilot, ArduShield v2, ArduIMU v2, Remzibi OSD with NMEA GPS (Tutorial) | HappyKillmore | UAV - Unmanned Aerial Vehicles | 620 | Feb 15, 2013 06:15 PM |
| Discussion ArduIMU+ V2 (Flat!) now available--$99 | zlite | UAV - Unmanned Aerial Vehicles | 37 | Mar 24, 2011 04:30 PM |
| Discussion ArduIMU released--first sub-$100 IMU/AHRS | zlite | UAV - Unmanned Aerial Vehicles | 43 | Oct 03, 2009 02:43 AM |
