I'd say virtually all of us love the XPS stuff for various reasons. I have the original internal module in my Evo 9 Tx. V 1.03 I think. I fly this at the NEAT Fair in NY each Septmeber with as many as 50 other planes in the air and 99% of them are on 2.4. This is why I love XPS "I HAVE NEVER HAD A Glitch there !!!" follow the link to a great electric event. http://www.neatfair.org/ scroll down to the two pictures. I took the one on the right with my XPS helicam a couple years ago. All electric event week following Reinbeck.
Al |
Maybe there is a PPM trainer connection and you can do like IvanC did to his 8FG running the Spektrum module from the trainer connection. If you only need 6 channels you might be able to build something out of a DX4e or you could build the short range version from the MLP4DSM or LP5DSM, it works just fine for short range (see DIY electronics section).
I used to have a Spektrum DM8 module for my 9CAPS but I was running out of model memories so I bought a DX6i to fly the UM stuff with and sold the Spektrum module. I'm not quite ready to say that was a mistake yet, but I dearly miss the Futaba now when I'm flying my UM fleet. Pete |
USA, CA, Piedmont
Joined Jun 2010
Do you have some boards that allow them to be easily connected as a serial device, with USB for attaching to a PC? I'm thinking of something like this: https://store.diydrones.com/Xbee_Tel...metry-xbee.htm And any chance of getting a pair of these to try out? |
Lake Havasu, AZ
Joined Jun 2005
We will have a simple modem board that allows serial communications. We do have a USB<>serial adapter, but it is not something that is required for our modules as they don't need to be programmed like the XBEE modules do. Our DivBee modules do not have a CPU, so they can be put into any design that has a SPI port. Our modem board has a PIC, LED, and push button switch. You can program them using any PIC programmer, but they will come with simple modem firmware already installed, complete with a custom IEEE MAC address. You can bind two units together for exclusive communications, just like you do with our transmitter modules and receivers. We were able to get the pricing down now to just $19.95 for the DivBee modules. The modem boards will be $12.95. Full schematics, PCB layout, and source code for the modem boards will be available at no cost.
I'll tell you what I need... I need a device that can transparently emulate a USB cable that is small and cheap and probably has a place to solder battery connections. Needs an A connector on one board and a B connector on the other (both full size). Not sure of the ultimate bit rate needed but I can say that range only needs to be about 10 feet which should help boost the bit rate. I might be able to fit the battery pack inside the device, need to open it when I finally find a solution that doesn't cost an arm and a leg.
Hahahaha. Homie said crashasaurous. Aaahahahahah. Careful Homie, you will be scorned at home ;-). I thought Id never hear the end of it when i switched.
Latest blog entry: Lil repair work.
I had an RF interference caused by a loose spark plug connector. The comment was that "my radio is better than yours." (JR flyer) In fact nobody's system is immune to that problem. That is the reason the connector is so difficult put on and take off when it fits right. The point is, a lesser known MFG will always be the problem rather than the "problem" being the problem. |
Reason: punctuation and spelling
Lake Havasu, AZ
Joined Jun 2005
![]() I was actually echoing what someone with vastly more knowledge about such things. I may have misunderstood what he meant too. If there is anything I hate is somebody conveying misinformation. Thanks again.
| Thread Tools | |
| For Sale XPS 8 & 10 channel RXs & Device Programmer | Wind_of_Change | Aircraft - General - Radio Equipment (FS/W) | 11 | Dec 10, 2010 04:19 PM |
| For Sale XPS sailplane 8 channel receiver | bruff | Aircraft - General - Radio Equipment (FS/W) | 1 | May 05, 2010 08:56 PM |
| Sold XPS 8 channel sailplane receiver | bruff | Aircraft - General - Radio Equipment (FS/W) | 2 | Apr 23, 2010 09:25 AM |
| For Sale XPS 8 and 6 channel receivers for sale. | mjpereira | Aircraft - General - Radio Equipment (FS/W) | 4 | Mar 18, 2010 05:34 PM |
| Sold Multiplex Royal Evo 7 W/ XPS Module & XPS 6 Channel Receiver | Yardbee | Aircraft - General - Radio Equipment (FS/W) | 0 | May 03, 2009 07:40 PM |
