This thread is privately moderated by rick121x, who may elect to delete unwanted replies.
Old May 12, 2010, 08:13 PM
rick121x is offline
Find More Posts by rick121x
Just a North Vegas flyer
rick121x's Avatar
North Las Vegas NV
Joined Mar 2002
Incidence meter
A few years ago when I was either too poor or too cheap to buy a real incidence meter, I found this sketch and made one. It was pretty easy, just using scrap stuff around the shop. The clamps slide with a little friction along the main bar - that is pretty easy to do: Just CYA the clamp around the bar, and it will be too tight --- then just sand the bar down a little and all is OK.
The needle is 0.047 wire in a 1/16 alum tubing sleeve for a bearing. I used very hard balsa for the clamps, and toughened it with CYA. My main stick is about 15 inches long.
You will have to figure out how to calibrate it - but that's part of the fun. A level table, some careful measurements for the clamp slots, and a protractor to set in some degree markers. And there you are - saved about $25
This little device actually does it's job as well as any commercial ones that I have seen. It's something you don't need often, but it is such a valuable tool at that time! Hey, I still use it !!!!
rick121x is offline Find More Posts by rick121x
Old Aug 24, 2011, 02:28 AM
TweakRacer is offline
Find More Posts by TweakRacer
TweakRacer's Avatar
United States, CA, Orange County
Joined Jan 2006
Cool DIY! Building one now. Thanks for the inspiration.
I found a similar project here:
http://www.modelflight.com/incidence.html
[Sorry for resurrecting this old thread, but it was just edited by the OP last month.]
TweakRacer is offline Find More Posts by TweakRacer
Sold Slot Machine, CG Machine and Laser Incidence Meter NumbSkull Aircraft - General - Miscellaneous (FS/W) 2 Mar 21, 2010 08:01 AM
Wanted Incidence Meter andernamen Aircraft - General - Miscellaneous (FS/W) 0 Mar 01, 2010 09:13 AM
Wanted great planes incidence meter and z- bend pliers greatplanes Aircraft - General - Miscellaneous (FS/W) 3 Nov 03, 2009 09:17 PM
Wanted Incidence meter biskit Aircraft - General - Miscellaneous (FS/W) 0 Sep 28, 2009 05:16 PM
Wanted Incidence Meter andygua Aircraft - General - Miscellaneous (FS/W) 3 Aug 24, 2009 04:56 PM
