Old Apr 22, 2012, 01:56 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Some more details.
Some more details about the RC etc...
All components sit on a 1.5mm glass fibre board.
Reciever: Jeti R6
Telemetry sensor: Jeti MUI 75 (voltage, current, used capacity)
ESC: Turnigy Sentry 40A
Control servos: HGD digital 250 MetalGear & Bearing
Release servo: Corona 939MG Metal Gear Servo
Julez is offline Find More Posts by Julez
Old Apr 22, 2012, 04:42 PM
Captn Don is offline
Find More Posts by Captn Don
Joined Jan 2007
A long wait
Gott segnen du Julez. LATER Captn Don
Captn Don is offline Find More Posts by Captn Don
Old Apr 22, 2012, 05:52 PM
Joined Jan 2007
tail boom
Julez; What is the tail boom length? LATER captn Don
Old Apr 23, 2012, 01:29 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hi Don,
whoopsie
I forgot that one while remodelling my CAD. I updated the main drawing. From the rear side of the rear main pole to the beginning of the tail, it is 605mm.
Cheers,
Julez
Old Apr 23, 2012, 03:37 PM
Joined Jan 2007
none
Julez: Vielen Dank. Captn Don
Old Apr 24, 2012, 05:36 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
You're welcome.
The next task will be to build a halfway decent canophy...
Old Apr 24, 2012, 04:10 PM
Joined Jan 2007
motor
Julez:What wattage motor and prop size? What size are the side tubes of the canopy? LATER Captn Don
Old Apr 24, 2012, 04:14 PM
Joined Jan 2007
Tubes
Let me qualify that I meant ask the diameter of the tubes. LATER captn Don
Old Apr 25, 2012, 05:50 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hi Don,
this is the motor I built:
http://www.scorpion.powercroco.de/12...4Scorpion.html
Due to my slightly inferior winding skills, I only got 7 and 7.5 windings instead of 8.
So I assume around 900kV. Any motor with that kV and no less than 130g mass should do the job.
I think I have some pictures of it at home...
I use a 12x5" Aeronaut Cam Carbon folding prop.
I generally prefer folding props to rigid ones, as they balance better. Both blades come from the same mold, and are thus perfectly identical in shape, weight, and mass distribution.
If that is the case with a rigid prop, depends on the skills of the toolmaker and the injection machine operator.
This setup pulls around 35A from a 3s pack.
I do not quite understand which tubes you mean.
The tube under the pack and the RC stuff, as well as the tail boom and the main poles, are 10x10x1 square tube.
The sail frame has a 10x1 center tube, and 8x1 side tubes.
The upper struts are 8x1, the lower ones 6x1, and the diagonal tube from behind the rear strut attachment point to the front of the sail frame center tube is 6x1 as well.
Cheers,
Julez
Old Apr 25, 2012, 07:31 AM
Joined Jan 2007
Tubes
Julez: The info from you is complete , Thank you. LATER Captn Don
Old May 08, 2012, 01:42 PM
Joined Jan 2007
almost complete
I am gathering partz 4 the rogallo .
I have a # 11 and # 16 cam. How did u mount the cam almost no vibes except during a dive to loop . Maybe show a picture of installation. LATER captn Don
Old May 11, 2012, 11:31 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hi,
you are a fast builder!
For the cam, I used a little piece of EPP foam shaped like a wedge with an appropriate angle. I cut a little groove in the top side, so that the side tube of the sail sits in that groove. I fixed the cam with the EPP wedge above it with scotch tape at the end of the tube that sticks out of the sail at the rear.
This way, the cam is pointed right at the "fuselage".
Old May 13, 2012, 03:20 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Elevator mixing
Hi guys,
we had a calm evening here, and I used it to program a little elevator mixing. Now I have a 3 position switch, which is either neutral, or has 10% down/12% up elevator mix.
This is quite useful for different wind conditions. Up for no wind, neutral for a little wind, and down to penetrate medium wind better.
As a bonus, I discovered that the "up" position increased my flight time around 20%.
Old Aug 12, 2012, 02:32 PM
llamareto is offline
Find More Posts by llamareto
Joined Oct 2008
electric rogallo
Hello julez, could you put some general pics of your electric rogallo model?. Im going to try to built it for FPV purposes.
I need to see how you link sail tubes too.
Thanks.
llamareto is offline Find More Posts by llamareto
Video kite plane thrown friz Electric Plane Talk 13 Apr 21, 2010 08:39 AM
New Product Smaller version of Joel K. Scholz Hawkeye blimppilot Minnesota Area Radio Control Electric Enthusiasts (MARCEE) 1 Mar 10, 2010 02:40 PM
Sold Large Rogallo, Flying Kite (???) VasMan Aircraft - Electric - Airplanes (FS/W) 20 Apr 11, 2008 05:46 PM
