Old Dec 31, 2011, 02:32 PM
Captn Don is offline
Find More Posts by Captn Don
Joined Jan 2007
New Year
Julez:Guten Rutsch
Captn Don is offline Find More Posts by Captn Don
Old Jan 07, 2012, 01:01 PM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
Hallo Captn Don, vielen Dank, sehr freundlich.
Thank you very much, very friendly. I hope you had happy holidays as well.
I finally found the time to make some detailled images.
I hope most things are explaine by the images. I will post CAD drawings of the sail and its frame, as well as of some small parts soon.
One must be careful when assembling the side struts. I recommend this glue:
http://www.hobbyking.com/hobbyking/s...Strength_.html
It is the best one I found so far. When I tried it on a stainless steel bolt, I bent the bolt rather than being able to unscrew the nut.
One needs M4 Bolts as in the picture, and aluminium pipe. The small piple is sufficient for the lower struts, as these are only loaded by tension. The upper side struts must be made of thicker pipe, or it will be bent by the pushing force. Ask me how I know...
The head of the bolt is removed, and the stub is glued into the 6x1mm pipe. A6mm piece of 1mm music wire is glued in as a locking pin. This makes the lower side struts. for the upper side struts, the aluminium pipe is sawed off with 20mm lenght, and glued in the 8x1mm pipe.
The threaded part of the bolt is cut to the correct length, and the clevises are screwed on with some force, until the openings match the cointerpars on the frame. The upper side struts are identical, the lower side struts have a left and a right piece.
The landing gear is made from 4mm music wire, and supported by 3mm wire. The wheels are 100mm diameter.
Cheers,
Julian
Julez is offline Find More Posts by Julez
Old Jan 07, 2012, 10:43 PM
Joined Jan 2007
Electric Rogallo
Julez: What I wanted are the dimensions of the electric Rogallo just like the one in the video. Everything out in the open. The one in the video (teaser) fly's so very well. LATER captn Don
Old Jan 08, 2012, 09:14 AM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hi Don,
I'll post those soon as well. The information about the glow version are for taqrc, he asked about them.
Cheers,
Julian
Old Jan 10, 2012, 03:35 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Wow ! That kite plane is very stable when flying, ideal for AP.
Very impressive.
I think I have just found my next project
sparklet is offline Find More Posts by sparklet
Old Jan 23, 2012, 02:14 AM
taqrc is offline
Find More Posts by taqrc
Joined Nov 2007
Still waiting for Plans
Hi,
Still waiting for the plans to build the sail ... Please send the length of the spars
taqrc is offline Find More Posts by taqrc
Old Mar 01, 2012, 12:42 AM
taqrc is offline
Joined Nov 2007
info required
hi,
still waiting for the exact dimensions of the sail.. i.e lengths of all three arms .. span, length of the sail etc.
Old Mar 09, 2012, 12:27 PM
GUNNERTONPANDA is offline
Find More Posts by GUNNERTONPANDA
Joined Feb 2010
Having the prop there makes sense,the prop on my Skyflex tore the wing. Interesting as I am planing to get mine flying again. Mine was the one with all the string rigging,& it is a bit of a fuss to store.I will be following this to see if I can convert to do away with the rigging.
Brian
GUNNERTONPANDA is offline Find More Posts by GUNNERTONPANDA
Old Mar 14, 2012, 11:40 AM
Joined Jan 2007
All together now 1 2 3
Julez: Wip lang braucht man nach feiern???? LATER captn Don
Old Apr 10, 2012, 09:13 AM
Joined Jan 2007
Dimensions????
Julez:Exact details are not needed now. Just the basic dimensions of the sweep angle of the L.E. and lengths of L.E.
The length of the cross over spar and attachment point.
The length of the wing struts and attach point.
The length of the two vertical wing attachments and the attachment point on the center spar.
The dimensions of the tail groups( rudder,stab-elevator)
The fuselage length and attach points
Basic sail dimensions.
Landing gear dimensions .
Please get the ruler out and give to us the basic parameters.
THANKS Much Respectfully captn Don
Old Apr 11, 2012, 05:40 PM
Joined Jan 2007
Drawing
Julez : Just fill in the dimensions.
Old Apr 22, 2012, 02:10 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
Hi friends,
I am awfully sorry for my long absence.
But I can hope to make everything good by finally posting some extra-detailled plans for the SuperSkyflex.
First comes the CAD.
Some more info: The upper struts, made of 8x1mm aluminium pipe, have a bolt-to-bolt length of 720mm The lower struts, made of 6x1mm aluminium pipe, have a bolt-to-bolt length of 815mm.
The upper strut connector has a hole distance of 32.5mm.
When all comes together, the sail should have 90-100mm dihedral at the point of the strut attachment.
The tube under the pack and the RC stuff, as well as the tail boom and the main poles, are 10x10x1 square tube.
The sail frame has a 10x1 center tube, and 8x1 side tubes.
The upper struts are 8x1, the lower ones 6x1, and the diagonal tube from behind the rear strut attachment point to the front of the sail frame center tube is 6x1 as well.
The wheels have a diameter of 85mm.
Old Apr 22, 2012, 02:22 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
The struts.
Here come some detail images.
At first the struts.
Old Apr 22, 2012, 02:44 PM
Julez is offline
Julez's Avatar
Germany
Joined Dec 2003
The landing gear.
The landing gear.
Note that the holes in the smaller plate ,which is bolted to the square pipe using countersunk bolt heads, allow the bolt heads from the main plate to lock in place into them, when the rubber bands are attached. This way, the landing gear is fixed, but can rip off in a crash or band landing without damage.
The wheels have 85mm diameter.
The wire is 3mm music wire.
Video kite plane thrown friz Electric Plane Talk 13 Apr 21, 2010 09:39 AM
New Product Smaller version of Joel K. Scholz Hawkeye blimppilot Minnesota Area Radio Control Electric Enthusiasts (MARCEE) 1 Mar 10, 2010 03:40 PM
Sold Large Rogallo, Flying Kite (???) VasMan Aircraft - Electric - Airplanes (FS/W) 20 Apr 11, 2008 06:46 PM
