This thread is privately moderated by Lafayette, who may elect to delete unwanted replies.
Old Jan 22, 2011, 11:03 AM
RightcoastRC is offline
Find More Posts by RightcoastRC
Professional Pixel Flyer....
RightcoastRC's Avatar
United States, VT, Weathersfield
Joined Dec 2005
Going to subscribe to this, I have never used monocote, or any other covering at all, I dont have a covering iron either, will have to look for one!
What kind of temps are you using safely on the covering jobs over foam?
RightcoastRC is offline Find More Posts by RightcoastRC
Old Jan 23, 2011, 02:33 PM
Lafayette is offline
Find More Posts by Lafayette
'scuse me while I kiss the sky
Lafayette's Avatar
Joined Nov 2009
If done right, you do not need to iron on the film on solid foam. I just use a light spray of 3MSuper77, and then i place film on the foam. Then I use a small block of blue core to smooth out the film and make sure it adheres well. Do not use sharp edges as not to sctrach the film or put some indentations in the foam.
As for temp if you use it on rib covered wings, start low/med. It all depends on the iron you use. Experiment. (DO NOT MELT THE FOAM!!!
Monokote and such have a glue layer built in that is activated by heat.
But a covering job done well should not require extensive shrinking, it should be tight an wrinkle free already. Of course certain corners, or odd shape parts being covered will need some smoothing out the wrinkles.
Just make sure to protect the aeras you do want to be prayed with the glue well. That stuff is sticky!
Try some on scrap pieces of foam and see the results. Experimenting is what led me to this "poor man's monokote"!
Post some pics of the results if you can.
I have a big wing that I will cover soon. I will post the picture of the process I use.
Have fun,
Lafayette.
Lafayette is offline Find More Posts by Lafayette
Old Jan 25, 2011, 12:02 PM
ediaz is offline
Find More Posts by ediaz
ediaz's Avatar
Orlando, Florida
Joined Nov 2004
I bought 4 rolls of this film at Dollar Tree yesterday. No I just have to figure out what I'm going to cover. My wife would call this Impulse buying.
Thanks for the tip and the postings.
Evelys
ediaz is offline Find More Posts by ediaz
Old Jan 26, 2011, 02:05 PM
Lafayette's Avatar
Joined Nov 2009
Evelys[/QUOTE]
Well, when I went to look for more and had a total of like 25 or more rolls, I got the rolling eyes!!!
I have left some pieces I covered in my non heated "Hangar" temps reaching near zero and all seems to hold well. Streched or just glued on.
We will see in the spring how it all held up!
Lafayette
Old Feb 18, 2011, 11:24 PM
Lafayette's Avatar
Joined Nov 2009
Just covered some dollar tree foam board, 3m77 light spray. Do not use too much it will make a soggy spot and pool under the film. I kept the paper on the foam which makes it stronger, a new tail for my custom SS. Going to cut wing cores, 1 with similar profile but full not hollow, and trying another as well.
The film will protect nicely.
I plan on covering the foam wing as well.
I might use white bead foam for the core, with a layer of FFF on the bottom for added strength.
Old Mar 10, 2011, 09:24 AM
derk is online now
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
so has anyone used this process on a balsa model yet?
i am finishing up the frame on a micro glider and wanted to try some of this for covering.
derk is online now Find More Posts by derk
Old Mar 10, 2011, 10:23 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
I have not, but I have done a silmilar thing with other plastics. I use a frame to hold the plastic fairly 'taut' and this can be cardboard with tape, staples, etc. Find a way to hold your framework, and mist 3M super 77 spary glue to the framework. Lay your frame over the frame, and use a finger to adhere along all the structural pieces.
Be careful if thinking of shrinking with heat, try to get the covering faily tight to begin with.
Testing on a quick box frame is reccomended!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jun 13, 2011, 07:12 AM
old foamie is offline
Find More Posts by old foamie
old foamie
Joined Oct 2007
I was thinking if it would work on a built-up foam wing and fuse , like on old timers built of balsa?
old foamie is offline Find More Posts by old foamie
Old Sep 29, 2011, 12:13 PM
Have_Blue is offline
Find More Posts by Have_Blue
United States, WI, Milwaukee
Joined May 2009
I'm wondering if spraying a fusible adhesive onto the film would allow you to make a truly iron-on covering: http://www.sewforless.com/item/606_F..._Adhesive/1228
Have_Blue is offline Find More Posts by Have_Blue
Old Dec 30, 2011, 04:57 AM
Lafayette's Avatar
Joined Nov 2009
Seems 3m77 will leave opaque residue on the film...
Old Jan 16, 2012, 09:33 AM
nakelp86 is online now
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Subscribed :-)
nakelp86 is online now Find More Posts by nakelp86
Old Jan 16, 2012, 04:04 PM
Lafayette's Avatar
Joined Nov 2009
Building a Lazercuts Hydro Extreme. I had considered glassing it, but I think I will just cover the whole thing with the $1 wrap and 3M77. It will give it color, protection and make it slick!
Will post pics when I do it.
Old Jan 27, 2012, 03:40 AM
Lafayette's Avatar
Joined Nov 2009
Covering dollar tree poster board
This is also a great way to keep the paper on the poster board for strength and covering it for color and protection. A bit of water, dew from the grass can ruin your day...
Good protection super light weight, protect your work!
Old Jan 30, 2012, 01:13 AM
Lafayette's Avatar
Joined Nov 2009
Experimenting with some stuff I used years ago. I should cover nicely, and it is super tough and light.
A plus would be that it may could take any type of paint.
Will post results when available.
Old Feb 13, 2012, 08:34 PM
OutcastZeroOne is offline
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
must remember this. I just got a rool of blue and clear wrap to play with. worst case I can use the stuff to wrap gifts with :P
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Discussion Remzibi OSD (Poor Man's OSD) integration with ArduPilot HappyKillmore FPV Talk 543 Apr 07, 2015 12:27 PM
Discussion Clancy Turbo Bee - Poor man's EDF pburress Parkflyers 125 Jan 15, 2011 04:33 PM
Poor man's story (sharing info) StCalvin Other Websites 2 Oct 09, 2009 03:06 AM
Poor man's story (sharing info) sleb Other Websites 1 Sep 22, 2009 12:22 AM
Yippee! Poor Man's Pre-Rotator for Autogyro! jodini Auto Gyros 23 Sep 06, 2009 12:41 PM
