Old Jun 09, 2003, 05:02 PM
asennad is offline
Find More Posts by asennad
asennad's Avatar
Joined Jun 2003
Looking to get back into RC..need plans
After a long absence I am looking to get back in to RC. I would like to try a speed 400 model. Something simple to build and fly.
I would prefer to build it myself from plans, all balsa, 3 channel and with ailerons.
I came across this model the ELECT J that I liked but it is without balsa thicknesses:
http://plans.rcmodell.hu/planelect.html
Any other plans or balsa suggestions please.
asennad is offline Find More Posts by asennad
Old Jun 09, 2003, 10:37 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Blowing my own trumpet here, but look up Radio Control Modeler magazine's plans listings. I've got a design in there called "Squert" which is just what you're after.
Designed when I lived in England and all we could buy were 7.2V motors and 600 AA sized nicads, "Squert" was possibly the first aerobatic S400 model flown there. It really is basic, a box section fuselage, shoulder wing mounted with glue, which is good for hand launches, and a bottom hatch to make changing packs easy. With 8 modern cells and a 6V S400, it should go pretty quick.
Structure is very light, easy to build - if you like woodwork. The plan was published in 1994, but they still crop up. Two showed up at our club's electric funfly last year.
regards
Dereck
Dereck is offline Find More Posts by Dereck
Old Jun 10, 2003, 02:28 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Heck, you don't really NEED a plan.
Build a traditional balsa wing of about 36-40" span and give it 8 degrees dihedral.
Make up a balsa box fuselage and some built up tail feathers, trim it all up zero zero (tailplane to wing flat bottom)
Get a 6v 2.33:1 geared 400, a 7 or 8 cell pack and 12A ESC, 8x6 or 9x6 APC 'E' prop, put HS55 servos on elevator and rudder, and fly...CG around 30% chord.
As long as the weight is under 22oz, it will fly. Under 20oz it will fly well, at 18oz it will rock :-)
When you get bored with that, make a new wing with only a couple of degrees dihedral and strip ailerons, and another servo...and have fun rolling it as well.
Seriously, thats all you have to do.
Old Jun 10, 2003, 04:09 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
And when you get bored with that, build another new wing with NO dihedral, a semi-symetrical section and a Mega 1615/5 up front, so you can practice vertical rolls and low inverted passes.
Call it a Minibat if you like......(flies well on a direct drive S400 too).
http://www.rcgroups.com/forums/showt...hlight=minibat
tim
tim hooper is offline Find More Posts by tim hooper
Old Jun 10, 2003, 04:36 PM
asennad is offline
asennad's Avatar
Joined Jun 2003
Thanks all for the advice. I found plans for the SQUERT on the net and will use it as a guide for my own design.
That Minibat is exactly what I want to be flying when I have a little more experience.
Old Jun 11, 2003, 08:47 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Asennad, Welcome to the Ezone!
GregG is offline Find More Posts by GregG
Discussion looking for a run little RTF to get back into planes. STANG KILLA SS Foamies (Kits) 6 Jan 05, 2007 09:36 AM
Discussion Looking to get back into the hobby..... Tophinater Electric Plane Talk 20 May 16, 2006 01:47 PM
Discussion Looking to get back into Flying fallenangl Beginner Training Area (Aircraft-Electric) 2 May 11, 2006 09:47 PM
looking to get back into it festis9 Club Talk 1 Apr 23, 2005 10:39 PM
Getting back into RC flying. Need advise!! NorCalFlyer Sailplane Talk 3 Oct 07, 2004 07:09 AM
