This thread is privately moderated by fishfingers, who may elect to delete unwanted replies.
Old May 09, 2010, 07:09 PM
fishfingers is offline
Find More Posts by fishfingers
Trader Rating: 1
Murfreesboro
Joined Jun 2009
Trader Rating: 1
Sold
E-flite 60A Pro ESC
Key Features
* Up to 60-amp continuous current with proper air flow, 75-amp peak
* 5-volt Switch-Mode BEC circuit capable of 2.5-amp continuous current on any recommended input voltage
* Drives up to 7 analog or 6 digital standard-sized servos, with the BEC on any recommended input voltage
* 3–6S Li-Po, 9- to 18-cell Ni-Cd/Ni-MH input voltage
* Finned heat sinks
* Programmable motor braking
* Safe power-arm mode prevents accidental starts
* Programmable low voltage cutoff with settings for 3-cell Li-Po (9V), 4-cell Li-Po (12V), 5-cell Li-Po (15V), 6-cell Li-Po (18V), or 70% of battery starting voltage
* Programmable soft start for helis and airplanes
* Auto motor shut down if signal is lost or there is interference
* Programmable timing—5 user-selectable ranges for use with a larger variety of brushless motors
* Programmable throttle input range (1.1–1.9 ms or 1.2–1.8 ms)
* Utilizes new smaller MOSFETs technology to minimize weight
* Radio System Power On/Off Switch
* Optional RS232 Serial Link available for programming
* Pre-wired connectors—E-flite EC3 on battery input and 3.5mm female gold bullets on motor output leads
Overview
When performance matters in your high-current applications look no further than the E-flite® 60-Amp Pro Switch Mode ESC. This is a high-quality, efficient sensorless brushless electronic speed control with an integrated Switch-Mode BEC. It can operate without the need for a separate receiver battery to power your servos and receivers, saving you weight and complication. It is capable of up to 60 amps continuous current when using 3- to 6-series Li-Po battery packs. You can drive up to 7 analog or 6 digital standard-sized servos with the BEC on any recommended input voltage. Featuring an exposed, finned heat sink aluminum case with lightweight plastic endcaps, safe power-arming along with advanced programmable features such as low voltage cutoff, braking, timing, throttle input range, and more, the E-flite 60-Amp Pro Switch Mode ESC is truly a ‘pro series’ electronic speed control.
Brand new in package. $65 shipped conus.
fishfingers is offline Find More Posts by fishfingers
Found Used E-Flite 60A ESC btpalc Aircraft - Electric - Power Systems (FS/W) 0 Apr 24, 2010 07:46 PM
Sold E-flite 60a PRO ESC/$60 shipped aaflyer60 Aircraft - Electric - Power Systems (FS/W) 3 Mar 14, 2010 12:15 PM
Discussion E-Flite 60A ESC caps - 470uF ---> 1000uF? rampman DIY Electronics 13 Jan 04, 2010 10:31 PM
Sold E-Flite 60a Pro ESC birdy233 Aircraft - Electric - Power Systems (FS/W) 4 Oct 25, 2009 03:23 PM
Question E-Flite Pro 60a ESC throttle response, similar to CC Phx? eckcessive Power Systems 2 Feb 11, 2009 12:42 PM
