Old May 09, 2010, 03:23 PM
kyle7119 is offline
Find More Posts by kyle7119
United States, IA, Cedar Rapids
Joined Aug 2009
1/2 wavelength antenna for Corona RP8D1
I am going to extend the antenna on my Corona RP8D1, but I have some questions about how to do this. First of all, I noticed that the wire for the antenna is very high guage (small diameter). I have some 22 guage wire at home, but this is bigger than the stuff used on the antenna. Will it hurt to use some of the 22 guage wire to extend the antenna? Also, what length do I need to extend it to in order to reach 1/2 wavelenth?
I know that this is a kind of non-related question, but how far are you guys getting for your range checks with your Corona RP8D1 recievers with the 1/4 wavelenth antennas?
kyle7119 is offline Find More Posts by kyle7119
Old May 09, 2010, 04:51 PM
Kmart is offline
Find More Posts by Kmart
Kmart's Avatar
United States, CO, Boulder
Joined Sep 2008
1/2 wavelength- so 1/2 the wavelength of your frequency. Plug some digits in here:
http://www.csgnetwork.com/freqwavelengthcalc.html
be careful about a smaller guage wire- it will be heavier, and the solder point might not be able to hold it.
Kmart is offline Find More Posts by Kmart
Old May 09, 2010, 09:38 PM
kyle7119 is offline
Joined Aug 2009
I un-soldered the old antenna and soldered a new 1/2 wave antenna on using 22 guage wire. My solder joint appear to be able to hold the wire. I am now getting 130 paces for a range check in an urban environment (compared to the original 90 paces). At this distance, though, there is a noticable delay between when I throttle up and when the motor responds. Is that normal?
Old May 09, 2010, 10:52 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
nope.. what about your other surfaces?
ashdec87 is offline Find More Posts by ashdec87
Old May 10, 2010, 02:55 AM
patricklupo is online now
Find More Posts by patricklupo
Joined Jul 2009
I have two Corona RP8D1's and have always noticed a slight delay in servo/throttle response from both, with the normal 1/4 antenna. They're also inncompatible with the Flytron headtracker (causes severe stuttering) and one of them regularly flakes out on me. I like the range and failsafe feature but not the inherent latency, lack of precision and just don't trust them.
patricklupo is online now Find More Posts by patricklupo
Old May 10, 2010, 05:47 AM
areis81 is offline
Find More Posts by areis81
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
kyle, some times ago i posted almost the same question. hope this thread will help you out!
http://www.rcgroups.com/forums/showthread.php?t=1223539
areis81 is offline Find More Posts by areis81
Old May 10, 2010, 10:20 AM
aaron_gx is offline
Find More Posts by aaron_gx
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
Question about impedance... How can this be measured? Idealy, based on IBcrazy's remarks in the above thread, you want to maintain a 50ohm load on the the receiver. Where about do you measure from and to? I'd like to extend my RP8D1's to 1/2 wave also, but want to tinker to get it as good as I can.
Or, instead of measuring impedance, do we measure RSSI on a range test to find the best real-world results at various lengths? (i mean 1/2 wavelength +/- a few inches to compensate for base-loading)
aaron_gx is offline Find More Posts by aaron_gx
Old May 10, 2010, 11:03 AM
areis81 is offline
RC Wannabe!
areis81's Avatar
vercelli, ITALY
Joined Dec 2009
if it can be useful, i've been suggested to choose the antenna length meanwhile measuring RSSI...
is this right?
Discussion How do I set up the Corona RP8D1 RX ? Mr. Farknocker Power Systems 9 May 18, 2012 03:00 PM
Discussion 1/2 wavelength 72 Mhz justind123 FPV Talk 10 Apr 14, 2010 08:01 PM
FAQ Antenna Corona RP8D1 Arno de Bliek Radios 1 Sep 18, 2009 04:36 AM
Discussion 1/4 wavelength calculation and antenna length Fly2High Hand Launch 6 Jul 05, 2007 03:11 PM
