Old May 09, 2010, 08:24 AM
xavier3596 is offline
Find More Posts by xavier3596
Joined Apr 2009
2.4ghz transmitter based on STM8S + corana DIY 2.4 ghz + Futaba skysport case
Hi all,
here is my nearly finished project of 2.4ghz transmitter.
http://sites.google.com/site/stm8sdi...-2-4ghz-module
It is based on the new cheap µcontroller board STM8S discovery for ST (about 10$ with USB debugger included) and the Corona DIY 2.4ghz module.
http://www.st.com/mcu/contentid-130-...DISCOVERY.html
Here the features:
- 7 channels (8 possible but I need only 7 channels for my electric glider (4 servos by wing, brusless controller,elevator and rudder )
- 4 memories (can be selected at startup with master/slave switch with beep selection)
- 1 switch (2 positions) for butterfly
- 1 switch (2 positions) for Throttle Cut
- 1 switch (3 positions) for 3 flight conditions
- 16 mixers
- 9 points curbs for the 4 input sticks
The configuration is made with PC with python script
http://sites.google.com/site/stm8sdi.../configuration
I will post source code for the transmitter and the tools for configuration in the following days
Regards
Xavier
xavier3596 is offline Find More Posts by xavier3596
Old May 09, 2010, 02:39 PM
Joined Apr 2009
Hi
I have uploaded on my web site the python script to generate the model configuration for the transmitter. The generated file has to be uploaded to the STM8S flash memory with ST tools.
Python v2.6 must be installed.
Not compatible with python 3.x
http://sites.google.com/site/stm8sdi...edirects=0&d=1
Regards
Xavier
Old May 12, 2010, 05:01 AM
CrashingDutchman is offline
Find More Posts by CrashingDutchman
CrashingDutchman's Avatar
The Netherlands, Utrecht, Amersfoort
I am going to follow this, I just ordered a STM8S. Let's see how it compares to Arduino.
CrashingDutchman is offline Find More Posts by CrashingDutchman
Old Mar 26, 2012, 12:13 PM
Bracame is offline
Find More Posts by Bracame
Apprenti
Bracame's Avatar
France, Basse-Normandie, Négreville
Joined Oct 2011
Question
Hello from France (ans sorry for my english !)
Great job !
I wonder how to reprogram my poor skyartec sky705 witch have a stm8s too.
The usb interface is a ch372 ans i don't know if i can use it for reprogrammation.
If not, where could i find a "st link" ?
Here's a photo of the board
Thank you
I hope it is not to late !
Bracame is offline Find More Posts by Bracame
Old Mar 29, 2012, 06:50 AM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
Blows it away, in terms of on-chip peripherals, and due to being able to debug/step through code while it runs. including watching memory/variables, etc. Why would anyone start a new project in 2012 with arduino is unknown
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Aug 07, 2012, 06:38 PM
Bracame is offline
Apprenti
Bracame's Avatar
Joined Oct 2011
News (in french)
http://www.modelisme.com/forum/aero-...ce-maison.html
Old Aug 11, 2012, 02:25 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Can you post the pictures of your transmitter also here
msev is offline Find More Posts by msev
Old Aug 12, 2012, 11:40 AM
Bracame is offline
Apprenti
Bracame's Avatar
Joined Oct 2011
Ok, the picture are here :
Old Aug 12, 2012, 11:43 AM
Bracame is offline
Apprenti
Bracame's Avatar
Joined Oct 2011
Google code :
http://code.google.com/p/bracame-rc-radio/
I can help interested people.
Old Aug 12, 2012, 01:44 PM
msev is offline
Joined Sep 2010
Do you plan on adding some additional functionallity? I have some ideas
Old Aug 12, 2012, 02:50 PM
Bracame is offline
Apprenti
Bracame's Avatar
Joined Oct 2011
Yes ! Program memory is not full ... (32 k)
Do you know stm8 ?
Old Aug 12, 2012, 03:04 PM
msev is offline
Joined Sep 2010
No unfortunately I can't code, its not my field of expertise..I'm studying pharmacy...So I can't help in this area.
Well one idea would be to interface a Nunchuck via I2C, the accelerometer and the small joystick and buttons could be used for example for operating a pan-tilt servo mounted camera on a plane.
Another more exotic idea would be to interface it to a speaker+sd card shield so the transmitter could talk to you when you flick a switch it would say, "switch in high position" for example (this is already implemented in er9x project for example).. Its useful for fpv..
Personally I would need more 3-way switches added..
I have transmitting modules from turnigy 9x, it would work right? Can ppm stream be changed in code from negative to positive if needed?
You are using stm8discovery right?
Old Aug 12, 2012, 03:15 PM
Bracame is offline
Apprenti
Bracame's Avatar
Joined Oct 2011
Yes stm8discovery ,
I uses all I2C port of my stm but i plan to use a motion plus in analogique mode (later)
Old Aug 12, 2012, 03:20 PM
msev is offline
Joined Sep 2010
A gyro? What do you plan to do with it?
Old Aug 14, 2012, 03:54 AM
Bracame is offline
Apprenti
Bracame's Avatar
Joined Oct 2011
motion plus can drive all 3 axis
http://diydrones.com/profiles/blogs/...flights-with-a
It is not my priority for the moment, will do that later ....
Sold Futaba 2.4GHz TM-8 Module and R608FS 2.4 GHz Receiver Maarksc Aircraft - General - Radio Equipment (FS/W) 0 Mar 11, 2010 09:21 PM
Question 2.4 Ghz Technology based on..? shifteroo Radios 11 Dec 06, 2009 04:19 PM
Sold Futaba 2.4 GHZ 6EX Transmitter and R606FS magkat Aircraft - General - Radio Equipment (FS/W) 0 Oct 10, 2009 02:36 PM
Sold 2.4 Ghz Systems - JR X9303 2.4Ghz Transmitter-Price dropped! sweetrds Aircraft - General - Radio Equipment (FS/W) 5 Mar 05, 2009 06:32 PM
Sold 2.4 Ghz Systems - JR X9303 2.4Ghz Transmitter-Price dropped! sweetrds Aircraft - General - Radio Equipment (FS/W) 4 Mar 03, 2009 11:52 PM
