Old May 08, 2010, 03:51 PM
Martin V is offline
Find More Posts by Martin V
Joined Mar 2007
Headplay wont boot. battery Voltage and pinout?
It looks to me like:
1. Vbatt (nearest edge of circuit board)
2. Vbatt
3. Not Connected
4. Ground
5. Ground
The circuit board had a + symbol by pin 1-2 and - symbol by 4-5.
Battery and ground connections ohm out to be in parallel, but maybe this is where I went wrong.
Well I was fairly certain this was correct so I hooked up a 12v lipo to pin 1 and 5. The power light stayed on momentarily then powered off.
Now the unit does not stay on, the goggles show the boot screen momentarily then power off.
After looking further I did find an IC that is getting hot after trying to boot a few times. It's a fancy 5V and 3.3V regulator IC (#6232caz).
Martin V is offline Find More Posts by Martin V
Old May 08, 2010, 07:10 PM
IL76MD is offline
Find More Posts by IL76MD
fly it high as possible
Falls Church, VA
Joined Jun 2009
2. Vbatt
3. Not Connected
4. Ground
5. Ground
Internal battery has 7.4V not 12V and you should connect 12V lipo to external
connector, where charger with 12V output usually been connected.
Hope it is not too late.
IL76MD is offline Find More Posts by IL76MD
Old May 08, 2010, 11:27 PM
Kul is offline
Kul
Find More Posts by Kul
Kul
Aerodynamics Grad Student
Joined Dec 2007
I did exactly that and now my Liberator does not light up as well.
Kul is offline Find More Posts by Kul
Old May 08, 2010, 11:57 PM
Martin V is offline
Joined Mar 2007
Looks like we have another project to work on
Turns out the power supply is fairly complex. This may be very difficult to troublshoot without a schematic. I've been tracing out the power supply and found a IC that controls the battery charging, another that outputs a 5.5V and 3.3V supply. Three Mosfet ICs that appear to be used for switching.
It seems something further down the line is giving some feedback to tell the power supply to shut down. My fear is it could be one of the big ICs is damaged causing excess current draw. If this is the case I think were out of luck.
In the meantime I may get some $100 goggles off ebay, and will probably be happier, even if I fix the Deadplay goggles.
Old May 09, 2010, 12:19 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Have you tried 12 volts going into the chargeing plug?
I can't remember but think center pin is positive? better make sure of that.
Its an odd ball plug with a thinner center connection, so make sure that is touching to make contact.
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old May 09, 2010, 02:01 AM
Martin V is offline
Joined Mar 2007
I tried the power supply that came with the unit, but the same problem exists. It appears the problem is further down stream.
Old May 09, 2010, 09:01 AM
OhhYeah is offline
Find More Posts by OhhYeah
Joined Sep 2003
Yes, the center pin is positive. I rigged my unit (through the 'DC in' port) with a 3S lipo - it works fine and regular battery changes are easy.
OhhYeah is offline Find More Posts by OhhYeah
Old May 09, 2010, 06:14 PM
Kul is offline
Kul
Kul
Joined Dec 2007
Have you found any tiny fuses at the inlet. Perhaps one of those blew.
Old May 09, 2010, 07:22 PM
Martin V is offline
Joined Mar 2007
I found a couple what appear to be PTC reseting type fuses, but they are not damaged. I've traced the battery and power supply quite a ways into the unit so I know power is getting to most of the circuitry. It seems to be more a case of what is cuasing the unit to power back off?
I wonder if Headplay support would give us any clues. I'm guessing they would rather get us to buy another Liberator.
Old May 09, 2010, 07:36 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Unfortunatly I don't think they sell liberators. Only new sets of goggles.
bracky72 is offline Find More Posts by bracky72
Old May 09, 2010, 10:42 PM
David22 is offline
Joined Apr 2008
email headplay dirrect they have great customer support via email
hard to get a hold of them via phone line
Old May 10, 2010, 01:07 PM
Kul is offline
Kul
Kul
Joined Dec 2007
email headplay direct they have great customer support via email
I've tried a few times when I had a problem with the optics but since I bought my goggles used from someone else they refused to help me. I ended up opening the goggles and fixing the optics myself.
UPDATE: I asked someone else to look at my liberator and they found that I did have a burned fuse after all. It powers up again.
Old May 10, 2010, 02:50 PM
mr..speed is offline
Find More Posts by mr..speed
mr..speed's Avatar
near Stgt/Germany
Joined Feb 2003
How did you open the liberator ? any pictures ?
mr..speed is offline Find More Posts by mr..speed
Old May 10, 2010, 03:38 PM
Martin V is offline
Joined Mar 2007
Can you find out which fuse it was in case I missed one? I think the fuses all have a reference number like f1, f2....
Old May 10, 2010, 10:37 PM
Kul is offline
Kul
Kul
Joined Dec 2007
I'll try to take pictures later. I think I'll install a fuse and a a AnyVolt voltage regulator between the lipo and the Liberator before I use it again.
Discussion Quanum battery voltage telemetry - and 'voltage under load' question ... JJJNYC Batteries and Chargers 51 Oct 22, 2014 11:55 AM
Discussion Battery wont fit charger ? Wade1 Batteries and Chargers 10 May 09, 2010 04:58 PM
Discussion Battery voltage versus servo voltage. yellowmg1978 Beginner Training Area (Aircraft-Electric) 11 Jan 11, 2010 06:19 PM
Discussion Align 75 amp speed control wont let me set low voltage cut off! help! djdaveq Electric Heli Talk 15 Dec 14, 2009 12:02 PM
Discussion Mastech Power supplly voltage wont go past 6volts erh7771 Batteries and Chargers 5 Dec 05, 2009 08:27 AM
