Old Oct 20, 2011, 08:51 AM
designer,builder,flyer
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Claus,
Two questions,
Is the baking paper used as a peel ply or is it now a laminant?
Are you going to put a bullet cone or stinger on the tail end of the fuse?
ApexAero is online now Find More Posts by ApexAero
Old Oct 20, 2011, 11:06 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
It is a very good natural peel ply.
i used it to make sure that the plastic bag did not gave me a bad surface.
it will be open in the end to make sure i can cool down the interior
there will come some inlets in the front.
I might come out with some insane flights on 7 S ... and i think that will be 160 amps.
Claus
clausxpf is offline Find More Posts by clausxpf
Old Oct 22, 2011, 08:32 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
a little tip that might speed the work.
i was looking at the bottom of the fuselage i just applyed glas and epoxy to.
I do have a heat lamp but no good way of placing it over the subject.
then i saw my teflon baking sheets, and my foil iron... and put two and two together,
I put one the baking sheet and played ironing foil onwith a little higher temp than normal for foil ..
After 3 times covering i could see that the epoxy was not shiny any more and touching it i it was like 3 hours in the hardening process.
Old Oct 23, 2011, 12:31 PM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
fuse construction finished
just to show you the finished result before paint ...
I will make some new wings later both thinner .... longer and who knows what .
Claus
Old Oct 26, 2011, 12:03 PM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Mounting Servo's
It is real nice to have space enough.
Old Oct 26, 2011, 12:44 PM
Low rates are for wimps
bwoollia's Avatar
Canada, AB, Edmonton
Joined May 2008
It's amazing that a jet that looks so slim and sleek has all that space. A very efficient construction method!
bwoollia is offline Find More Posts by bwoollia
Latest blog entry: Dynam Me-262 Schwalbe in Flight
Old Apr 24, 2012, 12:05 PM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
getting ready for the 5. international electric jet meating in copenhagen /Denmark.
this one will followed be my other designs... like Velocity-RC T-33, Saab Tunnan and naturally the Saab Draken. My friends that have build the F-8 panther will particiate as well and Jonas will come with the Crusaider with tilt wing!
Claus
Old May 07, 2012, 04:15 PM
kremecheze's Avatar
queens,ny
Joined Jun 2007
awesome looking build
kremecheze is offline Find More Posts by kremecheze
Old May 12, 2012, 01:10 PM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
wings.
I am playing with some new set up on my cnc hotwire cutter-
look at how narrow this cutting is !
Claus
Old May 28, 2012, 08:58 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
FPV wings for the super slingjet.
thin wings reinforced by some glass and carbon string on the underside of the wing, covered with 50 gr/m²
Top of wing will be covered tomorrow with 80 gram / m².
Claus.
the Velocity-RC team.
Old May 28, 2012, 09:04 AM
bwoollia's Avatar
Joined May 2008
Nice!
Old May 29, 2012, 11:49 AM
frank40's Avatar
Denmark
Joined Sep 2005
That is a brilliant idea Claus, I will be sure to use it next time
frank40 is offline Find More Posts by frank40
Old May 30, 2012, 10:30 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the allmost finished wings.
Here are 1436 mm (56½") wing and area enough for serious loads of transmitter and camera.
if wheather permits maiden on saturday!
wm 400 mk2 fan 2900kv motor on 6S and as a test, 48mm exit that is 60 % of fsa
That should give me close to 400 km/hour exit velocity (248Miles/hour)
Claus
The Velocity-RC team.
Old Jun 14, 2012, 10:17 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
waiting for the pilot !
here it is with every thing in place and with a new fan .
just waiting for the pilot and the wheather to work together.
Claus
The velocity-rc team
Old Jun 14, 2012, 10:33 AM
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
that is what you get in the kit Brian .
Claus
Mini-Review 70mm Velocity-RC Slingjet - Sling Shot mode101 Electric Ducted Fan Jet Talk 96 Jun 12, 2010 11:14 AM
New Product Velocity Slingjet - Sling Shot absolute-zero Electric Ducted Fan Jet Talk 34 Jun 12, 2010 11:05 AM
Discussion Advice me please.. Upgrading from my Airtronics RD6000 Super.. Cdr.Instigator Radios 8 Mar 27, 2010 08:08 PM
Question switch from 9c super to 2.4 ghz reciever? lordbyronxxiv 114th RC Aero Squadron 2 Mar 20, 2010 02:37 PM
