Old May 08, 2010, 03:37 PM
clausxpf is offline
Find More Posts by clausxpf
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
Build Log
from slingjet to super slingjet, and now with FPV wings
I did have a kit that i have designed, and decided to do a new model out of it
5 or 6 cells do need more space that the slingjet had.
the first test model lasted two flights. Radio failure in the last leg of landing.
take off weight was 1.5 kg ... but thrust on 5 S was static near to 2 kg.
5 minutes of flight only drained 1480mAh from the batteries.
I am rendering the movie at the moment..
Claus
at Area 52
clausxpf is offline Find More Posts by clausxpf
Last edited by clausxpf; May 28, 2012 at 09:38 AM. Reason: It is still develloping.
Old May 09, 2010, 08:19 AM
ibcellist is offline
Find More Posts by ibcellist
Meditative flight
ibcellist's Avatar
Virginia
Joined Jun 2009
Beautiful work! What foam are you using and what weight glass do you use for your builds? I've been looking through your work and all of it is absolutely superb. Can't wait to see this thing fly! Your new fuse looks much cleaner than your last.
-Evan
ibcellist is offline Find More Posts by ibcellist
Old May 09, 2010, 09:20 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the video is very raw.. and have 12 seconds of black in the start.
super slingjet maiden (9 min 58 sec)
The foam used is XPS (extruded polystyrene foam) like dows blue foam.
the glass i am using is 49 gram / meter2
Claus at area 52
Old May 09, 2010, 09:47 AM
Meditative flight
ibcellist's Avatar
Virginia
Joined Jun 2009
Looks like a nice flying plane! And by the way there is actually a full minute and 12 seconds of black at the start of the video. Thanks for the info!
-Evan
Old Nov 08, 2010, 06:26 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
cleaned the video
go to next frame
Old Nov 08, 2010, 06:28 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
00000000.restored (8 min 10 sec)
Old Nov 08, 2010, 10:29 AM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Hi Claus
Thats a nice model and it looks great in flight to.
frank40 is offline Find More Posts by frank40
Old Jan 01, 2011, 09:44 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
we did a little test today...
1.55 kg plane 2.1 kg
the plane in the test stand. (0 min 24 sec)
at some 380km/hour exit.
Old Jan 07, 2011, 05:03 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
super slingjet
now it is only wheather ...
Claus
Old Jan 07, 2011, 06:07 AM
jweber009 is offline
Find More Posts by jweber009
PH.D in Scratchbuilding
Denmark, Region Zealand, Holbaek
Joined Sep 2005
I can't wait to do the test run with the new setup....
jweber009 is offline Find More Posts by jweber009
Old Feb 28, 2011, 09:05 AM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
now we have 233 km/hour .
if you want to see some raw performance take a look here:
sunday flying of the Super Slingjet (2 min 31 sec)
i think jweber will give you the feeling of how it was in the air.
Claus
Old Feb 28, 2011, 01:08 PM
Joined Sep 2005
Claus
Indeed I will.....
The Super SlingJet is just as stable in flight as the original. Can't tell if it has made a diffenrence with the lower body..... still need some more experince with this one.
Regarding power..... "IT DOESN'T GET ANY BETTER THAN THIS".....
On first flight I started with full throttle..... went directly into a vertical climb. Half way into the climb I throttled down to 50% and it still went straight up. Did a couple of laps on full throttle and came down to landing after about 2 min. of flight.
On second flight I decided to do some "slow speed to full-throttle vertical climbs".... no problem here. Came in really slow.... pulled the elevator and when it was at about 70-80 degree nose up and almost stalled out I put the throttle to its max..... it just climbed away gaining more and more speed.
More flights and video will come.... so stay tuned.
Old Feb 28, 2011, 02:23 PM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Hi there
I had the pleasure of seeing the flights live and man that was awsome, never seen a plane going vertical like this. Ton of power and plenty of speed, a winer for sure.
Old Sep 18, 2011, 06:36 PM
clausxpf is offline
Claus at Area 52
clausxpf's Avatar
copenhagen Denmark
Joined May 2002
the last flight of the old super slingjet.
this is just to show how little ground was needed to get airborne with no help at all.
but the fuselage itself did survive without damage.
a new will be build without twin booms.
Super Slingjet Last flight (2 min 45 sec)
Claus
Old Sep 19, 2011, 10:55 AM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Man.... thats a rocket
Mini-Review 70mm Velocity-RC Slingjet - Sling Shot mode101 Electric Ducted Fan Jet Talk 96 Jun 12, 2010 11:14 AM
New Product Velocity Slingjet - Sling Shot absolute-zero Electric Ducted Fan Jet Talk 34 Jun 12, 2010 11:05 AM
Discussion Advice me please.. Upgrading from my Airtronics RD6000 Super.. Cdr.Instigator Radios 8 Mar 27, 2010 08:08 PM
Question switch from 9c super to 2.4 ghz reciever? lordbyronxxiv 114th RC Aero Squadron 2 Mar 20, 2010 02:37 PM
