| Thread Tools |
| This thread is privately moderated by Clintstone, who may elect to delete unwanted replies. |
Castle Quick Tip: Auto-Rotation Calibration Part 2 of 2*Video*
Video to help with Auto-Rotation Recovery mode.
OK
I might try this again. But I noticed in the video that you say to put your normal throttle at 0-0-0 all the way across... If you leave it at 0-0-0 , doesn't this defeat the normal setting on the DX7 controller ? In order to get the motor started you would have to have the throttle hold on and in position 1, if I am correct ? So normal mode doesn't do anything now ? |
Now if you are running fixed endpoints instead of governor mode you can leave a linear curve in normal mode an as long as the throttle stick is in the low position the controller will arm. Keep in mind that if the last throttle signature the controller see's is the calibrated throttle hold before you spool up it will spool up according to the Head Speed Change Rate rather than the Initial Spool Up Rate. |
The key here is that the ESC must see -0- to arm and it must see -0- to get back to soft start... with this said we have recommended -0- all the way across in normal as a safety but you could even use 2 points for -0- at the bottom and 30-30 for the rest which in Set RPM mode would allow you to spool up in Normal with the stick to your lowest Head-speed. We recommend the -0- line all the way as to keep someone from flying in normal and creating a soft start condition in flight. We try to keep things simple in our recommendations but once you understand how it works you are free to get creative if you like.
I run a 3 position switch on hold with an auto position and a -0- position that allows me to run 3 Head Speeds , normal, idle 1 and idle 2. I would add that if you click too far then you can get into trouble but I am very careful as I know what it can do...-0- would force a soft start condition...with today's computer radios we have so many options. |
Well I tried it again following your instructions..
It still will not arm. ICE75 ESC using a DX7 with Gaui-365 My throttle setting epa are 100 high 111 low I tried the auto setting of +50 all the way down to -20 Normal throttle set at 0-0-0 across the board I thought the Gaui unit might of been the cause of it, so I tried with out it hooked up at all. Same results. It makes the beeps at high stick. But when I tried the low stick it just never beeps and arms...So looks like I will not be using auto at all..Not sure why. Maybe the previous post (h60tweet) above is having the same problem ? |
OK
After talking to you I went step by step as the video said Normal throttle curve set to 0-0-0 Set RPM Mode Below setting loaded into the esc Brake Ramp: Super Slow Brake Delay: .6 sec (Delayed) (*) Sample Frequency: 2 Sample / Sec Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*) Power-On Beep: Disabled BEC Voltage: 6 Hex55: 85 Vehicle Type: Helicopter Throttle Type: Governor Mode Throttle Response: 5 Governor Gain: 20 Initial Spool-Up Rate: 2 Head Speed Change Rate: 14 Auto Rotate Enabled: True Governor Mode Type: Fixed Vehicle Setup - Battery Type: LiPo Vehicle Setup - Number of Cells: 6 Vehicle Setup - Battery Voltage: 22.2000 Vehicle Setup - Gear Ratio: 11.5714 Vehicle Setup - Pinion: 14 Vehicle Setup - Spur: 162 Vehicle Setup - Motor Kv: 1450 Vehicle Setup - Motor Number of Poles: 8 Desired Head Speed 1: 1760 Desired Head Speed 2: 1800 Desired Head Speed 3: 2005 Data Log Enabled: 255 Motor Timing: 3 PWM Rate: 12 Khz Brake Strength: 0 Direction: Forward (*) Current Limiting: Normal (70A) (*) Motor Start Power: 59 Cutoff Type: Soft Cutoff Cutoff Voltage: Auto Li-Po (*) 0-70-100 on normal-idle 1-idle 2 Throttle hold set to +50 Normal mode with throttle hold off The controller WILL not arm ! But if I put the following in with the no auto not checked. It will arm right off ? Hex55: 85 Brake Strength: 0 Brake Delay: .6 sec (Delayed) (*) Brake Ramp: Super Slow Cutoff Type: Soft Cutoff Motor Start Power: 59 Direction: Forward (*) Sample Frequency: 2 Sample / Sec Motor Timing: 3 Data Log Enabled: 255 Current Limiting: Normal (105A) (*) BEC Voltage: 6 Power-On Beep: Disabled PWM Rate: 12 Khz Vehicle Type: Helicopter Throttle Type: Governor Mode Throttle Response: 5 Governor Gain: 20 Initial Spool-Up Rate: 2 Head Speed Change Rate: 16 Auto Rotate Enabled: False Governor Mode Type: Fixed Vehicle Setup - Battery Type: LiPo Vehicle Setup - Number of Cells: 6 Vehicle Setup - Battery Voltage: 22.2000 Vehicle Setup - Gear Ratio: 11.5714 Vehicle Setup - Pinion: 14 Vehicle Setup - Spur: 162 Vehicle Setup - Motor Kv: 1450 Vehicle Setup - Motor Number of Poles: 8 Desired Head Speed 1: 1760 Desired Head Speed 2: 1800 Desired Head Speed 3: 2005 Auto-Lipo Volts/Cell: 3.0 Volts/Cell (*) Cutoff Voltage: Auto Li-Po (*) Strange how the order of the values are different ( auto vs normal... ) |
OK
Tried something I tried before. Bypassed the Gaui-365 with a extension and ran it directly to the receiver. Went thru the programming process and it programmed perfectly.. Seems the Gaui was changing the throttle setting limit. ![]() I had tried that before and must of not done it correctly at that time. Either way it works now and works perfectly! ![]() Thanks Clint... Fred aka Spidious |
Well since I got the 500 going on the esc for auto.I thought I would try the 60..
But the following screen keeps popping up. It won't update to the v3.2 firmware ? Tried to set the auto on it and it won't work.. OK got it to autorotation program finally.. But it still has the pop up and warning and the older version.. The reason it wasn't auto, I didn't notice that the auto unchecked when I tried to upgrade the software.. Luckily I decided to auto program it and not fly it...I found the wire that comes out of the battery at the deans connector had partially broken.. Solder it back up now ! |
Are the printable instruction wrong ? It says
Once it is up to speed flip into throttle hold and In the Throttle Hold Screen slowly decrease the value pausing briefly between each point until you hear the motor loose power & begin to slow – go no further! Shouldn't it say the motor stops ? |
| Thread Tools | |
| Mini-HowTo Castle Quick Tip: Throttle Calibration Part 1 of 2 | Clintstone | Castle Creations | 41 | Sep 26, 2012 08:27 PM |
| Discussion "Auto Rotation Enable" and "Fixed Endpoints"??? | RMG2 | Castle Creations | 8 | May 03, 2010 03:42 PM |
| Discussion 3.11 throttle calibration and auto calibration for Helis | Clintstone | Castle Creations | 43 | Mar 13, 2010 05:29 AM |
| Discussion CC PHOENIX 35 and auto calibration throttle | quenda | Castle Creations | 9 | Dec 06, 2009 07:44 PM |
| Discussion UAV Quadcopter Auto Calibration - Need help with the maths! | Tomo8281 | UAV - Unmanned Aerial Vehicles | 1 | Oct 14, 2009 05:57 PM |
