Old May 07, 2010, 04:52 PM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Mini-HowTo
Castle Quick Tip: Throttle Calibration Part 1 of 2
Video to help with Throttle Calibration on a Heli.
This is a tutorial video that I made to help make throttle calibration on Castle Creations ESCs easier. This video is made using a Heli but it can also be applied to an airplane.
You can also find more info at : http://www.castlecreations.com/
Castle Quick Tip- Throttle Calibration.wmv (3 min 23 sec)
Clintstone is offline Find More Posts by Clintstone
Old May 11, 2010, 08:58 AM
dfrazier is offline
Find More Posts by dfrazier
USA, LA, Sulphur
Joined Apr 2006
Good video
dfrazier is offline Find More Posts by dfrazier
Old Jun 11, 2010, 02:19 AM
monkey1 is offline
Find More Posts by monkey1
Joined Jun 2010
i cant see your TX parameters selection! And voice also small. Any more better quality video?
monkey1 is offline Find More Posts by monkey1
Old Jun 14, 2010, 02:39 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
I will be making a higher quality video soon. Thanks for your patience.
Old Jun 16, 2010, 11:18 AM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Are the videos available for download on the Castle site? If so where as I've not been able to find them.
GBR2 is offline Find More Posts by GBR2
Old Jun 20, 2010, 10:09 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
http://www.castlecreations.com/suppo...al_videos.html
Old Jun 23, 2010, 03:15 PM
GBR2 is offline
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Yes, but all that does is link to the YouTube videos. I'd like to have the videos downloadable so that you don't need an internet connection to watch them.
Old Jun 24, 2010, 02:31 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
there are several open source programs that let you download you tube videos I believe. I am hoping to re-make the videos next week with higher quality video and sound. The original videos were posted on you tube so we could get them up quickly.
Old Feb 04, 2011, 06:31 PM
zigaspire is offline
Find More Posts by zigaspire
Joined Feb 2011
I have an old, non-computerized 3 channel transmitter. I have an outunner motor that is a little too powerful for my 2 meter sailplane. I want to be able to program the ESC to only allow about 75% power to the motor when the radio puts out full throttle.
Is this possible with a Castle Creations ESC using Castle Link? I have not purchased the ESC yet.
Thanks.
zigaspire is offline Find More Posts by zigaspire
Old Feb 05, 2011, 07:31 AM
flarssen is online now
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
I have a CC Phx10 on v3.20.
Tx is Robbe/Futaba FC-18.
To get the confirmation beep on high setting I need to set ATV to 110% (max) and then put the trim above centre. For the low setting it initializes when ATV is set to 62% with trim in the normal low position, and 80% when trim i centred.
What is the values in ms for the fixed endpoints? Obviously far from what my Tx operates on, but any servo plugged in to ch 3 behaved quite normal.
Calibrating the Tx against fixed values in the ESC seems somehow backwards to me. What is wrong with the "full stick, power on ESC, pull stick" method used by others for throttle calibration?
Edit: Got it working now with full up trim. ATV's ended then at 96% (High) and 104% (Low). A bit unusual I guess, and a pain since my Assan module (2.4GHz) refuses to initialize unless throttle is at it's lowest (+ trim).
Fred
flarssen is online now Find More Posts by flarssen
Old Mar 16, 2011, 02:27 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Fred
You should be able to pull the trim down to satisfy... then calibrate the throttle with the trim down... as long as you leave the trim down then it should not change...
Old Mar 16, 2011, 03:19 PM
66tbird is offline
Find More Posts by 66tbird
To many projects
66tbird's Avatar
USA, AZ, Litchfield Park
Joined Aug 2004
On my phx45 using a 9303 I can find the high but not the low.
Just to test I set it for functionality I did a simple, 'airplane' mode and 'auto endpoints' and all it does is enter program mode on travel extremes.
btw the esc hasn't spun a motor yet
66tbird is offline Find More Posts by 66tbird
Last edited by 66tbird; Mar 25, 2011 at 10:40 AM. Reason: Problem solved, just had to understand the the way it works. Thanks for the help
Old Mar 16, 2011, 04:14 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Set your throttle type to fixed endpoints and try it again... it should work after set it to fixed endpoints...
Old Mar 17, 2011, 05:05 AM
Son, Norway
Joined Sep 2004
If I understand this correct, the ESC has fixed settings for min and max throttle in governor mode and the idea is to adjust the Tx travel according to those.
As I said, with trim down, reaching the upper level is impossible with my Tx.
Why not make these settings changeable through the link app?
Old Mar 24, 2011, 12:54 AM
Son, Norway
Joined Sep 2004
Problem solved
The problem I had with reaching the high spot was due to the fact that the function throttle ATL (trim have no effect when stick is above neutral), was deactivated by default in heli mode. After setting THR ATL to active, I was able to reach both upper and lower spot.
Fred
Discussion Thunderbird 54 Throttle Calibration Chophop Power Systems 24 Apr 29, 2010 08:37 PM
Discussion Suppo 20A ESC throttle calibration procedure khaled_abobakr Power Systems 7 Apr 10, 2010 04:28 AM
Discussion 3.11 throttle calibration and auto calibration for Helis Clintstone Castle Creations 43 Mar 13, 2010 05:29 AM
Discussion Quick tip for I/R sender speeds Slider2732 Micro Ready-to-Fly 0 Jan 25, 2010 11:11 AM
Discussion CC PHOENIX 35 and auto calibration throttle quenda Castle Creations 9 Dec 06, 2009 07:44 PM
