Old Jun 08, 2003, 09:00 PM
Tipsy_WA is offline
Find More Posts by Tipsy_WA
Tipsy_WA's Avatar
Perth Western Australia
Joined Oct 2002
Novice Brushless Questions
Is there a thread I can read regarding the science of brushless motors that will bring me up to speed on the differences when compared to brushed motors
In particular I am interested in the following:
Why the motors have 3 leads (compared to brushed pos and neg)
Are they DC
Can they be reversed etc
Tipsy_WA is offline Find More Posts by Tipsy_WA
Old Jun 08, 2003, 09:34 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
There are probably lots of threads, but let's start a new one anyway!
They are actually 3-phase AC motors - miniature versions of the motors that drive big air conditioning fans and similar equipment.
ESC's for brushless motors synthesize 3-phase alternating current from direct current. That's why they cost so much.
You can reverse a brushless motor by exchanging any two of the three leads.
Miami Mike is offline Find More Posts by Miami Mike
Old Jun 08, 2003, 10:55 PM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Don't forget the most important part... NO BRUSHES. Literally, the only thing that can wear out are the bearings, which are dirt cheap to replace.
Of course, just like any motors, you can overheat and destroy it, or as Genebond says "dork" it into the ground and break/bend the output shaft.
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Jun 08, 2003, 10:56 PM
FlyByMike is offline
Find More Posts by FlyByMike
Pittsburgh, PA
Joined Jan 2002
Some benefits of BL are :
Simplicity - permanently sealed ball bearings are the only parts to wear, so very low maintenance. No brushes to wear out, run in, or to make dust.
Efficiency -generally they make better use of the battery given equivalent power ratings.
-Mike
FlyByMike is offline Find More Posts by FlyByMike
Old Jun 08, 2003, 11:32 PM
LightFlightRC is offline
Find More Posts by LightFlightRC
Purveyor of RC-Opiates
LightFlightRC's Avatar
California
Joined Jan 2003
I've had an astro 010 barely after they came out. It still runs like new and I'm sure I have hundreds of hours on it, if not thousands. I know they are more expensive but I am convinced in the long run they are cheaper. Protect your investment with a gearbox since it will take the impact if you crash. Less weight and more thrust and RPM for less current in. Brushless is the way to be!
LightFlightRC is offline Find More Posts by LightFlightRC
Old Jun 08, 2003, 11:49 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
What everybody said but be warned.. they are addictive! The first one you install leads to a craving for more!
boomer
boomerace is offline Find More Posts by boomerace
Basic Brushless Questions samhoff Power Systems 7 Sep 10, 2003 12:49 PM
My first brushless (questions)... dodgeboy Power Systems 9 Jul 28, 2003 11:20 AM
Hacker Brushless Questions Brill 1 Power Systems 5 May 30, 2003 10:48 PM
A few brushless questions... RobDog Power Systems 10 Feb 19, 2003 05:02 PM
