Old May 07, 2010, 09:40 AM
dirtrackracer2 is offline
Find More Posts by dirtrackracer2
dirtrackracer2's Avatar
United States, AZ, Kingman
Joined Apr 2010
radion 480 b motor
i need a motor shaft for the 480 b motor on a radion the pkz4418 for that motor is not the correct one, the shaft i need has a place for a c clip on the front of motor the guy at a main said you dont need that the magnets hold it together(well i said no way) im not a model expert but i do know the magnets do not hold the motor together. if you enlarge the motor you can see the c clip if you enlarge the shaft you can tell there is no groove for the c clip
and the pkz 4418 shaft has a extra flat spot ground into it and is over 1/8 inch longer than the one i have
dirtrackracer2 is offline Find More Posts by dirtrackracer2
Old May 07, 2010, 12:39 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
There should be a collet in place of the clip to hold the motor together.
Xpress.. is offline Find More Posts by Xpress..
Old May 08, 2010, 07:16 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Collets are normally only used for the prop adapter, to hold the prop and shaft together as they turn.
I don't have a Radian or a 480B motor but as I understand it that plane has a the motor in a "firewall mounting" with the motor behind a bulkhead, the fixed part of the motor is behind the bulkhead and attached to it with screws from the front, and the rotating part of the motor (the magnet housing) is inside the fuselage.
There is a plastic yoke/spinner base with the folding prop blades and that is held to the shaft with a collet. The large nut in the center of that is what tightens the collet and hold it all together.
The pulling forces in flight will want to pull the shaft out of the magnet housing, through the motor base, and out of the motor. If there are grub screws at the end of the magnet housing, those are what is keeping the motor together in use. And it there is a short section of the shaft visible there there may also be a circlip that keep the shaft from being pulled into and through the magnet housing.
If you have a shaft that is the right size (4mm?) and length but lacks the groove for the circlip, you can cut one yourself if you have the right tools. Here is a thread that explains how to do that:
http://www.rcgroups.com/forums/showthread.php?t=1240725
The extra length on the flat is not of any consequence as long some of it is in the right place. And that thread at the link above also explains how to cut a new flat.
If you can post any photos of the old and new shaft maybe we can offer some better advice.
My understanding is that Hobby Zone will sell a new motor but not just a replacement shaft for a motor. Because of that, I would make a shaft for it.
If you want to do that, get a shaft that is too long (it may have the circlip groove on it), cut it to length and put the groove and a flat on it for the grub screws if necessary.
You can get shafts are Head's Up RC, RC Dudes, Lazertoyz, and a number of other online U.S. based, RC dealers.
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 08, 2010, 07:26 AM
Joined Apr 2010
Thanks guys i recieved a new motor for no charge yesterday. i never thought of cutting a groove in the shaft i have. and maybe a collet would work on this one too if theres enough room. again thanks for the reply
Old May 08, 2010, 09:29 AM
Jack
USA, ME, Ellsworth
Joined May 2008
If you don't have the stuff to do it yourself you could mail me the shaft and I'd do it and send it back to you. I could shorten the shaft too if it needs that.
I am in Maine, feel free to PM me for a mailing address if you're interested in that. No charge, you can pay the postage.
Jack
Old Apr 01, 2014, 11:19 AM
BeavisUSMC is offline
Find More Posts by BeavisUSMC
Trees Are Stupid
BeavisUSMC's Avatar
United States, KY, Louisville
Joined Sep 2013
I'm about to replace mine tonight. Is there some special tool I need to cut the groove in the shaft? Can it be done other ways. This same motor is in my Albatross.
BeavisUSMC is offline Find More Posts by BeavisUSMC
Old Apr 01, 2014, 06:00 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Look at that link I put in post #3 just above, that way (abrasive cutting) is about the only practical way to do that on a hardened and ground shaft.
Jack
Old Apr 01, 2014, 06:32 PM
stemo99 is offline
Find More Posts by stemo99
stemo99's Avatar
United States, NJ, Pennsville
Joined Feb 2008
Xpress meant a collar with a set screw.
stemo99 is offline Find More Posts by stemo99
Old Apr 01, 2014, 07:27 PM
Trees Are Stupid
BeavisUSMC's Avatar
Joined Sep 2013
I couldn't use the drill press because the Dremel body wouldn't fit close enough. My 3/8 drill had a ton of slop in the bearing.
The shaft is nothing like the original in the Albatross, with the exception of shaft diameter, every other dimension is off.
I had to cut 2 new flats on the back for the set screws on the can and let the extra 1/4 inch just hang out the back. That puts the groove for the C clip in the part of the shaft with 4 flats already ground.
Since I had to free hand the cut it came out much less than perfect. About all I can say is that the V shaped impression I could make is marginal at best for a groove to retain the clip.
About the best thing I can say is it will suffice since the front clip is nowhere near as important as the 2 set screws at holding the motor in place form the force of the shaft pulling forward...as with the prop turning.
Best I can tell it it is only for impact protection for the motor.
Parkzone dropped the ball here. There is a replacement shaft for so many motors but if you bought the now short lived, discontinued Albatross you are S.O.L. Thanks Parkzone.
I think this will work, as you know a new motor is almost $50 before shipping. One thing you will also notice is the prop will stick out another 1/16 of an inch since the turned down portion of the shaft is shorter than the original.
If you have a machine shop with a lathe, you will be fine at duplicating the original. If you are the average Joe that can't afford a $50 motor anytime, you will have to live with the shortcomings of this repair if you wanna fly your Parkzone Albatross.
Old Apr 01, 2014, 08:50 PM
Jack
USA, ME, Ellsworth
Joined May 2008
I'm confused. He wants to cut a groove for a collar with a set screw? I assumed the groove was for a Circlip.
For collars I would just grind a small flat for the grub screw to bear on. That is described in that same thread too.
Jack
Old Apr 02, 2014, 05:59 AM
stemo99 is offline
stemo99's Avatar
Joined Feb 2008
If the OP wants to send this out for machining so be it. But grinding a flat and using a collar with set screw would save postage, time and aggravation. Use a C clip it groove is present, if not collar w/set screw or better yet, both.
Old Apr 02, 2014, 06:34 AM
Trees Are Stupid
BeavisUSMC's Avatar
Joined Sep 2013
I just cheated the extra length out the back when I ground the flats. :
Old Apr 02, 2014, 06:58 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Adding flats and grooves is easy if you have a Dremel tool and the #409 thin abrasive cutting discs. There is a thicker disc that is softer and that does not work as well, it is OK for flats but nearly useless for grooves.
Chuck the shaft up in a drill motor, give it one light touch with a a #409 disc, and you have a perfectly useable groove in two seconds or less.
Jack
Old Apr 02, 2014, 07:52 AM
Trees Are Stupid
BeavisUSMC's Avatar
Joined Sep 2013
Jack
It works if your drill doesn't have slop in it. That snap ring is not critical IMO anyway. The can rides on a bearing... all you need is the grub screws... unless you crash...I don't see the need to worry about that. In an Albatross anyway. The Radian is a pusher? Maybe then you need it.
Old Apr 02, 2014, 04:30 PM
Piece is online now
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
A new drill can be had for cheaper than a new stock motor.
Piece is online now Find More Posts by Piece
Wanted Wtb 480 b/l inrunner lectroglide Aircraft - Electric - Power Systems (FS/W) 0 Mar 24, 2010 08:50 PM
Discussion radion control & retracts jaymak Beginner Training Area (Aircraft-Electric) 3 Oct 24, 2009 07:53 AM
Sold Aitronics Vanguard 7ch radion system Jim Young Aircraft - General - Radio Equipment (FS/W) 1 Mar 04, 2009 11:27 AM
For Sale [B]Multiplex BL-480/6G NEW never been used[/B] dmhuff92127 Aircraft - Electric - Airplanes (FS/W) 8 Aug 10, 2005 10:18 AM
F.S: GRAUPNER 480 B.B 7.20 volt 9LIVES1968 Aircraft - Electric - Airplanes (FS/W) 2 May 05, 2005 07:56 PM
