Old May 07, 2010, 07:42 AM
Stingeragent is offline
Find More Posts by Stingeragent
Austin Tx
Joined Feb 2003
Wicked Plus 4000 on 70mm bh fan
Hi, I already ordered this motor for use in my f-117 from banana hobbies. Guess I should of asked first what mounting hardware I'm gonna need. I assumed it would be similar to the EDO plug on their 64mm fans so thats what I went with. Am I gonna need something else to mount it or will that work? Also, was planning on running it with a 4s 2200 20c pack. Is that gonna fry my motor on the 70mm 5 blade fan or do I need to drop down to a 3s?
Updated: Ok, just got the F-117 in the mail and it appears to not have a rotor thing like the edo fans, its got a prop collet adapter. Not sure if its a 3mm or 3.17 and the manual doesn't seem to say. So need to find out what I should do. I order the wicked plus 4000 with standoff adapter and edo rotor plug, so not sure if the motor shaft sticks out passed the rotor adapter, or if I need to buy a whole new motor shaft or what. Or would it be easier to just buy a new fan that will fit my motor.
Stingeragent is offline Find More Posts by Stingeragent
Old May 07, 2010, 07:28 PM
The Don is online now
Find More Posts by The Don
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
No idea what to suggest as I am not familiar with the BH 70mm EDF units. Do you have photos of the fan unit and collet adapter.
Don
The Don is online now Find More Posts by The Don
Old May 07, 2010, 07:44 PM
Austin Tx
Joined Feb 2003
Yea I could take some photo's, but I think i'm gonna try what you suggested in the other thread with the brass tube. I put in a 3.17 mm collet adapter and it seems like everything will work ok as far as it being long enough and everything. But I'm gonna need to put some brass tube or a washer or something inside the fan hole so that it will be more flush with the smaller sized collet adapter. Well with all that being said, since I have the edo plug on the motor you sent me, is there anyway to remove that and just have the standoff and the motor shaft, or am I gonna need to order a new shaft from you?
Old May 07, 2010, 08:08 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
You will need a GWS gear puller to remove it.
Don
Old May 10, 2010, 08:18 AM
Austin Tx
Joined Feb 2003
Ok thanks. Last question is, about how many watts/thrust am I looking at running this on a 3s 2200 20c pack. I realized that the fan is a 6 blade so pretty sure I'm not gonna be able to run it on 4s without frying it
Old May 11, 2010, 10:57 PM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Not really sure. I would guess maybe 400 watts??? The only 70mm fans I have tested them in was the Phase 3 Squall fan units.
Sold BH/LX 70mm fan 2400KV motor 50A esc & bec truevine77 Aircraft - Electric - Jets (FS/W) 3 Jun 02, 2010 08:44 AM
Discussion Question on BH F/A 18 70mm V2 (not the huge one) Stingeragent Foamy EDFs 1 Apr 25, 2010 06:47 PM
For Sale BH/LX 70mm fan 2400KV 5s motor truevine77 Aircraft - Electric - Jets (FS/W) 1 Apr 08, 2010 11:05 PM
For Sale Don's Wicked 4000 Plus, Pentium 60A, balanced fan Matt Gunn Aircraft - Electric - Jets (FS/W) 2 Mar 01, 2010 10:37 PM
Sold Dons wicked 4000 and eflite fan $30 shipped conus java8297 Aircraft - Electric - Jets (FS/W) 0 Nov 12, 2009 07:31 PM
