Old May 06, 2010, 10:44 PM
crd is offline
crd
Find More Posts by crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
1 watt 2.4ghz video tx, Futaba 7C 2.4ghz, 900mhz XBEE compability?
Ok Im building a FPV easy star with autopilot and it will consist on a:
1 watt 2.4ghz video transmitter
Futaba 7C 2.4ghz radio/receiver
and a 900mhz xbee telemetry module
have anyone tested this setup, what problems have you got?
I for sure want a 2.4ghz radio, I have a 2w, 1w and 200mw 2.4ghz video transmitters so I can sell them and get a 1300mhz video tx instead but before I do that I want to make sure that my first setup on the top will work?
crd is offline Find More Posts by crd
Old May 06, 2010, 11:37 PM
JRFlyerFPV is offline
Find More Posts by JRFlyerFPV
No JR tx here!
JRFlyerFPV's Avatar
Eastern ND
Joined Sep 2009
My opinion, dump the 7C and get either a 7C or 9C 72mhz - you can then use the 2.4ghz video gear and also not have to worry about lockouts when going just out of range. You won't be able to use 2.4ghz radio and 2.4ghz video together. If you still want to stick with 2.4ghz radio, then 900mhz or 1.3ghz are your two choices pretty much.
JRFlyerFPV is offline Find More Posts by JRFlyerFPV
Old May 07, 2010, 12:25 AM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
Yeah I might end up selling all my 2.4ghz gear, and get 1300mhz. I cant stand using stick antennas on my radio.
Old May 07, 2010, 02:56 AM
mrleenagle is offline
Find More Posts by mrleenagle
fpv addict
mrleenagle's Avatar
Sydney, Australia
Joined Nov 2007
What's the xbee for???
mrleenagle is offline Find More Posts by mrleenagle
Old May 07, 2010, 07:25 AM
crd is offline
crd
crd
Always thinkering
crd's Avatar
United States, FL
Joined Nov 2006
The XBEE will give real time telemetry data of my autopilot to my ground station like (position, airspeed, voltage, altitude, angle, and it will tell my antenna tracker where the plane is so it can point the antenna towards the plane)
Discussion Practical difference between 1.2ghz and 2.4ghz LM 1 watt TX Carlyle Harper FPV Talk 27 Jan 23, 2010 04:15 PM
Sold Futaba 7C FASST 2.4ghz Tx Rx and 4 S3152 servos jeepfreek Aircraft - General - Radio Equipment (FS/W) 3 Jan 08, 2010 08:56 PM
Sold futaba 2.4ghz 7c tx and rx and flight batt pack 150.00 motoman40 Aircraft - General - Radio Equipment (FS/W) 2 Jan 08, 2010 06:26 PM
Discussion Video Resolution/Color and TX frequency (900Mhz vs 1.3Ghz vs 2.4Ghz vs 5.8Ghz) mook FPV Talk 4 Apr 03, 2009 01:02 AM
For Sale Futaba 7C 7-Channel 2.4GHz Air Tx/Rx No Servos plamski Aircraft - General - Radio Equipment (FS/W) 2 Sep 17, 2008 05:09 PM
