This thread is privately moderated by Evel Knievel, who may elect to delete unwanted replies.
Old May 06, 2010, 11:16 AM
Evel Knievel is offline
Find More Posts by Evel Knievel
"Audentes Fortuna Juvat"
Evel Knievel's Avatar
United States, GA, Columbus
Joined Oct 2008
Cool Stuff
I recently added cooling scoops to my 89" Slick. I am running a Hacker A60 18L with a 24x12 prop. After a fairly aggressive flight (ample 3D and hovering) it was right at 130F. While that is acceptable I would like it to be a bit cooler. The ambient temp that day was about 85F and around here there are plenty of 95-100F days during the summer. I have not flown it yet so I will have to see if it really works.
Evel Knievel is offline Find More Posts by Evel Knievel
Old May 06, 2010, 01:54 PM
gaffrig is offline
Find More Posts by gaffrig
Fly it or Fix it
Greenville, NC USA
Joined Sep 2009
Interesting concept. Clarification - I see where the air goes in, but where does it go out? I think I'll try it on one of mine. Thanks!
gaffrig is offline Find More Posts by gaffrig
Old May 06, 2010, 05:40 PM
Joined Oct 2008
It will exit the top and bottom after passing over the motor. When you look at the third picture, the entire top (and bottom) of the mount is open for the air to exit.
Old May 13, 2010, 12:38 PM
going4speed is offline
Find More Posts by going4speed
3DHS 'native'
going4speed's Avatar
USA, TX, Spring
fluid dynamics would indicate that the exit for air flow needs to be larger than the inlet...just an FYI
going4speed is offline Find More Posts by going4speed
Old May 13, 2010, 12:51 PM
Joined Oct 2008
But... if the outlet is smaller than the inlet pressure goes up and velocity goes down. lower velocity allows for the transfer of more thermal energy to a point. Two different theoretical perspectives I think.
Old May 15, 2010, 08:24 AM
3DHS 'native'
USA, TX, Spring
True but surface turbulence could instead cause stalled air at the surface to heat up mitigating any cooling affect from larger quantity of inlet air. I think Theory...fun stuff...I would love to see a before and after temp run on this rig..
Old May 16, 2010, 06:58 PM
Joined Oct 2008
Me too I was right at 130F on an 85F day so we will see... When the batteries get back from Thunder Power we will see
Discussion Maxecuter website updates--cool stuff Pat Daily Scale Kit/Scratch Built 0 Sep 08, 2009 08:49 AM
This Slow Flier stuff is pretty cool LJH Parkflyers 8 Nov 18, 2002 05:19 PM
Cool stuff...another question DaveRCPilot Parkflyers 5 Sep 18, 2002 10:14 PM
Source for Cool Stuff All__talk Electric Plane Talk 1 Apr 30, 2001 04:01 PM
