Old May 06, 2010, 02:31 AM
Calvin_220 is offline
Find More Posts by Calvin_220
Joined Apr 2010
Fiberglass Habu Airframe
Hello All,
I am currently in the process of making an airframe out of fiberglass based off of the Habu. I want to build a jet with removable wings & horizontal stab for easy transport. I bought the Habu and dig the performance but im just not stoked on foamies. So I am going to design a plug and go from there. I have a couple of questions:
1. Should I up the fan size because of the weight difference or just run a hotter 70 mm fan, motor, battery setup?
2. What method should I use to mount the wing & horiz stab so that it can be removable?
If there is any interest in seeing the process I will post pics as I go and keep you updated!
C
Calvin_220 is offline Find More Posts by Calvin_220
Old May 06, 2010, 09:10 AM
sbritton is offline
Find More Posts by sbritton
sbritton's Avatar
USA, CA, El Dorado Hills
Joined Apr 2008
subscribed....70mm is nice...but a 90mm version would be awesome.
sbritton is offline Find More Posts by sbritton
Old May 06, 2010, 09:29 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Originally Posted by Calvin_220 View Post
Hello All,
C
Go for it man!! Subcribed!
Michael Paxton is offline Find More Posts by Michael Paxton
Old May 06, 2010, 05:32 PM
PatternFlyer is offline
Find More Posts by PatternFlyer
Frontenac, KS
Joined Jan 2003
I would love to see the pictures of progress!!
It will be great to have glass kit available.
I think if the weight difference isn't much, 70mm will be easier for $$ spent. Since you are building the fiberglass fuselage, changing to 90mm shouldn't be a difficult problem as long as correct ducting is possible.
Like most of the glassfuselage, carbon fiber tube and alignment pins can be used on wings. It will make it easier to change incidence if necessary.
if the incidence is not necessary to change, two carbon tubes. One larger than the other one. Large one goes on the thickest or closer to CG and the small one to the back.
For mounting small screws through the carbon tube from the bottom of the wing panels may be easier. Both ends of the wing tube must have some hard material for the screws to grip on to. a lot of people use end grain balsa ring inside the tube.
two small tubes will be good on horizontal stab. screws on both side for holding.
PatternFlyer is offline Find More Posts by PatternFlyer
Old May 06, 2010, 06:33 PM
Joined Apr 2010
I work in the restaurant industry and mothers day is this weekend, so I wont have any progress until later next week. Once I get it started though, I will for sure post detailed pics of the progress from beggining to end.
All together there will be (5) 2 part molds, fuse, wings & hoizontal stabs. The molds will be machined out of aluminum and brought to a mirror finish so that the end product is flawless. The wings will have carbon cloth in areas for retracts if I want to add. For aileron control, I have been playing with the idea of using push rods. So where the wing butts up to the fuse there will be a larger carbon tube by the leading edge and a smaller one aft. In front of the large tube there will be a hole for the push rod. The sleeve for the push rod will be installed during the build up of the wing and secured so that there is no slack or play and will exit under the wing, mid aileron. This would be cool because it would be flush against the bottom of the wing and could operate both ailerons on one servo to reduce weight. Ideas?
A push rod system could also work to controll the elevator & rudder to eliminate cutting the fiberglass in the rear of the plane and causing extra headaches. Painting in the mold would create a nice professional finished looking jet as well. I think if this jet was made of glass & light enough, it would make it slippery fast and a blast to fly. Retracts or not it would be very sexy. I am working on a clear canopy as well but that seems to be one issue I have not figured out just yet.
Thanks for the interest and I will keep you posted!
C
Old May 06, 2010, 08:04 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
machined molds ...you must own the resturant $$$
AIR SALLY is offline Find More Posts by AIR SALLY
Old May 06, 2010, 08:11 PM
Getmore Rc is offline
Find More Posts by Getmore Rc
Matrix 90 & 100mm sport jet
Getmore Rc's Avatar
Merritt Island Fl
Joined Aug 2008
How about some gourmet
Getmore Rc is offline Find More Posts by Getmore Rc
Old May 06, 2010, 08:46 PM
Joined Apr 2010
My career aside, I am well connected and prepaired to pay the price to have a top end mold made, to ensure a quality end result. I don't know if aluminum is nessasary though since this plug is pretty simple. Meaning there are no panel lines ect... I'm going to check out the options next Tuesday and go from there. After this project I would love to bring my friend a scale F-16 model so he can scan it and get a project going with all the panel lines. We will see what the future brings!
Happy flying,
C
Old May 07, 2010, 02:34 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Machining moulds to clone a foamy? Are you from china?
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old May 07, 2010, 02:42 AM
Joined Apr 2010
Ya, You too?
Old May 07, 2010, 02:49 AM
Joined Dec 2003
Nope, but I do understand their marketing
Good luck!
Erik
Old May 07, 2010, 03:00 AM
One Six Right is offline
Find More Posts by One Six Right
another MONSTER ?
One Six Right's Avatar
Valencia, CA
Lol... Tff !
One Six Right is offline Find More Posts by One Six Right
Old May 07, 2010, 03:02 AM
Joined Apr 2010
Good luck!
Erik
Thanks! I know I will need it... This is not going to be an easy project. But its the project and the work put into it that drives me.... I wish it wasn't a clone but I am not savy at using 3-d software to create my own experimental. I will start with this and see what comes of it.... It will be nice to say the least...
C
Old May 07, 2010, 05:00 AM
Jack Brewer is offline
Find More Posts by Jack Brewer
United States, IN, Lafayette
Joined Dec 2003
Sounds nice, hope it is soon.
Jack Brewer is offline Find More Posts by Jack Brewer
Old May 07, 2010, 06:49 AM
gunradd is offline
Find More Posts by gunradd
KingtechUSA
gunradd's Avatar
United States, FL, Spring Hill
Joined Apr 2009
For the ailerons you want 2 servos so you can have differential dialed into it. Also for the canopy all you do is vacume form it thats the easy part by far for this project.
gunradd is offline Find More Posts by gunradd
Sold Sick all metal,fiberglass CX2 airframe with extras Z06 Tony Aircraft - Electric - Helis (FS/W) 4 Feb 06, 2010 12:32 PM
Found Habu airframe and servos only mavdriver Aircraft - Electric - Jets (FS/W) 0 Feb 03, 2010 06:29 PM
I want to lodge a formal complaint against Habu. Cody WIlson Site Suggestions / Complaints 1 Oct 19, 2005 11:39 AM
Backup complaint for HABU lockheed martin Site Suggestions / Complaints 0 Oct 18, 2005 11:36 PM
"My Lil' Habu" or SR 71 FoamParkFlyer Hepdog Foamies (Kits) 15 May 05, 2005 07:08 PM
