Old May 05, 2010, 08:14 PM
epoweredrc is offline
Find More Posts by epoweredrc
24 yrs. of Aircraft flying
epoweredrc's Avatar
United States, GA, Tallapoosa
Who has good cheap VPP set ups?
looking at VPP setups I have no clue who sells them, who all have motors with hollow shafts for them and who sells the vpp setups? I am thinking about doing one on a small plane foamy. thanks for any and all input
epoweredrc is offline Find More Posts by epoweredrc
Old May 05, 2010, 08:43 PM
xtremeRCpilot is online now
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
This is not the cheapest but the best IMHO !! A few of the Comp Pilots use it with great results, and you dont need a hollow shaft!!!
http://www.airlandseahobby.com/shop_...m?subcat_ID=46
John
xtremeRCpilot is online now Find More Posts by xtremeRCpilot
Old May 05, 2010, 09:27 PM
epoweredrc's Avatar
John
Thanks, Um well it seems most are higher priced. i guess that slided over the shaft somehow love to see a video of it going together or at least on a plane working. bet could google for that .. Again thanks guess i will google some more but not had much luck in past search's
Old May 05, 2010, 11:47 PM
wcc963 is offline
Find More Posts by wcc963
wcc963's Avatar
United States, FL, Pompano Beach
Joined May 2006
its super easy to assemble. i just got mine for my Fancy Foam MX-2 and love it. it took about 10min to assemble and is a very clever design. it doesn't come with the motor mount so add about 14.00 to the price of the unit. as for a video of it check these out:
http://flightpass.higherplaneproduct...udio-H264s.mov
wcc963 is offline Find More Posts by wcc963
Old May 06, 2010, 07:04 AM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
No such thing as a "good cheap" VPP. The Mamo unit is really the only available system worth messing with. Set it up right and it won't give you any headaches.
As for videos... go look at ETOC videos for anyone using a VPP, including myself. We ALL use the Mamo unit.
Good luck!
RJ
hpapilot is offline Find More Posts by hpapilot
Old May 06, 2010, 11:42 AM
epoweredrc's Avatar
Good luck!
RJ
ok well any VPP ones at all. I know of.. the following.
http://www.rcuniverse.com/magazine/a...article_id=716
well Hobbylobby used to selel one i think but cant find it and thought horizen did but cant find it guess there are less around now.
RJ,
Are you RJ Gritter? you really put on a show with yours.
You guys using this one running 2 cells I guess.? what motors thanks
Old May 06, 2010, 11:53 AM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Honestly, a hollow-shaft setup isn't worth messing with. The setup becomes much more complicated, and VPP tends to be hard enough to handle anyway without the added annoyance of a sloppy setup or the system giving you problems. A good, tight setup is key to success with a VPP.
Yep that's me. I've always run 2S on my airplanes and just built them as light as possible. A few of the other guys have been running 3S 250's recently with pretty good success. I'm interested in trying that setup myself. The motor of choice is the Hacker A20-34S... bolts right on to the Mamo unit/mount and has all the power you could need.
RJ
Old May 06, 2010, 12:38 PM
epoweredrc's Avatar
RJ
Wow dude your good. i really enjoyed watching your flights ( by youtube,I only dreamed of being at the Etoc)
it takes lots to impress me but your flights did, I want to start the slow. low, easy flying and to music VPP has always interested me since I first seen it.
I am about to buy this plane from a club member http://www3.towerhobbies.com/cgi-bin...?&I=LXJTK3&P=0
just for a backyard flyer would it be a good model for VPP or should I look into others? Any of the Fancy foam ones good? I started flying 3D with his planes in 2004 the 36' and love em.
Chris
Old May 06, 2010, 12:42 PM
Cleveland, Ohio
Joined Sep 2006
Chris
You cant go wrong with any of the Fancy Foam Models and the MX2 is a great choice for your VPP!
John
Old May 06, 2010, 02:31 PM
hpapilot is offline
hpapilot's Avatar
Joined Nov 2006
Thanks, glad you enjoyed my flights!
I would definitely suggest staying away from the old Flatouts stuff, especially for VPP. The Fancy Foam stuff is great and is what the majority of us are flying in competition. I'm a little biased (since I designed it ) but I like the MX2, especially for VPP stuff. It has enough wing area to handle the extra weight of the VPP and seems to perform all the maneuvers well enough for me!
RJ
Old May 06, 2010, 02:42 PM
epoweredrc's Avatar
John
RJ
Thanks for the info, well I guess I will just play with the flatout in the yard for now untill i have more funds for the right stuff to do VPP. I do not want to go cheap and have to redo later or issue's with it working right.
I will check out the MX2, I love Mike Hammel planes he is a aswsome guy never met him but used to be on a chat groups with him regular.
Old May 07, 2010, 12:58 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
Good luck!
RJ
Mamo Unit is the way to go. Like RJ said, EVERYONE who ran VPP at ETOC used the Mamo unit. RJ, Andrew, Jason, Ryan, Jamie, Matthew, Brandon, and myself all used the Mamo system (sorry if I missed someone's name).
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old May 07, 2010, 02:27 PM
aerolite is offline
Find More Posts by aerolite
Fly lower!
aerolite's Avatar
West Texas
Joined Jan 2005
Originally Posted by 3D-Seth View Post
Mamo Unit is the way to go. Like RJ said, EVERYONE who ran VPP at ETOC used the Mamo unit. RJ, Andrew, Jason, Ryan, Jamie, Matthew and myself all used the Mamo system (sorry if I missed someone's name).
Seth
Seth, don't forget that Brandon Chitty flew the new Fancy Foam Fenix with a VPP setup. Not sure which variety, but I think it is the Mamo also.
His video with the VPP flight can be seen here.
http://stores.homestead.com/fancyfoa...nix/Detail.bok
aerolite
aerolite is offline Find More Posts by aerolite
Old May 07, 2010, 02:52 PM
epoweredrc's Avatar
Seth
Thanks Seth
aerolite
yeah i loved his take off, that was so cool. i would have to try something like that If i get one.
Old May 07, 2010, 04:11 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
aerolite
Yep he's one I forgot. Doh!
Discussion variable pitch prop + motor set ups for cheap rcnutt Power Systems 0 Mar 30, 2008 02:26 PM
Discussion who has the cheap but good ESC 40+A jstoll Power Systems 5 May 01, 2007 08:29 AM
Looking for good trailer set ups Splash Scale Kit/Scratch Built 2 Aug 11, 2005 11:00 PM
T- Rex Who Is Doing 4s Set Ups??? MODMAXX4748 Mini Helis 8 Jan 22, 2005 08:06 AM
good set ups with himax 5400 brianb10 Power Systems 11 Jul 13, 2004 09:23 PM
