Joined Apr 2009
a Freaking hinged stabilizer airfoil
Hello everyone,
I have received numerous requests for an airfoil for the horizontal stabilizer that uses a hinge instead of being full flying. Now I like full flying stabs, but they require more maintenance. If there is any slop at all at the pivot pins then stability suffers greatly. For this reason I'm likely to move away from full flying even though it can be a little better aerodynamically. I have a tentative new airfoil for hinged horizontal stabilizers, as a substitute to the venerable HT-22. The new foil drastically drops drag at large up elevator deflections which is the weak point of hinged systems. I'm in the tweaking stage trying to get another percent or so improvement, but it is very close. I should be done in a few days. Current version is 5% thick and somewhere around 1% camber. Hingeline is at 40% from the leading edge. All of that is like the HT-22. The shape won't look like what you are used to seeing though. I've not seen another foil with this sort of shape. More details when I'm done. Gerald Edit - Foil on second page of discussion. http://www.rcgroups.com/forums/showp...5&postcount=17 |
Joined Apr 2009
Jim,
The shape of the airfoil within reasonable limits has no effect on trim or flying characteristics except with respect to drag. Ditto the location of the hingeline if there is one. The slope of the lift vs. AOA curve is determined primarily by the profile of the stabilizer not by its airfoil. To be technically correct I should throw a small caveat in there that flow separation and bubbles can alter this slightly in some cases. I'm also not talking about what happens near or after tail stall. My full flying tails have negative camber because of two things. First, one pushes up elevator faster and more abruptly than down elevator with the one exception of the pushover at the top of the launch. Therefore it is desirable to have up elevator transients handled better, in preference to down elevator transients. This favors negative camber. Second, the airflow seen by the stab is a function of the turn radius. The tighter the turn, the more relatively curved the airstream is from the point of view of the stab (and the wing for that matter). This curvature is sweeping upwards. That makes the airfoils behave as if they have more camber than they really do. So starting with negative camber biases the airfoil in the direction that prevents it from getting too much effective positive camber and getting the low drag bucket off of the range where the stab will be flying. For a hinged elevator arrangement, we get none of the above, except for the tilted and curved airstream in a turn. The tilt is what bites a hinged elevator. The airfoils for this purpose are positive camber in an attempt to get the nose of the airfoil to line up better with the incident airstream. This helps keep the flow attached and reduces drag. The difference is substantial. BTW, even a fairly rearwards CG won't alter the lift the stab has to generate by much at all. So from that point of view the camber of the stab is essentially irrelevant. I mentioned hingelines above... There is a trend in Europe to put hingelines at 50% or behind on elevators and rudders (when they have one). This is sound structurally, but rather poor aerodynamically. When we apply an elevator or rudder control, we are making a shift in the zero lift line of the vertical or horizontal. The smaller percentage chord the control surface, the greater the required angle of deflection to get the same shift in zero lift line. Now the greater the angle of deflection, the more the control surface behaves as an airbrake and the less it behaves as a camber adjuster. So relatively narrow rudders or elevators require greater deflection for the same pitch or yaw adjustment to the model, and create a fair bit more drag when doing it. The stronger the maneuver, the greater the drag disparity. Given narrow ineffective draggy rudders, is it any surprise that many forego these controls all together? http://www.rcgroups.com/forums/showp...1&postcount=22 Edit: On the picture, the axis labeled alpha is the degrees of shift of the zero lift line. Gerald |
| Thread Tools | |
| Data DA8000 DS stabilizer airfoil by D. Ayers | Lt._Ayers | Dynamic Soaring | 0 | Apr 17, 2009 03:07 PM |
| Data DA8000 slope glider stabilizer airfoil by D. Ayers | Lt._Ayers | Slope | 0 | Apr 17, 2009 03:04 PM |
| Data DA8000 RC model stabilizer airfoil by D. Ayers | Lt._Ayers | The Builders Workshop | 0 | Apr 17, 2009 02:52 PM |
| Question Stabilizer Airfoil | kevin matthews | Free Flight | 13 | Aug 07, 2008 10:49 PM |
| Discussion bagged apogee stabilizer airfoil | bdo0000 | Hand Launch | 11 | Oct 09, 2007 11:10 AM |
